Amd 3500$ - i am in the end and you stoped help me please get in
My offer -
AMD Athlon 64 939 3700 San Diego core 2180 ¤
DFI LANPARTY UT nF4 Ultra-D 920 ¤
G.Skill DDR 550MHZ EXTREME PC4400 TCCD 1024MB DUAL CHANNEL F1-3200DSU2-1GBLE 1850 ¤
WD 250GB 7200RPM 16MB SATAII 975 ¤
LEADTEK WinFast PX7800GTX TDH MyVIVO 256MB 256BIT 3770 ¤
NEC ND-3540A Dual Layer DVD±R/W/DL 16X 350 ¤
Antec SUPER LANBOY Aluminum 590 ¤
OCZ PS 520W ATX POWERSTREAM 845 ¤
VIEWSONIC VP191s 3895 ¤
THERMALTAKE BIGTYPHOON 240 ¤
Total - ¤ 15615
* I would consider taking 2x1GB of PC4000 Crucial ballistix instead of the GSkills, it wouldn't give the same overclocks, but it will let you play with high filters much more smoothly
  • תגובות 75
  • צפיות 6.5k
HERE YOU GO, A MONSTER:
שם מוצר כמות מחיר סופי
Coolermaster STC-T01 Stacker P/S Not Included Case  1 999 ¤
NEC ND-3540 Black 16/8/4//48/24/48 Bulk DVD±R/RW  1 319 ¤
AMD Athlon 64 3700 San-Diego Socket 939 BOX  1 2249 ¤
Thermalright XP-120  1 309 ¤
LG 16/48 Bulk Black DVD-ROM  1 149 ¤
Citizen/Sony/Alps Black 1.44MB 3,5" FDD  1 55 ¤
Seagate 250GB 7200 rpm 8MB Buffer NCQ Serial ATA HDD  1 839 ¤
Western Digital Raptor 36.7GB 10000 rpm Serial ATA HDD  1 629 ¤
DFI LanParty NF4 SLI-DR nForce 4 Ultra 939 Motherboard  1 1339 ¤
OCZ 512Mb DDR400 CL-2-3-2-5 EL Platinum memory  2 1718 ¤
19" Viewsonic G90F+B Black Flat Monitor  1 1579 ¤
Antec TruePower 480W V2.0 120mm + SATA + 24pin Power Supply  1 739 ¤
Computer Assembly  1 160 ¤
Gainward Geforce 7800GTX Ultra/ 3500PCX 256MB DVI Video Card  1 3489 ¤
סה''כ: 15 14572 ¤
:o
I dont need this crazy computer I need something simpler but the video card looks to me I got him in my house and I really love him
Ok Mcfly its looks good but I heard that OCZ better to DFI so you are not say that I should take OCZ?
Another Option:
דגם מחיר כמות
AMD Athlon 64 X2 Dual-Core processor 4400+(2.2GHz) BOX 4400 ¤ 1
DFI LANPARTY UT nF4 SLI-D 1200 ¤ 1
G.Skill DDR 550MHZ EXTREME PC4400 TCCD 1024MB DUAL CHANNEL F1-3200DSU2-1GBLE 1850 ¤ 1
WD 160GB 7200RPM 8MB SATAII 580 ¤ 1
WD 36/10000 SATA RAPTOR 640 ¤ 1
LEADTEK WinFast PX7800GTX TDH MyVIVO 256MB 256BIT 3770 ¤ 1
CREATIVE AUDIGY 2 ZS 585 ¤ 1
NEC ND-3540A Dual Layer DVD±R/W/DL 16X BLACK 350 ¤ 1
COOLER MASTER Stacker 995 ¤ 1
ENERMAX EG701 AX 2.0 Noisetaker 600W SLI 1170 ¤ 1
LG F700B 930 ¤ 1
Computer Assembly 170 ¤ 1
Everything's Price: ¤ 16060
Cash Discount 3%
Final Price: 15578.2
hey dude,welcome to israel.
this is one huge budget here in the holy ground,you let us flexibility to create an a monster!!!:)
i'd go on the following features as my weapone of choce:
amd 64 4400x2
DFI lan party SLI-DR
1GB of mushkin red-line pc 4400
7800 GTX(an XFX one of course:D)
250 gig's
ocz modstream 520W
and a case to suite as an eye candy :P
i'll give you the exact prices and ct' later on today
LG 700B? ARE YOU FU**ING KIDING?
No such thing "Redline 4400", there's XP4400 and Redline XP4000
None of OCZ's current products even matches the overclocking capabilities of the GSkill LE.
מה הבעיה במסך הזה?
בתקציב של 15,000 שקל לוקחים מסך הרבה הרבה יותר איכותי, ה-F700B לא מתאים אפילו למפרטים של 5000 שקל
Ok till now I think I know what I am going to take
AMD Athlon 64 3700 (939-pin) Box San Diego
DFI LAN PARTY NF4 SLI-DR
OCZ 1GB (2x512MB) EL DDR PC3200 DualChannel Platinum Rev 2
About the hard disk I am not sure about it I mean I sure that I going to take an raptor but I dont need more than 160GB so I think I going to take a WD 36GM 10000rpm and 160GB of WD 7200rpm what do you say ?
I'd take something that's binned a bit higher than the Plat rev2, maybe Mushkin XP4400/Geil Ultra-X 4400/OCZ Plat 4200/Gskill LC (all are high binned TCCD with Brainpower PCB)
As for the hard drive - IMO one SATA2 drive will suffice
AMD Athlon 64 X2 Dual-Core processor 4400+ (2.2GHz) Retail BOX
4,472 ש"ח
Mushkin 1GB 2x512MB XP4000 2-2-2 Redline
1,379 ש"ח
Leadtek WinFast PX7800 GTX TDH MyVIVO
3,770 ש"ח
1,395 ש"ח
Thermalright XP-120 for Pentium 4 AMD Athlon64
266 ש"ח
OCZ PowerStream Power Supply 520W
868 ש"ח
Thermaltake Soprano VB1000SNS Silver Window
506 ש"ח
Creative AUDIGY 2 ZS Retail Sound Card
598 ש"ח
Seagate 250GB NCQ 8MB 7200RPM SATA
973 ש"ח
If you can give me the prizes of them it will be better because I want to make my choices and if you say they are all the same so I will make my choice
And about the SATA 2 what is prize too ?
The mushkins are currently the cheapest - 1500 NIS
http://lamir.co.il/product.asp?product=7334
And WD 160GB SATA2 drives go for around 530-550 NIS
THE SATA2 COST 10 SHEKEL MORE THAN SATA1
BUT IT WONT GIVE U ANY BIG IMPROVEMENT 4 NOW
I THINK U SHOULD TAKE 3700 SAN DIEGO 2 GIGA OF REGULARY MEMOREY BEACAUSE I THINK 2 GIGA DDR 400 NORMAL MEMOREY IS BETTER THAN 1 GIGA MEMOREY 4 OC .
ABOUT THE MONITOR-IN SUCH BIG BUDGET U MUST TAKE 19" GOOD LCD SCREEN
CRT IS GOOD FOR GAMES MAYBE, BUT AS FAR AS EVERYTHING ELSE ITS A BETTER CHOICE.
