Amd 3500$ - i am in the end and you stoped help me please get in
THE SATA2 COST 10 SHEKEL MORE THAN SATA1
BUT IT WONT GIVE U ANY BIG IMPROVEMENT 4 NOW
I THINK U SHOULD TAKE 3700 SAN DIEGO 2 GIGA OF REGULARY MEMOREY BEACAUSE I THINK 2 GIGA DDR 400 NORMAL MEMOREY IS BETTER THAN 1 GIGA MEMOREY 4 OC .
ABOUT THE MONITOR-IN SUCH BIG BUDGET U MUST TAKE 19" GOOD LCD SCREEN
CRT IS GOOD FOR GAMES MAYBE, BUT AS FAR AS EVERYTHING ELSE ITS A BETTER CHOICE.
i have an LCD in my home i am not really love him i cant improve his hz it is allways on 75
  • תגובות 75
  • צפיות 6.5k
eveman why do u think that 2 giga ddr400 well be better than giga for oc
128mb 433mhz in thiori should be better in oc from 2 giga ddr 400
the size not play in oc. the quality is matter.
Bose and eveman , I dont think  that I need 2GG memory I wont feel it , like I am know there is no games that must 2gb memory and I think that 1gb will be the best option for me
what do you say ?
Refresh rates don't mean anything in LCDs, that's not the way to compare them with CRTs
And IMO 2GB with a divider will give better results than 1GB overclocked, once you start maxing out the 7800GTX's filters. With a pair of PC4000 Ballistix, you probably wouldn't need a divider
And obviously a smaller amount of memory would overclock better, but at the expense of alot of performance where large amounts of memory are needed
about the video cards I am not sure that I am take them I thought about 6800GTx2 and to make it dual is it not better then the 7800GTX?
One 7800GTX would give better performance AND image quality
(it will also consume much less power, and should even overclock better)
mike i think you know what parts you need
build the computer from her after you finish press print and copy the the pc to the forum and we tell you want we think and what to cange
http://www.logicpc.co.il/eng/buildpc.aspx?Build=amd
Ok so I make my choice about the video card too
AMD Athlon 64 3700 (939-pin) Box San Diego
Mushkin 1GB 2x512MB XP4000 2-2-2 Redline
DFI LAN PARTY NF4 SLI-DR
Westren Digital SATA 36.7GB 10000 RPM
Westren Digital 160Gb SATA II
7800GTX
But I dont know which chipset to take I know that in the end are all the same but if some one knows something better then
something or what the best chipset is so I will really  -I prefer something that it PCI e-  thanks him
Sorry I wasnt concentrate and I wanted to say about the video card not about the memory
In chipsets do you mean memory? I would take TCCD rather than BH-5
No sorry I wasnt concentrate and I wanted to say about the video card not about the memory
There are some good performance comparisons
here, here and here.
Notice the performance in high resolutions and image quality.
Ok I sorry I see that u didn't understand me
I mean what company of the video card is the best on the 7800 ?
Well, from the brands that are available in Israel I would prefer Leadtek's card. It comes with a good overclock and the reference cooling (So far all manufacturers are still using reference cooling, they didn't have enough time to come up with anything else)
wow thank you bose , i am watching it..
Ok till now I am standing on 10,572 shekels and I didnt choice a Monitor case and power supplies and about the case I am need something small but with high performance that will be the best for the computer that I took if someone not updating so I put it here
GigaByte nVidia GeForce 7800 GTX 256MB GV-NX78X256V-B
OCZ 1GB (2x512MB) EL DDR PC3200 DualChannel Platinum Rev 2
Asus DVD x 16 Silver
NEC ND-3540A Dual Layer DVD±R/W/DL 16X Silver Bulk
