Stuck in OC... any suggestions?
I played a little with my dual-core 4200+ and got to 2750MHZ.
I tried to raise it but didn't succeed. The situation so far:
2750MHZ @ v1.648
Multiplier: X11
FSB: 250
HTT: X4
Memory timings: 2.5-3-3-7 @ v2.7
I tried to play with the FSB and the multipliers but couldn't get stability @ 2800 :s07:
Any suggestions on how to continue?
Thanks.
I think you need to download the HTT to X3...
:xyxthumbs:
איזה זכרונות יש לך?
G.Skill LA
:xyxthumbs:
I tried that when I put the multiplier on X10 and the fsb on 280... I gave more voltage to the memory (2.7 and then 2.8 ). tried to relese the timings of the memory to 2.5-4-4-8 and still wasn't stable. perhaps that was the wrong move?
Anyway, even tried to give more voltage to the cpu but the voltage wasn't stable and my computer reset... i guess it was because of my lousy PSU (which I'm about to replace) but eventually nothing worked... perhaps I should try and give voltage to other things that I don't usually do?
You can gave more Voltage to thr chipset ?!
If do you want to do that you acsully need to search MOD's for your MotherBoard...
:xyxthumbs:
:xyxthumbs:
I can give more voltage to the chipst. Will that be helpful?
הלוח הוא לא הבעיה פה, כניראה שהגעת לגבול של המעבד..
are you sure? :'(
no chance it can give just a bit more?
מממ.. הלוח הוא לא הבעיה, בקשר לזכרונות אני לא בטוח, הם אמורים להיות OCRים טובים, אתה יכול לנסות לשנות את היחס, לא בטוח שזה יעזור.
בכל מקרה, יש לך GTX וקיבלת רק 6300ב 3DMARK05?
That's the PCMark05 score...
I got 8722 on 3DMark05
By the way, is there any software that can OC my 7800GTX because in it's menu there is no such option?
חחחחח נמאס לי מהאנגלית... ;)
העלאת מתח לצ'יפסט יכולה לעזור לעלות עוד ...
תעלה לאט לאט, כל פעם בדיקת יציבות בSuper Pi על 16 MB...
:xyxthumbs:
:xyxthumbs:
lol sorry about that it's just that my cd-rom isn't working (which is a thread of itself that didn't help me at all... :s05:) so I can't install the hebrew from the Windows XP cd...
I'll try and give some voltage to the chipset but do you think I should stay with the current multiplier/fsb or should I try to use to configuration of 10*280?
כנראה שהגעת לגבול של המעבד ידידי...
How sad... well he sure is a good OCer anyway...
I'll still love him like he is my own son :D
:xyxthumbs:
