מי עדיף ? 1500$ בארה"ב
זה של DELL ב 1450 :
Inspiron E1505:
Intel® Core 2 Duo processor T7200 (4MB Cache/2.00GHz/667MHz FSB)
Operating System (Office software not included):
Genuine Windows® XP Professional WPXP
LCD Panel:
inch UltraSharp Wide Screen SXGA+ Display with TrueLife 15SXGA
Memory:
2GB Shared Dual Channel DDR2 SDRAM at 533MHZ, 2 DIMM
Hard Drive:
80GB 5400rpm SATA Hard Drive 80GB [341-3108][420-5449] 8
Combo or DVD+RW Drive:
8X CD/DVD Burner (DVD+/-RW) with double-layer DVD+R write capability 8XDVDRW [313-3959][420-5775][420-5901] 16
Video Card:
256MB ATI MOBILITY RADEON® X1400 HyperMemory 256ATI [320-4655] 6
Sound Options:
Integrated Audio IS [313-4217] 17
Network Card and Modem:
Integrated 10/100 Network Card and Modem INTNIC [430-0493] 13
Adobe Software:
Adobe® Acrobat® Reader 7.0 ADOBER [412-0917] 15
Miscellaneous:
E1505 Dual Core 1505D35 [465-7988] 82
Processor Branding:
Intel Centrino Core Duo Processor ICNDNB [310-8314] 749
Primary Battery:
53 WHr 6-cell Lithium Ion Primary Battery 6BAT [312-0404] 27
Wireless Networking Cards:
Intel PRO/Wireless 3945a/g IP3945 [430-1918] 19
Bluetooth Options:
Dell Wireless 355 Bluetooth Internal (2.0 + Enhanced Data Rate) TM355I [430-1777] 121
Office Productivity Software (Pre-Installed):
No productivity suite- Includes Microsoft Works 8. DOES NOT INCLUDE MS WORD IWRK [412-0915] 22
Anti-Virus/Security Suite (Pre-installed):
No Security Subscription TMNO [412-0850] 25
Dell Digital Entertainment:
Starter pack- Basic and trial products from Corel and Yahoo SEP [412-0865] 399
Warranty and Service:
1Yr Ltd Warranty and Mail-In Service
או זה של HP :
HP Pavilion dv6000t + $50 Mail-In Rebate
Costco Member Price $1,379.99
Shipping & Handling $0.00
Estimated Shipping Date : 11/2/2006
Price Shown is Before Rebate
$50 Manufacturers Rebate
8/30/06 through 12/16/06
CLICK HERE FOR REBATE DETAILS.
Selected Features:
Intel® Core 2 Duo processor T7200 (2.00 GHz)
2.0GB DDR2 SDRAM (2x1024MB)
FREE Upgrade from 60 GB 5400 RPM to 80 GB 5400 RPM
FREE Upgrade: 8X DVD+/-R/RW w/Double Layer Support
256MB NVIDIA® GeForce® Go 7400
Intel® PRO/Wireless 3945ABG Network w/Bluetooth
FREE Upgrade to 15.4" WXGA BrightView Widescreen!!
Genuine Windows XP Professional
Microsoft® Works/Money
6 Cell Lithium Ion Battery
HP IMPRINT Finish + Microphone + Webcam
System Recovery DVD w/Windows XP Professional
No TV Tuner w/remote control
Included Features:
HP PhotoSmart Premier
HP QuickPlay
1 Expansion Port 3 connector
1 ExpressCard/54 Slot (also supports ExpressCard/34)
2 USB 2.0 ports
1 Consumer IR (Remote Receiver)
S-video TV-out port
Built-in Altec Lansing stereo speakers
Touch Pad with dedicated vertical and horizontal Scroll Up/Down pad
101 key compatible
"90W AC Adapter (Discrete graphics) 65W AC Adapter (Shared graphics)"
1-year limited H/W warranty
90-day S/W warranty
תודה !
אוקיי . מצטער .
התקציב שלי הוא עד ל 1500$ , והדברים העיקריים הם = C2D , 2G , וכרטיס מסך לא מובנה דהיינו ה GMA950 .
תודה רבה .
אני לא מבין מה לא ברור:
שימו לב! ת'רד ללא תקציב בכותרת ינעל מיידית!
אני הייתי הולך על dell גם אני קניתי אותו מחו"ל(אם כי המפרט קצת שונה) אחלה נייד ממליץ
איפה שאני נמצא כרגע יש שמועות שהמחשבים של HP הם מורכבים מחלקים זולים , ומתקלקלים הרבה יותר מהר .
נכון ??
מה ששמתי לב שבמפרט של HP במחשבים עם ה15" אין יציאה ל FIRE WIRE ו ETHERNET , משא"כ עם ה 17" שלא עולה הרבה יותר יקר .
תשמע שכחתי לגמרי קניתי את הנייד (dell) יש לי אליו שנתיים אחריות בינלאומיות אבל אין עליו אחריות בארץ
קח זאת בחשבון...אם זה לא מפריע לך אז עדיף הDELL
תשאל גם אם הניידים של HP אם יש להם אחריות בארץ...
הייתי הולך על ה DELL מכמה סיבות:
1. DELL > HP - לא יעזור כלום עדין התמיכה, השירות, האחריות והשם הולכים עם DELL.
2. ה X1400 טוב יותר מה NVIDIA GeForce Go 7400 (אמנם במעט) אבל עדין.
3. המסך של ה DELL עם SXGA+ בעל רזולוציה טבעית של 1400x1050 יותר טוב מה WXGA הרגיל של ה HP שלרוב הוא בעל רזולוציה טבעית של 1280x800. (קח לתשומת ליבך שאין כמו מראה עינים ולכן מומלץ לבדוק את שניהם ולראות איזה מסך עונה על דרישותיך טוב יותר מבחינה ויזואלית)
חבל להטעות קונה תמים:
סעיף 1: שטויות מגוחכות וחסרות כל בסיס, חוץ מזה שזה בכלל לא רלוונטי כי לא תהיה לו אחריות בארץ.
סעיף 2: ההבדלים כל כך מינוריים שאפילו מצחיק לדבר על זה, לא שיקול בכלל, שניהם זהים בכל מה שלא קשור לBENCHMARKING או מדידת ביצועים במשחקים עם FRAPS, שם תראה הבדל של אולי 2 פריימים.
סעיף 3. לא רק הרזולוציה חשובה, אלא גם איכות התמונה. השוות את שני המסכים? חוץ מזה שרזולוציה כזאת מספיקה בהחלט גם ככה...
"חבל להטעות קונה תמים:" אני לא הייתי אומר את זה .
1 : לא כ"כ חשובה לי האחריות בארץ כי אני הולך להיות פה שנה .
2 : ההבלים בבנצ' הם כן משנים וקצת יותר ממינורים בדוק .
3 : בנוגע לרזולוציה אתה צודק שמספיק לי כמו מה ש HP מציעים ( קראתי שטכנולוגיית ה BRIGHT VEIW שלהם עושה רק טוב עם המסך ) .
מסכנות חברה !
יש את הנייד dell enspirion e1505 מקביל ל6400 בארץ אם לא חשובה לך האחריות אז DELL
בלי שום ספק השרות והאיכות מדברים בעד עצמם...
לגבי המסך אצלי הוא בmax ב800*1280 וזה מספיק מעל ומעבר
אתה ממש בור ועם הארץ.
1. תסתובב קצת בעולם ותראה איך מתיחסים ללקוחות בחברה כמו DELL ואיך מתיחסים ללקוחות בחברה כמו HP, תצא מהבועה. הבנאדם לא חיפש אחריות בארץ.
2. ההבדלים לא מינוריים ואי אפשר להתעלם מהם.
3. אם הייתה לך הבנת הנקרא ברמה בסיסית כיתה ג' היית מבין שרשמתי לו שעל הנייר מסך ה DELL יותר טוב (מה לעשות ש SXGA+ טוב יותר מ XGA) אבל שאין כמו מראה עיניים ולכן עליו לבחור את מה שנראה לו כטוב ביותר.
חבל שאתה כסיל. אתה יודע מה אומרים "יש שהשתיקה יפה להם"
זה שקנית HP ואתה מרוצה ממנו, מברוק! אבל עם עובדות אי אפשר להתווכח, כאשר בן אדם שואל שאלה בקשר למפרט הוא מצפה לקבל תשובה מקצועית הנוגעת לחומרה ולדרישות שלו. אנשים כמוך צריך לחסום מפורומי תמיכה כי אתה רק מטעה אנשים.
mhu,
ללא שום קשר למי צודק ומי טועה, תרבות דיון קודמת לכל, ולפי ההודעה האחרונה שלך דרוש שיפור דחוף מצדך בנושא.
תוכן הודעות:
יש להשתמש בשפה נאותה בהודעותיכם ולשמור על תרבות דיון גבוהה. חל איסור מוחלט להתלהם, לקלל, לפגוע, להעליב, או להשמיץ כל גורם כזה או אחר מכל סיבה שהיא.
דיונים או הודעות אשר עוברות על חוקים אלו לא מתאימות למסגרת הפורום והן יצונזרו או ימחקו. כמו כן, למשתמש הרלוונטי תתווסף אזהרה!
ולכן מתווספת לך אזהרה ראשונה.
מעניין... אני מתבסס על נתונים קצת יותר רציניים כמו למשל אחד מהמותן:
http://www.ynet.co.il/articles/0,7340,L-3317440,00.html
חוץ מזה שאני מכיר רק ביקורות טובות על HP(בלי קשר בכלל לDELL), אני רוצה להגיד שHP חברה ראויה לא פחות מDELL ושניהן חברות גדולות שמומלץ לקנות ניידים מהן.
אני מתבסס על נתונים אובייקטיביים לאומתך "תסתובב קצת בעולם ותראה איך מתיחסים ללקוחות בחברה כמו DELL ואיך מתיחסים ללקוחות בחברה כמו HP" שזאת טענה שמבוססת על דעה אישית בלבד, ולא יותר(אלא אם כן תתן לי נתונים אחרים (דגש על מבוססים) הטוענים אחרת, כאשר לקוחות גדולים(כמו הצבא למשל, או מוסדות חינוך) שאנשים שאני מכיר שם, יש להם להגיד רק טוב.
לגבי עוד טענה חסרת בסיס של "אתה FANBOY של HP", שוב פעם אני חוזר שהייתי סגור על נייד של DELL במשך שבועיים עד שנוספו כל החסרונות של DELL(שאתה הולך לגלות, או שהיית מגלה אם היית מקשיב או בודק לפחות יותר טוב בעצמך, כמו למשל בהשוואה הישירה שעשית באשכול אחר, שבו כתבת שהDELL בעל ג'יגה זכרון כבר במחיר של 6800 כאשר הDELL שאתה מתעניין בו בא עם 512 מגה זכרון... או שהחנות שבה אתה קונה לא מופיעה בZAP? ובפעם האחרונה שבדקתי הם לא שינו לא את המפרט ולא את המחיר, אז ההבדל במחיר הוא 6400 מול 7200 כבר, תמורת הבדלים כמו "2 מגה CACHE מול 4 מגה CACHE", ועוד הוספת טכנולוגית הTRUEBRIGHT שמסך, שלא כלול בדגם הזה(כתוב אופציונלי אבל לא כתוב מה המחיר או האם באמת יש להם במלאי את 2 סוגי המסכים לניידים)
לגבי תרבות הדיון שלך, לא מתפקידי לטפל בזה.
אני לא מבין למה אתה אומר ש -HP חברה טובה אני חושב שגם LG שלי טוב כול אחד חושב ששלו יותר טוב זה טבעי
