איך להתקין חייגן כבלים ב UBUNTU
אני חדש לגמרי בעניני לינוקס ולא יודע איך להתקין חייגן כבלים ב UBUNTU. אם הדבר כרוך בהתקנת תוכנה - אנא הפנו אותח=י למקום בו ניתן ללמוד להתקין תוכנות בלינוקס.
לא צריך להתקין כלום (בד"כ)
אני משתמש בסקריפט הבא, ישנם הרבה סקריפטים - זה רק אחד מהם.
#!/usr/bin/env python
import popen2;
import re;
import sys;
import time;
import os;
# class: ConnDB: stores various information about providers, nameservers, servers and
# their names.
class ConnDB:
def __init__(self):
#con tuple: nameserver1, nameserver2, remotename, name
self._cons = [];
#0 012.net - aztv
self._cons.append(("212.117.129.3","212.117.128.6","aztv.012.net.il","012.net -aztv"));
#1 012.net
self._cons.append(("212.117.129.3","212.117.128.6","cablepns.012.net.il","012.net"));
#2 actcom
self._cons.append(("192.114.47.4","192.114.47.52","192.117.122.13","actcom"));
#3 aquanet
self._cons.append(("192.117.240.10","192.117.240.3","cable.aquanet.co.il","aquanet"));
#4 barak
self._cons.append(("212.150.48.169","206.49.94.234","pns.barak.net.il","barak"))
#5 bezeqint
self._cons.append(("192.115.106.35","62.219.186.7","matav.bezeqint.net","bezeqint"))
#6 huji
self._cons.append(("128.139.6.1","128.139.4.3","vpn.huji.ac.il","huji"))
#7 israserv
self._cons.append(("192.115.0.100","192.115.3.100","192.117.195.250","israserv"))
#8 netvision
self._cons.append(("194.90.1.5","212.143.212.143","cable.netvision.net.il","netvision"))
#9 technion
self._cons.append(("132.68.1.2","132.68.1.9","ccdis3.technion.ac.il","technion"))
#10 zahav
self._cons.append(("192.116.202.222","192.116.192.9","pns.inter.net.il","zahav"))
#number of connections
self._numofcons = self._cons.__len__();
def getNumOfConnections(self):
return self._numofcons;
def getProviders(self):
return self._cons;
# class: Connection: starts the pptp connection
class Connection:
def __init__(self):
self.nameserver1 = ""
self.nameserver2 = ""
self.password = ""
self.username = ""
self.server = ""
self.pptp = "";
self.eth = ""
self.gateway = "";
self.newGateway = "";
self.dhcpClient = "";
self.dhcpClientPath = "";
self.msglen = 48;
def initiate(self, ns1, ns2, server, password, username, ethernet, dhcpClient, dhcpClientPath, pptpclient):
self.nameserver1 = ns1;
self.nameserver2 = ns2;
self.password = password;
self.username = username;
self.server = server;
self.pptp = pptpclient;
self.eth = ethernet;
self.gateway = "";
self.dhcpClient = dhcpClient;
self.dhcpClientPath = dhcpClientPath;
def connect(self):
self.clean();
self.writeResolve();
self.writeSecrets();
self.getGateway();
self.addRoute();
self.startPPTP();
self.getNewGateway();
self.deleteOldSetNewRoute();
# self.shareInternet();
def writeResolve(self):
self.msg("Writing resolv.conf");
resolveFile = open('/etc/resolv.conf','w');
resolveFile.write("nameserver " + self.nameserver1 + '\n');
resolveFile.write("nameserver " + self.nameserver2 + '\n');
resolveFile.close();
def writeSecrets(self):
self.msg("Writing pap-secrets");
papSecretsFile = open('/etc/ppp/pap-secrets','w');
papSecretsFile.write('"' + self.username + '" * "'+self.password + '"\n');
papSecretsFile.close();
chapSecretsFile = open('/etc/ppp/chap-secrets','w');
chapSecretsFile.write('"' + self.username + '" * "' + self.password + '"\n');
chapSecretsFile.close();
def clean(self):
self.execute("rm -rf /var/run/pp*");
self.msg("Cleaning ... ");
self.execute("killall -9 pptp");
self.execute("killall -9 pptp-linux");
self.execute("killall -9 dhclient");
self.execute("killall -9 dhcpcd");
self.execute("killall -9 pump");
self.execute("modprobe usbnet");
self.execute("modprobe CDCEther");
self.execute("ifconfig " + self.eth + " down");
self.execute("rm -rf /etc/dhcpc/dhcpcd-" + self.eth + ".pid");
def getGatewayFromDhcpcd(self):
self.execute("dhcpcd " + self.eth, 3); #was 2
dhcpcdInfoFile = open("/etc/dhcpc/dhcpcd-" + self.eth + ".info","r");
gateMatch = 0;
while not gateMatch:
line = dhcpcdInfoFile.readline();
gateMatch = re.match("GATEWAY=.*",line);
if not line:
self.errorMsg("parsing error");
if gateMatch:
str = gateMatch.group(0);
self.gateway = re.split("=",str)[1];
dhcpcdInfoFile.close();
def getGatewayFromDhclient(self):
self.msg("executing " + self.dhcpClientPath + " " + self.eth);
self.execute(self.dhcpClientPath+" "+self.eth,3); #was 2
if os.access("/var/lib/dhcp/dhclient.leases",os.R_OK):
(stout, stin) = popen2.popen2('grep routers /var/lib/dhcp/dhclient.leases | tail -n 1 | cut -d ";" -f1 | cut -d " " -f5');
elif os.access("/var/lib/dhcp3/dhclient.leases",os.R_OK):
(stout, stin) = popen2.popen2('grep routers /var/lib/dhcp3/dhclient.leases | tail -n 1 | cut -d ";" -f1 | cut -d " " -f5');
self.gateway = stout.read()[:-1];
def getGateway(self):
self.msg("Getting gateway:");
if (self.dhcpClient == "dhcpcd"):
self.getGatewayFromDhcpcd();
elif (self.dhcpClient == "dhclient"):
self.getGatewayFromDhclient();
self.msg("Found Gateway: " + self.gateway);
def addRoute(self):
self.msg("Adding Route:");
self.execute("/sbin/route add -host " + self.server + " gw " + self.gateway + " dev " + self.eth, 3); #was 2
def startPPTP(self):
self.msg("Starting pptp");
popen2.Popen3(self.pptp+" "+ self.server + " user "+self.username+" debug remotename "+self.server+" mtu 1452 mru 1452 noauth defaultroute").wait();
i = 0;
while True:
(stout, stin) = popen2.popen2("netstat -n -r | grep ppp0");
if (stout.readline()):
self.msg("Connected!");
break;
i = i+1;
print "--- connecting.... ---";
time.sleep(1);
if (i == 20):
self.errorMsg("Failed to Connect");
def getNewGateway(self):
(stout, stin) = popen2.popen2('/sbin/ifconfig ppp0 | grep inet | cut -d":" -f3 | tail -1 | cut -d" " -f1');
self.newGateway = stout.read()[:-1]; #remove the trailing \n
self.msg("New Gateway: " + self.newGateway);
def deleteOldSetNewRoute(self):
self.msg("Fixing Gateway");
self.execute("/sbin/route del default dev " + self.eth);
self.execute("/sbin/route add default gw " + self.newGateway);
def shareInternet(self):
self.msg("Sharing Internet");
self.execute('iptables -t nat -A POSTROUTING -o ppp0 -j MASQUERADE');
self.execute('echo "1" > /proc/sys/net/ipv4/ip_forward');
self.execute('ifconfig eth1 192.168.0.1 netmask 255.255.255.0 broadcast 192.168.0.1');
def errorMsg(self,m):
print "Error: ",m," \n";
sys.exit(0);
def execute(self, cmd, flag = 3):
popen2.Popen3(cmd,True).wait();
def msg(self,m):
print "++++++++ ",m," "*(self.msglen-m.__len__()),"++++++++\n";
# class: CableInternet: detects the pptp client, dhcp client and gets the user information
# welcome(): print a welcome message to the screen
# saveUserInfo(): save the information about providers and username/password into a
# .cablecon configuration file.
# getUserInfo(): gets the infromation needed for connection from the user
# detectDhcpcd(): checks whether a Dhcpcd client exists in the path. Returns 0 if does.
# detectDhclient(): checks whether a Dhclient exists in the path. Returns 0 if does.
# detectDHCPClient(): Goes over the dhcpc client detectors in some order and stops when
# found one that exists in the path.
class CableInternet:
def __init__(self):
self.condata = ConnDB();
self.provider = 0;
self.username = "";
self.password = "";
self.ethernet = "eth0";
self.cons = self.condata.getProviders();
self.pptp = "";
self.msglen = 48;
def welcome(self):
print "*********************************************************************\n";
print "***** Welcome to the Cable Internet Connection wizard ************\n";
def saveUserInfo(self):
confFile = open('/etc/cablecon','w');
confFile.write(str(self.provider)+"\n");
confFile.write(self.password+"\n");
confFile.write(self.username+"\n");
confFile.write(self.ethernet+"\n");
confFile.close();
def getUserInfo(self):
i = 0;
N = self.condata.getNumOfConnections();
while i < N:
print i,") ",self.cons[3];
i = i+1;
try:
self.provider = int(raw_input("Enter the number near your provier:\n"));
except:
self.errorMsg("Next time try to be more accurate");
self.username = raw_input("Enter your username: ");
self.password = raw_input("Enter your password: ");
print "0) eth0 \n1) eth1";
try:
self.ethernet = "eth" + raw_input("Enter your ethernet (default = eth0): eth");
except:
ans = raw_input("Do you want to save these changes? [y,N]:");
if (ans.lower()[0] == 'y' ):
self.saveUserInfo();
def detectDhcpcd(self):
(stout, stin) = popen2.popen2("which dhcpcd");
self.dhcpClientPath = stout.read()[:-1];
if (self.dhcpClientPath):
self.dhcpClient = "dhcpcd";
self.msg("Detected: dhcpcd");
return 1;
return 0;
def detectDhclient(self):
(stout, stin) = popen2.popen2("which dhclient");
self. dhcpClientPath = stout.read()[:-1];
self.dhcpClient = "dhclient";
self.msg("Detected: dhclient");
return 1;
return 0;
def detectDHCPClient(self):
self.msg("Detecting DHCP client");
if not(self.detectDhcpcd() or self.detectDhclient()):
self.errorMsg("Couldn't detect any dhcp client");
def detectPPTP(self):
(stout,stin,sterr) = popen2.popen3("which pptp");
self.msg("Find what pptp do you use");
self.pptp = stout.read();
self.pptp = re.split("\n",self.pptp)[0];
if (self.pptp):
self.msg("Found pptp: " + self.pptp);
return 1;
return 0;
def detectPPTPLinux(self):
(stout,stin) = popen2.popen2("which pptp-linux")
if (self.pptp):
return 1;
return 0;
def detectPPTPClient(self):
if not(self.detectPPTP() or self.detectPPTPLinux()):
self.errorMsg("error, couldn't find pptp client");
def getFileInfo(self):
confFile = open('/etc/cablecon','r');
self.provider = int(confFile.readline()[:-1]);
self.password = confFile.readline()[:-1];
self.username = confFile.readline()[:-1];
self.ethernet = confFile.readline()[:-1];
confFile.close();
def connect(self):
self.welcome();
self.detectDHCPClient();
self.detectPPTPClient();
if os.access("/etc/cablecon",os.R_OK):
self.getFileInfo();
else:
self.getUserInfo();
con = Connection();
con.initiate(self.cons[self.provider][0],self.cons[self.provider][1],self.cons[self.provider][2],\
self.password, self.username, self.ethernet, self.dhcpClient, self.dhcpClientPath,\
self.pptp);
con.connect();
sys.exit(0);
def msg(self,m):
print "++++++++ ",m," "*(self.msglen-m.__len__()), "++++++++\n";
c = CableInternet();
c.connect();
המלצה, לא לשמור שינויים עד שהצלחת להתחבר כמו שצריך.
פקודות הרצה -
sudo python filename.py
מטי.
ה SCRIPT הזה מתאים גם ל L2TP ?.
לא , pptp בלבד.
אם היית מציין מראש שזה מה שאתה צריך....
מטי.
