Changing the size of a partition
Hello everybody,
I have a SATA HD that was partitioned to a 20GB C: partition and a 100GB D: partition. The partitions were created during the windows installation process (not using partition magic or other software). I'm using XP SP2.
I want to change the size of C: to 30GB (D: has about 20GB free on it). Can I do it easily and safely?
Thanks!
:xyxthumbs:
