הבדל בין מארזים..???
רציתי לדעת מה ההבדל בין המארזים הבאים:
SILVERSTONE TJ06B מחיר 940
לבין ENERMAX CS-718 מחיר 680
תודה!!
ה-SS
Material
Aluminum front panel, 0.8mm SECC body
Color Black
Silver
Motherboard Extended ATX, ATX, Micro ATX
Model Standard Model
TJ06S
W / Window
TJ06S-W
TJ06B
TJ06B-W
Drive Bay Exposed
5.25 x 5
3.5 x 2
Hidden 3.5 x 6
Cooling System Front
120mm intake fan, 2200rpm, 21dBA
Front 80mm intake fan, 2200rpm, 21dBA
Rear 120mm exhaust fan, 1200rpm, 21dBA
Customized 120mm CPU wind tunnel
Expansion Slot
7
Front I/O Port
USB2.0 x 4
IEEE1394 x 1
audio x 1 ]
MIC x 1
Power Supply Optional standard PS2 (ATX), Redundant PS2
Net Weight
11 kg
Dimension 205 mm (W) x 566 mm (H) x 474 mm (D)
ה-ENERMAX
Type Entry level Server
Dimensions D480*W200*H560 mm
Material SECC 0.8 mm
Drive Bays 5.25" 4
3.5" 2
Hidden 6
M/B ATX, Micro ATX, Extended ATX
Power PS2, Mini Redundant
Front I/O Interface USB 2.0 x 4, Hi Definition Audio in/out, IEEE 1394
Cooling Fan Front 12 cm x 1, 8cm x 1(optional)
Rear 12 cm x 1
Expansion Slots 7
