RAID בלוח K8NF-9
אין מצב ש"גיבוי" יתן שיפור בביצועים !!!
Level 0 -- Striped Disk Array without Fault Tolerance: Provides data striping (spreading out blocks of each file across multiple disk drives) but no redundancy. This improves performance but does not deliver fault tolerance. If one drive fails then all data in the array is lost.
Level 1 -- Mirroring and Duplexing: Provides disk mirroring. Level 1 provides twice the read transaction rate of single disks and the same write transaction rate as single disks.
דווקא את החלק הרלוונטי לא הדגשת
