בעייה קטנה בSDL ..
שאני כותב משהו בSDL .. הוא מריץ לי את התוכנית בלי אף שגיאה וערה מופיע מסך שחור אבל איך בו כלום ..
ואז נופיעות מלמטה הודעות כאלה :
Loaded 'ntdll.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32kernel32.dll', no matching symbolic information found.
Loaded 'C:Program FilesMicrosoft Visual StudioMyProjectsSDL2DebugSDL.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32winmm.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32user32.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32gdi32.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32advapi32.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32rpcrt4.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32msvcrt.dll', no matching symbolic information found.
Loaded symbols for 'C:WINDOWSsystem32MSVCP60D.DLL'
Loaded symbols for 'C:WINDOWSsystem32MSVCRTD.DLL'
Loaded 'C:WINDOWSsystem32lpk.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32usp10.dll', no matching symbolic information found.
Loaded 'C:Program FilesTuneUp Utilities 2006WinStylerThemeHelper.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32oleaut32.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32ole32.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32ddraw.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32dciman32.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32uxtheme.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32MSCTF.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32kbdus.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32dsound.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32version.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32dinput.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32hid.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32setupapi.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32wintrust.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32crypt32.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32msasn1.dll', no matching symbolic information found.
Loaded 'C:WINDOWSsystem32imagehlp.dll', no matching symbolic information found.
The thread 0x4EBC has exited with code 0 (0x0).
The thread 0x4150 has exited with code 0 (0x0).
The thread 0x41B8 has exited with code 0 (0x0).
The program 'C:Program FilesMicrosoft Visual StudioMyProjectsSDL2DebugSDL2.exe' has exited with code 0 (0x0).
[אני עובד עם VS6.0] משהו מוכן הסביר לי מה הבעיה בבקשה ??
אין כאן שום בעיה.
השורות האלה מופיעות במצב debug כאשר מערכת ההפעלה טוענת ספרייה דינאמית (Dll) וה- Visual Studio לא מוצא את ה- debug information שלה. (כל עוד אלה לא ספריות שלך - אין בעיה).
התוכנית פשוט לא מחכה לשום קלט ויוצאת.
אהה אוקי ..
ויש איזה שהיא דרך להגדיר קלט בSDL כדאי שאני לפחות יראת תתוצאה ?
