windows cant find my writer
i have installed windows 2000
like u can see it doesnt have hebrew support :(
(but the big problem is that windows 2000 cant finde my writer
but windows xp found him so...
can u help me ?
i have yamaha 4x4x16 :( with scsi
go to control panel to the regional setting in the laguage tab look for the check box install files for complex script and right to left laguages next go to the advanced tab and set it to hebrew next to regional option and set it to hebrew and israel insert your win2k cdrom and press ok some files will be copied to hard drive after this you will be asked to restart the computer do it this will give your windows hebrew support.as for your cd writer you have to install a driver for the scsi adapter if want the operating system to recognize the scsi cd writer.
