Amd 3500$ - i am in the end and you stoped help me please get in
Hello I am a new user here I came form Miami
For 2 years to Israel and my computer stay on Miami I really want your opinion about a new computer so all the peoples who knows something about it thanks.
So I begin with my list
But first if something not sounds good or the prize of him not looks so say me.
Ok.
AMD Athlon 64 3800 (939) Box Winchester
MSI K8N Diamond nVIDIA nForce4 SLI Socket 939
Corsair CMX512 3200C2PRO
Westren Digital 160GB SATA II
Leadtek Geforce PX6800Ultra 256Mb Retail PCI-Express SLI
Thermaltake Xaser III Lanfire
OCZ PS 520W ATX POWERSTREAM
Thanks to Avi and Eylone that help me to register to the website
And now people if you can bring me the prize of the computer in Israel its will really help me. I thout about DFI Motherboards I have a 3500$ I thought about 2 video Cards of 6800GT to make a dual help me.
And if you can write in English because I dont want to call a friend that he will explain me the Hebrew
Oh and I forgot I dont need key boards mouse and headphones only a monitor
  • תגובות 75
  • צפיות 6.4k
What's the use of the computer? gaming? overlclocking?..
Do you want a LCD monitor or a CRT?
hello
in start im sorry for the english that not sow good
3500$
in israel is 15'876 shekel and this a lot of mouny and you can boute in this boudget a monster
but lets take care off the first chaos.
amd 3800 is not a good value for mouny! you can boute in 1400 shekel less amd 3000 with the same preformens im think that dual core 4400 be exelent choise.
the  memory is very expensiv and we should need to take somthing good for overcloking with 600mhz maybe with dfi lanprty ultra sli.
the graphic card is a "old genertion" and in this budget 7800gtx is most!
the case is a taste thing at the most but i bealive that we can find somthig much better.
What's the computer for? gaming? overlclocking?..
Emm I just need the computer for a games but I want to make a over clock to 4200 or 4000 and about the monitor - CRT not so expensive I want to spend my money on the computer not on the monitor
hello
3500$
amd 3800 is not a good value for mouny! you can boute in 1400 shekel less amd 3000 with the same preformens.
I sorry but I didnt understood you if you can write it clean it will be better , or you can write it in Hebrew and other people here will translate it to English.
מה שרשמתי לו זה ככה ואם מישהו יפרש באנגלית גבוהה זה יהיה נחמד :)
3500 דולר בישראל זה 15,876 שח וזה המון כסף. בסכום הזה אתה יכול לקנות מפלצת.
אבל בוא נטפל בכאוס הראשוני.
AMD 3800 אינו תמורה נאה לכסף, ב-1400 שח פחות יש AMD 3000 שנותן את אותם ביצועים. אני חושב שליבה כפולה AMD 4400 יהיה בחירה מעולה.
הזיכרון מאוד יקר ולא שווה את הכסף ועדיף לקחת משהו לאוברקלוקינג. משהו עם 600 מגה הרץ לפחות עדיף שיהיה עם DFI LANPARTY ULTRA SLI
הכרטיס מסך שבמפרט שלך "מהדור הישן" בתקציב הזה 7800GTX חובה!
המארז הוא בעיקר עניין של טעם אישי אבל אני חושב שאפשר למצוא מארז יותר איכותי מזה.
hello
3500$
Ok, Translation:
In israel, 3500$ equals to 15,876 Shekels.. its a lot of money and you can buy in this budget a monster PC.
amd 3800 isn't a good value for money, you can buy in 1400 Shekels less and amd 3000 , with the same performance i think.
the dual core 4400+ can be an exellent choice.
the memory is very expensive and you should take something better for overclocking , like the G.Skill PC4800 (DDR600) who promise that you will be able to reach the 300MHZ with a motherboard like DFI NForce4 Ultra-D \SLI.
The graphic card is a "Previous Generation" card, and in you budget you can buy the 7800GTX -which is the best today.
The case is more like something that you choose, just follow your taste.. anyway, in this budget you can take a better case.
וואו איזה אנגלית מדהימה, תודה על הפירוש.
ועכשיו אני אכתוב את זה באנגלית תאמרו לי אם השתפרתי ;D
wow this is a great english thank you for the Translation
Oh thanks Bose it something that I didnt know in America AMD 3800 is not so expensive so I guess that the other objects cost expensive too so if someone can make me an a List of a other computer that the prize of him and the objects are better then mine so I really thanks him.
But in America Amd 4400 cost more then 3800 and I dont think I need it
If I got the money its not says that I must to spend him on a crazy things
But I still want a computer with a good performance and a good prize if some one can help me to choice it will be better because I dont know what's going with Israel with computers but I sure you know so make me a list and I will look at it thanks a lot
Oh thanks Bose it something that I didnt know in America AMD 3800 is not so expensive so I guess that the other objects cost expensive too so if you can make me an a List of a other computer that the prize of him and the objects are better then mine so I really thanks him.
I think that the AMD A64 3700+ san-diego will be perfect for you and your needs.
דגם מחיר כמות
AMD Athlon 64 X2 Dual-Core processor 4400+(2.2GHz) BOX 4400 ¤ 1
DFI LAN PARTY NFORCE4 SLI-DR 1450 ¤ 1
OCZ EL DDR 1024MB 625MHZ PC-5000 Dual Channel Platinum DFI nF4 Special 1950 ¤ 1
WD 160GB 7200RPM 8MB SATAII 580 ¤ 1
Gainward PowerPack! 7800GTX 3800 ¤ 1
COOLER MASTER Stacker 995 ¤ 1
OCZ PS 520W ATX POWERSTREAM 845 ¤ 1
Thermalright XP-120 for P4 and K8 265 ¤ 1
סה"כ: ¤ 14285
www.noacomp.co.il
Model Price Quantity
DFI LANPARTY UT nF4 SLI-D 1200 ¤ 1
G.Skill DDR 550MHZ EXTREME PC4400 TCCD 1024MB DUAL CHANNEL F1-3200DSU2-1GBLE 1850 ¤ 1
WD 36/10000 SATA RAPTOR 640 ¤ 1
SEAGATE 120GB 7200RPM SATA 8MB NCQ 570 ¤ 1
LEADTEK WinFast PX7800GTX TDH MyVIVO 256MB 256BIT 3770 ¤ 1
NEC ND-3540A Dual Layer DVD±R/W/DL 16X BLACK 350 ¤ 1
OCZ PS 600W ATX POWERSTREAM 1245 ¤ 1
LG F900P 1690 ¤ 1
Computer Assembly 170 ¤ 1
Everything's Together price: ¤ 15855
Price of every payment: 15379.3
Final Price: 15379.35
From www.noacomp.co.il
HERE YOU GO, A MONSTER:
שם מוצר כמות מחיר סופי
Coolermaster STC-T01 Stacker P/S Not Included Case  1 999 ¤
NEC ND-3540 Black 16/8/4//48/24/48 Bulk DVD±R/RW  1 319 ¤
AMD Athlon 64 3700 San-Diego Socket 939 BOX  1 2249 ¤
Thermalright XP-120  1 309 ¤
LG 16/48 Bulk Black DVD-ROM  1 149 ¤
Citizen/Sony/Alps Black 1.44MB 3,5" FDD  1 55 ¤
Seagate 250GB 7200 rpm 8MB Buffer NCQ Serial ATA HDD  1 839 ¤
Western Digital Raptor 36.7GB 10000 rpm Serial ATA HDD  1 629 ¤
DFI LanParty NF4 SLI-DR nForce 4 Ultra 939 Motherboard  1 1339 ¤
OCZ 512Mb DDR400 CL-2-3-2-5 EL Platinum memory  2 1718 ¤
19" Viewsonic G90F+B Black Flat Monitor  1 1579 ¤
Antec TruePower 480W V2.0 120mm + SATA + 24pin Power Supply  1 739 ¤
Computer Assembly  1 160 ¤
Gainward Geforce 7800GTX Ultra/ 3500PCX 256MB DVI Video Card  1 3489 ¤
סה''כ: 15 14572 ¤
:o
Thank you Amit Z and Bose but I think that this computer is too much good for me 4400 its a really monster like I said if I got money it's not mean that I must spend him I need something Like 3700 SAN diego like Avi said
Evman007's computer is the best for you, in my opinion.
hmm..תתחדש!
