Call of Duty 4: Modern Warfare - הדיון הראשי
יש לי בעיה שאחרי כמה זמן שאני משחק אז הבעיה הזאת מופיעה...
מה לעשות???
[attachment deleted by admin]
  • תגובות 4k
  • צפיות 412k
מה לעשות???
הכי קל זה להוריד את ה PBSETUP מהאתר של הפאנקבסטר
להתקין אותו מחדש ולא לבטל תהליכים שלו אם אתה רוצה להמשיך לשחק
ולכמה תגובות לפני:
יש כבר פאצ' 1.2 רק שרוב השרתים הישראליים עוד לא עברו אליו אז לא שווה לעדכן בנתיים, רק שכל השרתים יעברו
Since the new components have been installed, I now get kicked from PunkBuster servers for "handshaking failed" or "Losing Key Packets", how can I fix that?
Some other software programs such as virus scanners, firewalls and Internet security software packages are suspicious of any new services and kernel drivers when they are first released. Some of these will block our new components thereby causing the "Losing Key Packets" kicking. Until these various packages are updated to correctly identify PnkBstrA.exe, PnkBstrB.exe, and PnkBstrK.sys as components of the PunkBuster Anti-Cheat System, players who experience PunkBuster kicks due to these conflicts need to either manually adjust the settings of the other software running on their system or disable the other software while playing on PunkBuster enabled servers. The new PunkBuster components make use of network resources and also frequently update files in the Windows system folders. This activity triggers warnings or blocks by some other security programs, some of which consider all unknown programs as threats or malware. Our new components are simply extensions of the existing PunkBuster system using new services and kernel software drivers, and are each signed with Verisign / Authenticode digital signatures for verifiable authenticity purposes. Most major security packages do not block our new components; users with other software that causes these conflicts should contact the vendor of their security package and request an update to correct this conflict.
איזה פיירוול/אנטיוירוס יש לך?
נסה לבטל אותם ולראות אם הבעיה חוזרת על עצמה.
התקנתי מחדש את הפאנק באסטר וזה לא עוזר...
אשמח לעוד תגובות...
דניאל.
שום דבר לא רשמי.
הכל בגדר שמועות וככה צריך להתייחס אליהן.
http://www.psxextreme.com/ps3-news/2251.html
נכון, שום דבר לא רשמי, אבל לפי מה קבעת שהמשחק הוכרז רשמית ל-XBOX?
דיברנו בדיון על ההכרזה של COD5 בכלליות וטענת שזה נכון ל-XBOX- הרי אין אזכור לדבר כזה...
הם חייבים, אבל ממש חייבים לסדר את ה-Server browser שלהם!
איך אפשר עם ה-FAV המעפנים האלה?
כשמנסים להתחבר לשרת ולא מצליחים, אי אפשר לבטל.
ובסוף הוא זורק אותי חזרה לתפריט הראשי, עכשיו אני אמור לזכור איפה הייתי ברשימה הארוכה הזאת?
איך אני לא מצליח להתחבר לשרתים עם פינג 80-100 הרבה פעמים?
מה עם רשימת שרתים אחרונים שהתחברתי אליהם?
בקיצור הרבה יותר מידי בעיות.
עכשיו למשל מצאתי שרת נורמלי ושכחתי להסתכל איך קוראים, אין מצב שאני אמצא אותו עוד פעם.
יאללה פאצ'!
זה אמנם לא פיתרון לבעיה, אבל אני לא נתקל בבעיה הזאת בגלל שאני משתמש בשרתים ישראלים ומתחבר אליהם ידנית דרך הקונסול.
ככה בעצם, לא קרתה לי פעם אחת בעיה של ping או שום מצב בעייתי אחר... (לנוחיותכם, רשימת השרתים הישראלים)
היום קבלתי את המשחק סוף, סוף...
משחק ענק!!! לא יודע מה אנשים מתלהבים מקרייסס, COD4 יפה בכל רמות.
נחמד גם שהמנוע שלו לא דורש כרטיסים כבדים על הכיס. :xyxthumbs: :xyxthumbs: :xyxthumbs: :xyxthumbs: :xyxthumbs:
אשמח לעוד תגובות...
דניאל.
תפקח את העיניים לעזאזל :s07:
ככה זה, קרייסיס נמצא בכותרות רק בגלל ההייפ סביבו והמנוע הכל-כך מציאותי שלו עד מוות (מבחינת הכרטיסים הגרפיים שלנו :kopfpatsch:).
אני ממש לא מסכים עם כמה אתרי סיקורים שהביאו לו ציון זהה או גבוה משל COD4, ללא ספק העלילה והתכנון שלבים המעניין של COD4 צריך לזכות אותו ביותר נקודות מקרייסיס.
אני אישית הייתי מדרג ככה:
Call of Duty 4 - 9.5
Crysis - 8.5
Crysis - 8.5
אני הייתי נותן את הציונים הללו רק למולטי, לגבי הסינגל לשניהם אני חושב שמגיע 9.5...אין פשוט אין על המשחקיות הגאונית של COD!!! אם ישלבו את הגרפיקה האדירה של קרייסיס עם המשחקיות והאקשן האדיר של COD אני חושב שנקבל משחק עם ציון 9.8 או יותר...
יש לי AVG.. גם אנטיווירוס וגם spyware של AVG... והחומת אש היא הרגילה של XP... אבל עד עכשיו זה לא עשה בעיות בגלל התוכנות האלו... רק עכשיו זה התחיל... זה עושה אחרי משהו כמו 10 דק' של משחק..
תודה.
למה החלטת שזה השרת של bitchslap? זה של הקלאן שלנו...
ואם מישהו יכול להביא רשימה של פקודות וכאלה למולטי זה ממש יעזור.. במיוחד פקודה של קפיצה גבוהה...
ועוד פעם מזכיר לכם --- 80.179.149.218:28960
חשבתי כך......
בכל מקרה סבבה לשחק איתכם, חוץ מזה שאתם לא פארים, שיחקתם שלושתכם על דרגה 55 נגד סימון סיקס ונגדי כאשר אני עוד בדרגה הרבה יותר נמוכה מכם, מישהו ממכם היה אמור לבוא אלינו.
תגובה כאילו לא ראית משחק טוב בחייך...
מה אתם משווים בין שני המשחקים האלה, כל משחק בדרכו שלו.
אני אוהב את COD4 וגם את קרייסיס, שניהם משחקים טובים בדרכם.
אנשים, אין מה לעשות לקרייסיס יש דרישות מערכת ואם המחשב שלכם לא עומד בהם אז דעתכם כלל לא אובייקטיבית ובטח שלא חשובה כי אתם לא יכולים להנות ממה שהמשחק הזה מציע.
בכל מקרה, אל תהפכו את הת'רד הזה להשוואות בין משחקים שונים כי שניהם נמצאים בליגה משלהם.
אנשים, אין מה לעשות לקרייסיס יש דרישות מערכת ואם המחשב שלכם לא עומד בהם אז דעתכם כלל לא אובייקטיבית ובטח שלא חשובה כי אתם לא יכולים להנות ממה שהמשחק הזה מציע.בכל מקרה, אל תהפכו את הת'רד הזה להשוואות בין משחקים שונים כי שניהם נמצאים בליגה משלהם.
שיחקתי אצל חבר שיש לו 8800GTX, והגעתי למסקנה שהמשחק הזה הוא ממש FC עם שידרוג גרפי.
ואם אתה כל כך מבין במשחקים, אז איך לא שמת לב ל-AI של השחקנים בקרייסיס? פשוט בושה.
נכון שלמשחק COD4 יש סגנון שונה מקרייסיס, אבל ל-COD4 יש נשמה.
לא אמרתי שקרייסיס זה משחק מושלם אך מבחינה גרפית הוא הקדים את זמנו.
יש לו הרבה באגים שצריך לתקן.
אני בן 29 ולא ילד בן 15, יש לי עבר עשיר במשחקים עוד מימי אבא רבה ובבה.
AI זה לא הדבר העיקרי שאני מחפש במשחק טוב.
AI לא נמצא בראש ענייני, אותי מעניין העלילה והסיפור, אני לא בוחר את המשחקים שאני רוצה לשחק לפי ה-AI שלהם.
אני נהנתי לשחק ב-2 המשחקים, לפי דעתי שניהם מעולים ברמות בתחום שלהם.
יש לי את 2 המשחקים המקוריים ואני נוטה יותר לכיוון של קרייסיס, אולי נכנסתי כמה פעמים לשחק ברשת ב-COD4 וזהו.
אני מעדיף והרבה יותר נהנה לשחק CRYSIS.
FARCRY זה משחק לא מהעולם הזה מבחינת המולט פליי שלו אבל את הסינגל כלל לא אהבתי.
בקשר ל-COD4, מה שסחף אותי במשחק הזה זה לא המשחקיות כי היא קצת בינונית לפי דעתי אבל מבחינת סיפור הוא מאוד מציאותי.
רובנו מכירים את המצב בעולם, המלחמה בעירק, הפצצה האיראנית שמתכוננת לבוא ובטח המצב בארץ עם הפלסטינים.
אין ישראלי שלא יאהב את COD4, מי לא היה רוצה לחסל את המחבלים האלה, כולנו מרגישים שייכות למשחק הזה מהבחינה שהסיפור מאחוריו מציאותי ונוגע לליבנו.
קרייסיס משחק מעולה
COD4 משחק מעולה.
שניהם שווים את הכסף.
יש לי בעיה במחשב שאני לא יכול לראות שום קובץ וידיאו.. לא יכול לעשות שיכזור מערכת ולא יכול להוריד עידכונים מהUPDATE...
אז אני עושה פירמוט... רק תגידו לי איך אפשר לגבות את הפרופיל שלי בCOD??
