Overlord DEMO RELEASED!!!
OFFICIAL RELEASE AT GAMESPOT
http://www.gamespot.com/pc/action/overlord/download.html?sid=6172322&tag=topslot;title;1&om_act=convert&om_clk=dltopslot
README:
Download Details
"OVERLORD" Demo ReadMe - 05/06/07 - v1.0
I. Introduction - Specifications
II. Installation
III. Running the Game
IV. Controls
V. FAQs
VI. Performance Issues
VII. Known Issues
VIII. Useful Web Sites
I. Introduction:
Thank you for playing the OVERLORD Demo. This file contains detailed technical
information so please read it through carefully.
Minimum Specification:
- Windows XP
- DirectX 9.0c
- CPU: Pentium 2.4 GHz or Athlon XP 2400+
- 512 mb RAM
- Graphics Card: GeForce FX5900 / Radeon 9500 or above
- DirectX 9 Compatible Sound Card
- 1.2 Gb Hard Drive Space
Recommended Specification:
- Windows XP / Vista
- DirectX 9.0c
- CPU: Intel Core 2 Duo or Athlon 64 X2
- 1Gb RAM
- Graphics Card: GeForce 7800 or Radeon X1800
- Creative Sound Blaster X-Fi Sound Card
Supported Graphics Cards:
ATi Radeon 9500, 9600, 9700, 9800, X300, X600, X700, X800, X1300, X1600, X1800,
X1900, X1950
nVidia GeForce FX5900, FX5950, 6600, 6800, 7100, 7300, 7600, 7800, 7900, 7950,
8800
Not compatible with all integrated sound/graphics solutions (inc. Laptops).
II. Installation
To install and run the game you must be logged into the PC as an
Administrator.
Place the OVERLORD DVD in your DVD drive. If you have Autorun enabled, the game
should
automatically start the installation process. If it doesn't start
automatically, then
browse to 'D:\' (where 'D' is the drive letter of your DVD drive) and
double-click
'setup.exe'.
To continue installation simply follow the on screen prompts.
During installation you will be asked if you would like a desktop shortcut to
be created, double-click this to start the game.
Alternatively you can start the game by going to:
Start Menu -> Programs -> Codemasters -> Overlord Demo -> Overlord Demo.
IV. Controls
KEYBOARD - DEFAULT CONTROLS
Move Overlord: W, A, S and D
Overlord Action: Space
Send Minion: Left mouse button
Callback minion: Right mouse button
Sweep: Left + Right mouse button
Cast spell: E
Guard Marker: Q
Target Lock: Left Shift
Previous/Next target: Shift + Z/C
Camera zoom: Move mouse forward/backwards
Center Camera: F
Prev/Next Minion type: Mouse scroll wheel
Select Minion type: 1 - 4
Select all Minions: `
Select spell: F1 - F12
You can change the default keys by running the Overlord configuration tool
- Run Start Menu -> Programs -> Codemasters -> Overlord Demo -> Config
- Select the Controls tab
- Select Mouse & Keyboard
- Change the key / mouse settings using the lists next to each action
- Click Save & Play
GAMEPADS
Overlord is designed to support the Xbox 360 Controller for Windows. To ensure
it is set up correctly.
- Run Start Menu -> Programs -> Codemasters -> Overlord -> Config
- Select Gamepad
- Click Save & Play
Many other gamepads are also compatible, however they must have at least two
analog sticks, and 15 distinct button inputs.
You will also need to configure the gamepad before play.
- Select Gamepad (Configurable)
- Now click the Configure button. A new window will appear which allows you
to select a button for each of the actions
- Click the button to the left of the action you wish to Configure (it will now
say Scanning)
- Press the gamepad input that you want to perform that action
- Repeat this for all actions
- Click Ok to return to the main Overlord Config tool
- Click Save & Play
NOTES:
- You may need to update your gamepad drivers in order to map all the buttons
on your controller.
- You may not be able to map all the buttons to your controller. In this
instance you can leave them blank, however you will not be able to use them in
game. Pause Menu is a good one not to map, as the ESCAPE key has the same
function in game.
V. FAQ's
Overlord requires at least 512 MB of RAM and a 2.4 Ghz processor. The
performance of the game will improve if you have more RAM, a faster processor
and graphics card. Regardless of your machine specs, you can maximise your
available memory and increase the overall performance of the game by doing the
following:
Shut down all non-essential Windows programs especially online
chat programs, virus checkers and screen layout utilities.
Regularly defragment your hard drive.
Increase your amount of free hard drive space.
If you are experiencing poor performance on a low-end graphics card (see the
ordered list of cards above)...
Reduce the game resolution in the Overlord Configuration program to 800x600
or lower.
Select "Custom" in the Video tab of the Overlord Configuration program and
turn off or set to Low the various options, particularly:
Shadows
View Distance
Soil Cover
Turning these options on again one by one will reveal which are causing the
problems, and
this will allow you to get the most from your card.
Always ensure you are using up-to-date drivers for your graphics card:
For ATi cards, download drivers from: www.ati.amd.com/drivers
For nVidia cards, download drivers from: www.nvidia.com/drivers
VII. Known Issues
Using low-end graphics cards (in particular the ATi Radeon 9600 SE) you may
experience graphical issues on certain levels when playing using the default
settings. To fix these issues use the custom detail settings in the Overlord
Configuration tool: set all options to Low or Off, and ensure the screen
resolution is set to 800x600 or lower.
Codemasters
http://www.codemasters.com/
If you are having problems running the game, you may want to try updating your
graphics card drivers from one of the following web sites before contacting
technical support:
ATI Technologies
http://www.ati.com/
Creative Labs
http://www.creative.com/
NVIDIA
http://www.nvidia.com/
© 2005 - 2007 Triumph Studios B.V. ("Triumph"). All rights reserved.
"Codemasters"® is a registered trademark owned by The Codemasters Software
Company Limited (Codemasters). The Codemasters logo is a trade mark of
Codemasters. "Overlord" is a trademark of Triumph. All other copyrights or
trademarks are the property of their respective owners and are being used under
license. Developed by Triumph and published by Codemasters. Unauthorised
copying, adaptation, rental, lending, re-sale, arcade use, charging for use,
broadcast, cable transmission, public performance, distribution or extraction
of this product or any trademark or copyright work that forms part of this
product is prohibited.
Microsoft, Xbox, Xbox 360, Xbox Live, and the Xbox, Xbox 360, Xbox Live logos
are either registered trademarks or trademarks of Microsoft Corporation in the
U.S. and/or other countries.
  • תגובות 70
  • צפיות 5.7k
חזק ביותר , נראה משחק בן זונה, אני מוריד
תודה.
ראבק ג'יגה דמו :o
שיחקתי
משחק נחמד מאוד
ואהבתי את הגרפיקה...
עובד חלק ביותר על ההגדרות הכי גבוהות
this game is LEGENDARY
איזה סוג משחק זה?
יריות גוף ראשון , אסטרטגיה? איך זה עובד..
וואו, תודה משחק שווה טילים, שיחקתי לבנתיים 5 דקות משחק סוס.
אני מוריד תמשחק Overlord Demo נראה משחק טוב... :xyxthumbs:
אבל זה מוריד לי על 120KB גג ויש לי 3 מגה... למישהו יש לינק טיפה יותר מהיר?
ותגידו זה ירוץ לי על הגדרו בנוניות עם המפרט הזה:
E6600
X1950XT 256MB ATI
2 GB זיכרון קינג סטון דואל צ'נאל?
תודה מראש :)
ירוץ ועוד איך ירוץ, לינק אני לא מוצא, אבל מוזר למה זה מוריד לך לאט אצלי זה הוריד על עם האינטרנט 1.5 מגה על 192KB.
מישהו יכול להגיד לי איזה סוג משחק זה נקרא? אני לא מבין במשחקים האלה ;D
אמא!!! זה מזכיר לי את GOLDEN AXE!!!
חחחח גולדן אקס? לא חושב שקצת הגזמת? חח :lol:
ואחי SyndromE תודה על כול הלינקים אבל אין לינק אחד שמוריד על 250KB או 300KB רק 180KB בעעעע
אז עם מישהו יכול להביא לינק מהיר אני יודה לו :)
ובעיקרון מישהו יכול לספר קצת מהדמו איך הוא? מה יש במשחק הזה וכדומה?
לא יודע...
יש את הדמו לשכן שלי (הגרוטאה שלי לא סוחבת בשיט!) על הLT שלו משחק מצוין!!
אגב במשחקיות הוא באמת מזכיר לי את GA
מוריד עכשיו, מקווה לטוב.
תמונות:
הגדרות הכל על המקסימום AAx16 + AFx16 + 1920x1200.
[attachment deleted by admin]
