מסכי LCD מומלצים + סקירת מושגים. נושא מרוכז, כל השאלות/תשובות בדיון הזה בלבד.
ל-q1234:
תראה בגדלים האלה מומלצים הדגמים הבאים:
Dell UltraSharp 2005FPW
Dell UltraSharp 2405FPW
במיוחד לסרטים.
לינק לביקורת:
http://www.tomshardware.com/2005/08/30/all/page13.html
ו-
http://www.tomshardware.com/2005/07/06/nec_and_lacie_lead_on_professional_lcd_gear/page18.html
וכאן אתה יכול לראות איך המסך באמת נראה במצבים שונים: (תשחק עם תיבה 3)
http://www.lesnumeriques.com/duels.php?ty=6&ma1=52&mo1=82&p1=856&ma2=119&mo2=59&p2=680&ph=3
לגבי איזה פאנל:
http://www.flatpanels.dk/panels.php
  • תגובות 1.3k
  • צפיות 155.5k
wow , הנק טוב משמעותית מכל המסכים שם , בהשוואה , אני צודק ?
לגבי Dell 2001 FP:
Dell 2001FP has a 20 inch 16 ms S-IPS (LG.Philips LM201U04) panel
Video isn't this monitor's strong point either. The nominal 16 ms latency we observed when fully optimized doesn't prevent some lags during video playback. The colors are bright, but not always entirely accurate. Ditto again for video games. It's not the fastest monitor in the galaxy and that disqualifies it. Furthermore, the interpolation is frankly a setback. The monitor is enough for a limited knock about between workmates, but not for an intensive game. Of course, it wasn't designed for that. For office use, the panel is impeccable; the swivel is very practical, and it's easy to find a comfortable working position. Viewing angles are wide enough to remove the need for precise tilting of the panel. Text is clear, but I'd recommend using a DVI connection for anything digital.
יותר טוב לגבי סרטים ומשחקים לא יותר מדי מהירים. אחלה לאופיס.
לגבי Dell 2405FPW:
Dell 2405FPW (widescreen) has a 24 inch 12 ms (g2g) PVA (Samsung LTM240M1-L01) panel
The monitor's higher native resolution would very comfortably support the display of two pages of text side by side. Unfortunately, brightness is too strong for the office. It may seem a bit crazy, but a more economical solution could be to buy two monitors - a 17" and a 19"! This arrangement would support office applications and still be suitable for CAD. Video noise while watching DVDs is strongly evident. This is a shame, because the format of the screen would be perfect for this application. Forget it, though - there is definitely too much video noise and, in addition, viewing angles aren't suitable. Games are clearly not this monitor's strength, either; it's too slow, and the monitor displays annoying lags. Worst of all, moving images lose sharpness in their textures.
זאת אומרת הוא מתאים רק לצלמי סטילס וגרפיקאים. לא מתאים כל כך לסרטים בגלל "רעש" וזויות צפייה. ממש לא מתאים למשחקים ולסרטים. אפילו לאופיס הוא לא מתאים הם ממליצים לקנות בפחות כסף שני מסכי 17 או 19 אינץ'!.
לגבי LaCie 321:
LaCie 321 has a 21 inch 20 ms SA-SFT (NEC NL160120BC27-02) panel.
ו- NEC 2180UX:
NEC LCD2180UX has a 21 inch 20 ms SA-SFT (NEC NL160120BC27-02) panel
הם מסכים תאומים (אותם נתונים פחות או יותר) משני חברות שונות:
for the office; it's a bit too good, really. Still, for images such as components of a document, this screen shows itself to be really sharp. Text is rendered legibly, with no particular problems either in VGA or DVI. Video is possible on this product, even though it's not really what it was designed for - with a latency of up to 33 ms, that's understandable. But except for a few long trails in fast panning, we can say that overall the level of video noise was low. Still, in the end, video isn't this model's strength. The display is slow and the only option to improve it is to move down a step in resolution. In the same vein, take note if you're a gamer and you're tempted by this product; you could probably stretch to the latest Nvidia offering, or even an Alienware console, and play in native resolution mode, so why not...?
מעולה לצלמי סטילס וגרפיקאים. טוב גם באופיס. ממש לא למשחקים (33ms) זה המון!. אפשר לראות, סרטים.
המסקנה הסופית היא:
choosing the best monitor depends entirely on your application - as is always the case. We award two Editor's Choice awards to the NEC and LaCie
מדבר בעד עצמו!
אם שמת לב חוץ מה-Dell 2405FPW וה-Dell 2405FPW כל הפאנלים הם של IPS ו-SFT (זה כמו IPS) וכמו שכתוב בעמוד הראשון: IPS - הפנל היקר ביותר מבין השלושה והכי פחות נפוץ בגדלי ה- 17-19 אינץ'. הפאנל מציג כמות גדולה יותר של צבעים מ-TN וזוויות צפייה מאד רחבות (כמעט 180 מעלות). החיסרון הוא שזמני התגובה בפנל הנ"ל בדרך כלל גבוהים והוא איננו מיועד למשחקים וסרטים. ולכן המלצתי לך על שני דגמים אלו בהנחה שהשימוש הוא בעיקר לסרטים. אני הייתי קונה במקומך את ה-ViewSonic VP930B. לינק לביקורת:
http://www.tomshardware.com/2005/11/17/viewsonic_vp930_lcd_monitor/page5.html
ו- http://www.tomshardware.com/2005/11/17/viewsonic_vp930_lcd_monitor/page6.html
תודה רבה רבה !
בחירה קשה מאוד.
בקישור שהבאת לי דובר על מסך של nec , מדגם 2170nx , שהציג ביצועים הכי טובים אבל בכלל לא דיברת עליו עוד (דיברת רק על 2180ux).
יש לו פחות מריחות מה-930b.
בנתיים האופציה הטובה ביותר נראית לי ה-2170nx או שאני אחכה למסך של dell , ש-iceBreak נתן לי אליו קישור :
http://www1.us.dell.com/content/topics/topic.aspx/global/products/monitors/topics/en/monitor_3007wfp?c=us&l=en&s=gen
המסך משתמש בפנאל שאפל משתמשים למסכי ה- CINEMA DISPLAY, השאלה אם יש לו יתרון על ips (אני עוד תקוע למזלי עם ההיידיס הישן והטוב).
מצד אחד אני רוצה מסך עם איכות תמונה מעולה , אבל רוצה לראות פה ושם סרטים כמו בן אדם , שהתמונה תהיה חדה ומציאותית ופה ושם לשחק במחשב.
שוב תודה רבה ! :)
הלינק מדבר על NEC 2180UX! והנה הוא שוב:
http://www.tomshardware.com/2005/07/06/nec_and_lacie_lead_on_professional_lcd_gear/page7.html
ושוב הוא ממש לא מתאים למשחקים. NEC טוענים ל-20ms עם אובר-דרייב, אבל בביקורת הם מדדו 33ms בלי אובר-דרייב כיוון שאין להם את הציוד לבדוק זאת. השאלה אם אתה סומך על היצרן. אולי יש ביקורות שכן בדקו עם אובר-דרייב.
הוא באמת נראה הכי טוב.
לדעתי אין כמו מראה עיניים: ללכת לחנות עם משחק הכי מהיר שאתה משחק בו ולראות בעצמך.
מהביקורת הזאת נראה שה- Dell 2001 FP הכי מתאים לצרכים שלך.
למרות שבמקום אחר ממליצים על 2405FPW (שים לב יש לו 24 אינץ' שזו תוספת למחיר) לסרטים.
לגבי אפל קבל לינק:
http://www.tomshardware.com/2005/08/30/all/page5.html
ו- http://www.tomshardware.com/2005/08/30/all/page13.html
ושוב אני חוזרת: אני הייתי קונה במקומך את ה-ViewSonic VP930B, למרות שהוא רק 19 אינץ'. תזכור שמסך רגיל (CRT) של 19 אינץ' הרבה יותר קטן ממסך LCD של 19 אינץ'. יש את הלינק לביקורת מהללת למעלה.
הוא היחיד שעונה על כל הצרכים שלך!
פה מדובר על 2170nx,שפשוט מכסח את כל שאר המסכים.
האם אחד מהמסכים שהמלצת לי עליו מציג 16.7 מליון צבעים באמת ?
אני חושב שאני נוטה לכיוון של מסך איכותי יותר מאשר ביצועיסט במשחקים לכן אני שוקל את ה-nec .
החברה lacie היא מוכרת ? יש לה מוניטין ? כי בחיים שלי לא שמעתי עלייה.
תודה רבה על כל העזרה. :)
מצורפת שאלה, שפורסמה לא במקום הנכון, מקווה שעכשיו המיקום תקין
בהמשך לחיפושים אחר מסך LCD רחב, קצת התקררתי בנוגע למסכי "24 ופניתי יותר לכיוון של "20.
שני מסכים עיקריים עלו בחכתי :
Viewsonic vp2030b
או Dell 2005FPW
האם יש עוד מסך, במחיר דומה, שאפשר לכוון אליו ?
ואם בכל זאת יהיה מצב ל-"24,יש מספר דגמים אפשריים Viewsonic vp2330wb, Eizo S410w וגם יש ל-Dell את ה-2405FPW.. - שני הראשונים אמורים לצאת לשוק בקרוב, והמסך של Dell כבר ניתן לרכישה. האם ההבדל בשטח התצוגה ו/או תכונות אחרות שווה את ההפרש, הממש לא קטן, במחיר ?
אשמח לשמוע דיעות נוספות לגבי כל ההתלבטויות, בעיקר מבעלי נסיון שימוש במסכים אלו
פה מדובר על 2170nx,שפשוט מכסח את כל שאר המסכים. האם אחד מהמסכים שהמלצת לי עליו מציג 16.7 מליון צבעים באמת ? אני חושב שאני נוטה לכיוון של מסך איכותי יותר מאשר ביצועיסט במשחקים לכן אני שוקל את ה-nec. החברה lacie היא מוכרת ? יש לה מוניטין ? כי בחיים שלי לא שמעתי עלייה. תודה רבה על כל העזרה.
בלינק אתה רואה את הדגם:
NEC LCD2170NX has a 21 inch 8 ms (g2g) S-PVA (Samsung LTM213U6) panel
שהוא האופציה היחידה שם ל-21 אינץ'. אבל יש לו 8 ms לעומת 80UX:
ופאנל אחר לגמרי.
עוד ביקורת מאתר אחר על 21 אינץ':
http://www.xbitlabs.com/articles/other/display/20inch.html
הלינק הוא לתוכן העניינים לפי דגם.
מצאתי לינק למישהו שקנה את ה-DELL (מהפורום הזה):
http://hwzone.co.il/community/index.php?topic=121618.0
ו- http://hwzone.co.il/community/index.php?topic=123124.0
אוף. עד שסוף סוף החלטתי איזה מסך אני רוצה (EIZO 1910/AS)...
ועד שסוף סוף התקשרתי ל"ניר טק" כדי להזמין אותו... התבאסתי לגלות שלא רק שאין כרגע את המסך בצבע שאני רוצה (רציתי לבן.. ויש רק באפור).. שזה לא כל כך נורא...
גם אין להם את ה"רגלית" של המסך שרציתי (ה-ARCSWING, הרגלית הקשתית.. ללא הפיווט)...
מי שמכיר את המסך בגירסא הזו יכול לומר אם הוא נראה טוב גם באפור?
איך הפונקציונליות של הרגלית הלא קשתית? גם איתה אפשר לכוון את המסך בכזו גמישות? (אין לי צורך בפיווט)...
האם היא נראית פחות טוב משמעותית לעומת הרגלית הקשתית?
במידה ואקנה מהם את המסך.. אני אוכל בעתיד (או אפילו עכשיו) לקנות בנפרד רק את הרגלית הקשתית? הם אמרו שהם לא מוכרים אותה בנפרד... מישהו יודע איפה כן אפשר למצוא בנפרד?
יש למישהו את מס' הטלפון של היבואן של EIZO.. על מנת לברר מולם ישירות?
מישהו יודע אם אפשר להשיג בארץ את הגירסה שאני כן מחפש?
המון תודה,
דודי.
גם אני רוצה לקנות אותו!
למישהוא יש את ה- Eizo S1910?
אבל אני עדיין מתלבטת בין ה- ViewSonic VP930B ל- Eizo S1910.
אני צריכה מסך מחשב בעיקר לסרטים ואופיס ולא משחקים.
בקשר ל-NEC והפאנל שלו:
The panel manufacturers LG-Philips and Nec, are the last two big supporters of IPS. Unfortunately for them, this technology is slowing down since the release of fast VA panels. Not so long ago, all 23" monitors and above, in addition to 20"s were all in IPS. This time is over and little by little, all monitor producers turn either to AU Optronics´ MVAs or Samsung´s PVAs. Even graphic designer monitor manufacturer are following suit as we see with Eizo and now LaCie. Only NEC resists. LG continues and, despite the fact that they are fewer and fewer, keeps those faithful users, who think that IPS are the best, even if this is sometimes hard to justify.
DELL:
ז"א, מי שרוצה גם לראות סרטים על המחשב - בנתיים אין מה לחפש במסכי 20-24 ?
וזה כולל גם הערכות לגבי החדשים של Viewsonic ו-Eizo ?
בלית ברירה.. החלטתי להזמין את הEIZO 1910 בלי רגלית הARCSWING... (חיפשתי וחיפשתי.. וגם אצל היבואן אין... רק אם אני אזמין במיוחד.. וייקח לזה חודש להגיע...)
היא קצת פחות גמישה בכיוונון אבל עדיין ניתן לכוון אותה כמו שצריך... וגם נראית קצת פחות טוב בעיניי מרגלית ה-AS...
לפחות יהיה לי פיווט...
כשהוא יגיע אני אכתוב עליו את התרשמותי :)
דודי.
איך ה Samsung 913N לעומת 930B?
לפי מה שקראתי ה 913N קיבל ביקורות מרשימות(למרות שאין לו DVI)
