Titan Quest - עוד מעט זה מגיע [הדיון הרשמי]
עכשיו זה רשמי, Titan Quest הועבר בשני לחודש ליצור המוני.
המשחק אמור להיות סטייל דיאבלו ויכלול מצב משחק COOP בנוסף למשחק לשחקן יחיד.
This highly anticipated action Role-Playing Game (RPG) will take Windows PC gamers on a transcontinental journey through the treacherous and exotic lands of Greece, Egypt and Asia, blending an immersive storyline with fast-moving combat and lush, cinematic gameplay for the ultimate RPG experience.
הדמו כבר זמין להורדה:
http://www.gamershell.com/download_13703.shtml
Recommended System Requirements
* Windows XP
* 3.0 Ghz Intel Pentium IV or equivalent
* 1 GB RAM
* 500MB or more free hard drive space
* 128 MB NVIDIA GeForce 6800 series or ATI Radeon X800 series or equivalent
* DirectX® 9.0c compatible
* 8x or faster CD-ROM/DVD drive
* Kyboard, Mouse
Can't install the demo even though you have enough hard drive space? This sometimes occurs on partition hard drives.
* Solution:
* Run regedit, navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion and change ProgramFilesDir to C:\Program Files. Create that folder on your C: Drive and run the Titan Quest demo again and this should fix the problem. You can change the Reg key back to what it was before.
Having issues with all text being gone and replaced with "SimpleStringTag not Found"?
* Solution:
* This may occur if you are installing the game on a Windows OS that is not in English. To fix this, enter the Titan Quest\Settings folder and open the defaults.txt file. Once there, add or edit the line to read "language = English" to the bottom of the file. Also, in My Documents\My Games\Titan Quest Demo\Settings edit the options.txt file with the same line "language = English" and save this as well. This should make the text appear in English and then you can manually change the language when you are in the game.
הרגע התחלתי להוריד את הדמו, רשמים בקרוב :jump:
שיחקתי בדמו ודי היתאכזבתי ציפיתי ליותר
פשוט כאב לדעת שאין DIABLO 3 :\ !!! :'(
יותר מאיזה בחינה? הדמו מוגבל מאוד בכוונה. (למשל אפשר להגיע רק לדרגה 6 ויש רק שני SKILLS שאפשר לבחור)
נראה נחמד מאד :-*
יש מה לעשות באמצע החופש :P
מה זה בעצם המשחק הזה? על מה הוא מדבר? איזה סוג משחק?
דרישות מערכת מטורפות :-X
אלה הדרישות המומלצות, לא המינימום.
שיחקתי חצי שעה ואהבתי.
עדיין לא מצאתי איך אפשר לשנות את הזוית מצלמה (אפשרי?) והפונט טיפה מעצבן + אבל המשחק עצמו מגניב!
יש המון שינויים קטנים שאוהבי דיאבלו ישמחו לראות.
לדוגמא כאשר אתה מצביע על חפץ בתיק שלך נפתח חלון קטן שמשווה את החפץ לזה שכרגע נמצא על הדמות.
עוד דבר זה שאם אתה פותח town portal אז אתה יכול לבחור לאיזה עיר לעבור ולא רק לקרובה ביותר. (ממש כמו שימוש בway point)
כרגע אני מתמקד בקשתות + קסמי אדמה מה שמוסיף אש לחיצים שלי. :smile1:
אחד מהאפקטים שאהבתי זה שאם אתה עובר בשדה אז הצמחים זזים כאשר אתה דורך עליהם.
עריכה:
טוב, סיימתי את הדמו.
יש כמה דברים שמציקים אבל הם בטח יסדרו אותם בפאץ. (כמו למשל שהערך של חפצים מופיע רק במסך של סוחרים אז קשה לדעת מה לשמור ומה לזרוק)
בסך הכל התרשמתי מאוד.
אין זמני/מסכי טעינה, והמשחק עובד חלק אפילו אצלי. (6600GT)
עריכה 2:
LOL, קבלו:
The members of the development team told us of stories where bodies would hurl through the air and land in the branches of trees, or go splat against the face of a mountain, only to slide slowly down. You can also use the physics engine to knock opponents off edges and cliffs, which will quickly become something of a sport, we're told.
מישהו הצליח לגלות האם המפה במשחק מולטי תהיה רנדומלית או אותה מפה כמו בשחקן יחיד?
משחק מדהיייייםםםםם
נראה לי בשבילו אני הולך לשדרג תמחשב שלי
דיאבלו היה החוויה הכי גדולה שעברתי במשחקי מחשב,זה היה משחק מושלם,ואני מקווה שזה ירוש את מקומו....
מגניב!!!!
המשחק הזה תומך בכרטיס creative sound blaster x-fi
המשחק הציג המון המון טקסטורות פגומות עבורי, והכרטיס שלי הוא 6600gt. אני מאוד מקווה שיתקנו את זה במלא כי זה נראה מבטיח
בא לי לנסות גם אבל אני חושב שאני יבזבז את הזמן שלי כי המעבד שלי הוא חרא
אם רק היה לי נורתווד.......
אני היחיד שלא רואה תוכן כתב בכלל בכלל?
כל המשחק הוא ככה כמו שלמטה
כנ"ל הנשקים כנ"ל הכל
אני לא יכול לקרוא מה כל סקיל נותן מה נשק מוריד שום דבר....
[attachment deleted by admin]
אולי תקרא את הציטוט המודגש בהודעה הראשונה בדיון הזה? :s07:
parker, על מה אתה מדבר? אצלי לא נתקלתי בשום בעיה כזו.
יש מצב שיש לך OC לכרטיס?
חחחחח
הכי מצחיק זה שמצאתי את זה אחרי חיפושים בפורום אחר אחרי שזה היה מתחת לאף שלי פפפפ
שטויות
תודה בכל מקרה :-*
טוב-סיימתי את הדמו
משחק גדול
