איך המפרט הזה? תקציב: 2000 דולר. NEWEGG
Intel Core 2 Duo E6300 Conroe 1.86GHz LGA 775 Processor Model BX80557E6300 - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16819115005
EVGA 122-CK-NF68-AR Socket T (LGA 775) NVIDIA nForce 680i SLI ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16813188009
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL4D-2GBPK - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16820231087
Western Digital Caviar SE16 WD5000KS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Product.asp?item=N82E16822136014
PNY VCG88GTSXPB GeForce 8800GTS 640MB GDDR3 PCI Express x16 HDCP Video Card - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16814133188
ViewSonic Q19WB-2 Black 19" 5ms Widescreen LCD Monitor - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16824116065
SAMSUNG 18X DVD±R DVD Burner With 12X DVD-RAM Write, LightScribe Technology Black SATA Model SH-S183L - OEM
http://www.newegg.com/Product/Product.asp?item=N82E16827151141
RAIDMAX ATX-701WB Black Aluminum ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16811156060
Antec True Power Trio TP3-550 ATX12V 550W Power Supply with Three 12V Rails - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16817371002
Scythe SCNJ-1100P 120mm CPU Cooling Fan - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16835185038
Logitech X-540 70 watts 5.1 Speaker - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16836121006
Razer Copperhead Anarchy Red 2000 dpi Gaming Mouse - Full Retail Multi Language - Retail
http://www.newegg.com/Product/Product.asp?item=N82E16826153106
Microsoft Natural 4000 B2M-00012 Black USB Wired Ergonomics Keyboard - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16823109148
סכום כולל: $1,876.88
נראה טוב מאוד...
אמממ אתה עושה OC?
אם כן עדיף לעלות ל 6400 במעבד...
לא אמור להיות יותר יקר בהרבה...
אם לא אז תירד בזכרונות ל 667...
מפרט מעולה סך הכל...
כן OC מתוכנן... למה עדיף ה6400 ?
אם מתוכנן OC קטן אז אפשר להשאיר את ה6300
אבל עם OC גדול אז כדאי את 6400 בגלל של6400 יש מכפלה גדולה יותר ואם מתכננים OC רציני המכפלה הגדולה יותר ב6400 תהיה מועילה...
קודם כל תוסיף את התקציב לכותרת בבקשה לי חוקי הפורום.
לגבי המפרט,אני אתייחס לתחום הקרוב לליבי,מארזים וספקים.
המארז הזה רחוק מלהיות איכותי.
בתוספת קטנה כדאי לקחת NEOHE 550
http://www.newegg.com/Product/Product.asp?Item=N82E16817103941
ולגבי מארז בעוד 20$ אתה לוקח GB אורורה 570
קח את GIGABYTE AURORA 3D
אולי לא את AURORA אם אין תקציב אז את פוסידון או משהו דומה
יקח יותר אבל הרבה יותר איכותי
ספק לא יודע חח
אולי LIBERTY
מארז תחליף ל Antec Nine Hundred Black Steel ATX
http://www.newegg.com/Product/Product.asp?Item=N82E16811129021
ספק תיקח את ה SeaSonic S12 Energy Plus SS-550
http://www.newegg.com/Product/Product.asp?Item=N82E16817151027
לגבי המסך שלקחת הוא בסדר גמור חוץ מהעובדה שאין לו כניסה של DVI. אם אתה יכול להתגמש קח את
http://www.newegg.com/Product/Product.asp?Item=N82E16824014105
המסך ממש גרוע בשביל התקציב. תרד בלוח ותיקח מסך יותר נורמלי.
קודם כל, לא מחליף מארז, המארז הזה יותר מדי יפה בשביל לפסוח עליו :xyxthumbs:
מה גם שהוא מאלומיניום טהור , כמה גרוע הוא כבר יכול להיות?
מה רע בויוסוניק ? אשמח לתחליף אחר במסגרת התקציב
מעבד אכן אני אחליף לE6400.
מה ההבדל בספקים בין זה שבחרתי לבין הNEOH הזה ?
תקציב כולל 2000 דולר אגב
עריכה:
לא שמתי לב שהVIEWSONIC הוא לא DVI
עריכה:
חבל המארז שהבאתי לך הוא גם מאוד יפה אבל יותר חשוב הוא יותר אייכותי ושקט וגדול ממה שלקחת. כנ"ל לספק.
תראה קצת תמונות של המארז.
http://www.newegg.com/Product/ShowImage.asp?Image=11%2D129%2D021%2D18%2Ejpg%2C11%2D129%2D021%2D04%2Ejpg%2C11%2D129%2D021%2D05%2Ejpg%2C11%2D129%2D021%2D06%2Ejpg%2C11%2D129%2D021%2D07%2Ejpg%2C11%2D129%2D021%2D08%2Ejpg%2C11%2D129%2D021%2D09%2Ejpg%2C11%2D129%2D021%2D10%2Ejpg%2C11%2D129%2D021%2D11%2Ejpg%2C11%2D129%2D021%2D12%2Ejpg%2C11%2D129%2D021%2D13%2Ejpg%2C11%2D129%2D021%2D14%2Ejpg%2C11%2D129%2D021%2D15%2Ejpg%2C11%2D129%2D021%2D16%2Ejpg%2C11%2D129%2D021%2D17%2Ejpg%2C11%2D129%2D021%2D03%2Ejpg&CurImage=11%2D129%2D021%2D18%2Ejpg&Description=Antec+Nine+Hundred+Black+Steel+ATX+Mid+Tower+Computer+Case+%2D+Retail
מה התקציב שלך למסך לפי זה יהיה יותר קל לבחור לך אחד.
אם אתה יורד ל-P5B-E למשל, יש לך 100$ בשביל להוסיף ולקחת את ה-204BW או את ה-VP930b. אפשר אולי גם לחתוך קצת בשילוב של המארז+ספק ואז בכלל לקחת מסך כמו ה-Dell 2007WFP.
התקציב הוא 2K$ הוא ניצל רק 1870 ממנו כלומר נשאר 130$ לשיפורים.
כלומר הוא יכול לקחת או את הסמסונג או את הBENQ 20 ואתה המארז שהמלצתי לו עליו ועדיין הוא לא ניצל את כל התקציב שלו.
אין תקציב ספציפי, יש תקציב כולל של 2000 דולר.
תוסיף אותו לכותרת
תוסיף אותו לכותרת
Done
נ.ב: חבל לי לפתוח אשכול חדש. את המפרט שלי אני מתכוון למכור בארץ לפני הנסיעה, כמה לדעתכם אני יכול לקבל עליו בארץ הקודש ? מפרט בצד ימין
