חוות דעת על מחשב - 4 אלף שקל.
[TABLE]
[TR]
[TD][/TD]
[TD]BX80646I54690K.jpg[/TD]
[TD]1[/TD]
[TD]Intel[/TD]
[TD]CM8064601710803[/TD]
[TD]מעבדים - Intel Socket LGA1150
CM8064601710803 - Intel - i5-4690K Quad core CPU - LGA1150 - 3.9 GHz - 6MB cache - 22nm - 88W TDP - Integrated HD Graphics 4600 at 1200Mhz - Devil’s Canyon Series - Tray...
שלוש שנים אחריות[/TD]
[TD]₪1246/1221[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]Z87M-G43.jpg[/TD]
[TD]1[/TD]
[TD]MSI[/TD]
[TD]Z87M-G43[/TD]
[TD]לוחות אם - Intel LGA1150
Z87M-G43 - MSI - Socket LGA1150 CPU - Intel Z87 chipset - Dual channel DDR3 up to 3000 MHz memory - Integrated Graphics with VGA, DVI, HDMI, DisplayPort video outputs - 2 PCI Express x16 slots - 8-channel audio - S/Pd...
[TD]₪462/453[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]0514-012TB0.jpg[/TD]
[TD]1[/TD]
[TD]Zeppelin[/TD]
[TD]0514-012TB0[/TD]
[TD]זכרונות - DDR3 - לנייח
0514-012TB0 - Zeppelin - 8GB DDR3 PC3-12800 - CL11 - DDR3-1600 - 1.5V...
Lifetime Warranty[/TD]
[TD]₪299/293[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]100x100[/TD]
[TD]1[/TD]
[TD]GigaByte[/TD]
[TD]GV-R928XOC-3GDu[/TD]
[TD] - NEW with 2 years warranty RADEON R9 280X GPU Rev 2.0 - 3GB 384bit GDDR5 memory - Windforce 3x cooler - PCIe x16 v3.0 interface - DVI, HDMI, Dual mini DisplayPort video outputs - GPU/Memory clock 1100/6000 MHz - Overclocked - Only with new PC
[/TD]
[TD]₪834[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]ST2000DM001.jpg[/TD]
[TD]1[/TD]
[TD]Seagate[/TD]
[TD]ST1000DM003[/TD]
[TD]דיסקים קשיחים ו SSD - SATA
ST1000DM003 - Seagate - 1TB - 3.5 inch - SATA3 6Gb/s - 7200rpm - 64MB Cache - Barracuda 7200.14 series...
שלוש שנים אחריות לפי תקנון יצרן[/TD]
[TD]₪274/269[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]X1-T.jpg[/TD]
[TD]1[/TD]
[TD]Antec[/TD]
[TD]X1-T-A550[/TD]
[TD]מארזי מחשב - מארז עם ספק
X1-T-A550 - Antec - X1-T Mid-Tower Gaming Case with Antec VP-550P 550W PSU - 3 5.25 inch and 8 3.5 inch bays - Max video card length 280mm - 2 120mm fans included - USB3.0, USB2.0, Audio front ports - ATX ...
שנה אחריות למארז, שלוש שנים אחריות לספק[/TD]
[TD]₪436/427[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]Freezer-13.JPG[/TD]
[TD]1[/TD]
[TD]Arctic Cooling[/TD]
[TD]Freezer-13[/TD]
[TD]פתרונות קרור - מאווררים למעבדים
Freezer-13 - Arctic Cooling - Arctic Cooling Freezer 13 - The Freezer 13 carries the legacy of the renowned Freezer 7 Pro Rev.2. With all together 4 high-performance heatpipes the cooler brings 200 Watts cooling performance – enou...
שנה אחריות[/TD]
[TD]₪156/153[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]GH24NS95.jpg[/TD]
[TD]1[/TD]
[TD]LG[/TD]
[TD]GH24NSB0[/TD]
[TD]DVD צורבים תקליטורים ו - פנימי SATA DVD צורב
GH24NSB0 - LG - x24 DVD-RW Drive with M-DISC™ Support - Burns DVD+R/-R discs at 24x speed - SATA interface - Black (GH24NSC0)...
שנתיים אחריות[/TD]
[TD]₪83/81[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]SERVICEFORUM.jpg[/TD]
[TD]1[/TD]
[TD]Plonter[/TD]
[TD]SERVICEFORUM[/TD]
[TD]שרות במעבדות פלונטר - הרכבת חלקים
SERVICEFORUM - Plonter - הרכבת מחשב, חיווט ובדיקות מקיפות חינם להזמנה של חבר פורום. זיכרו למלא בעת פתיחת בכרטיס הלקוח מאיזה פורום הגעתם או הודיעו לנו אחרי...[/TD]
[TD]₪1/1[/TD]
[/TR]
[/TABLE]
3857 / 3798 ₪
משום מה הכרטיס שבחרתי כבר לא קיים שם אבל ערכתי את זה למה שהיה אמור להיות(r9 280x)
מה אתם אומרים? יש משהו שצריך לשפר? אני חושב להוסיף SSD אם הכל בסדר במפרט.
התקציב שלי הוא עד 4 אלף,אם החריגה שווה משהו אז אפשר עוד 200 שקל.
השימושים שלי הם גיימינג בעיקר למשחקים כמו CSGO,ACU,GTA וכדומה ושיהיה לי גם סיכוי להריץ משחקים שיצאו בעתיד.אני משחק בעיקר CS GO,ככה שחשוב לי ה FPS במשחק הזה ואני שואף להגיע ל 250-300 FPS.
ואני גם עורך למשחק הזה ב SONY VEGAS אולי AE אז זה עריכה קלה גם אני מניח.
תודה רבה שבת שלום :)
  • תגובות 33
  • צפיות 5k
דבר ראשון תמלא את הטופס בנעוץ, יהיה יותר קל לעזור לך.
במשחק הזה ואני שואף להגיע ל 250-300 FPS."
רוב המסכים לא מציגים יותר מ60fps, ואני לא מאמין שמישהו באמת מצליח לראות הבדל משמעותי בין 60fps ובין 300fps. אם אתה בכל זאת רוצה לראות את המשחק בקצב רענון כזה אז כנראה כדאי לך לבדוק אם המסך שלך תומך בזה גם כן
נראה לי שאתה מתבלבל בין HZ שזה משהו של המסך ל FPS,בכל מקרה רוב שחקני הפרו משחקים על 300 FPS וכן יש הבדל כי עכשיו אני משחק עם המחשב הזה על 80-110 FPS והמשחק נתקע כל שניה
ושבאתי לחבר שלי שיש לו 230 מרגישים את ההבדל.
תקציב:
• התקציב לרכישת המחשב:4000
• חריגה מקסימלית מהתקציב:200
• האם לנצל את כל התקציב או לנסות לחסוך?לעשות את המיטב מהסכום הכסף.
שימושים:
• מהם השימושים במחשב? (לסמן באדום).עבודה משרדית | גיימינג כבד או קל | עריכה גראפית | עריכת אודיו | עריכת וידאו | HTPC | אחר (נא לפרט):אני חושב שגיימינג קל אבל יש מצב שגם כבד.
• במידה שבחרת בגיימינג, ציין שמות של משחקים בהם תשחק:CS GO אולי ARMA,זה תלוי.
•במידה שבחרת בעריכה כלשהי, ציין שמות של תכנות בהן אתה תשתמש:SONY VEGAS אולי AFTER EFFECTS קצת,לא עריכה כבדה.
• באיזו מערכת הפעלה תשתמש (32 / 64 ביט): 64 כנראה.
• האם יש צורך במערכת הפעלה חוקית כחלק מן התקציב? (כן / לא): לא מתכוון לשלם מעל 150 שקל על מערכת הפעלה.
דרישות מיוחדות:
• האם יש העדפה לגודל\צורה של המארז? (קטן | בינוני | גדול | שוכב (מאוזן) | אין חשיבות)
• אחר:לא אבל שיהיה נוח מבחינת כניסות של USB ואוזניות וכדומה.
• האם תבצע Overclock למחשב (כן או לא):
• אם כן, לאילו רכיבים?:אני לא מבין בזה כל כך אז אני לא רוצה לדבר יותר מדי smile.gif
• האם תרצה לבצע מערך מרובה כרטיסי מסך (SLI של Nvidia או CrossfireX של AMD) כרגע או בעתיד (כן או לא) : כנראה שלא.
ציוד היקפי:
לכל עזרה עם ציוד היקפי ניתן למצוא עזרה כאן
• מהי רזולוציית המסך הטבעית [הגבוהה ביותר] של המסך שיתחבר למחשב? אם היא אינה ידועה לך, כתוב את גודל המסך במקום (באינצ'ים) -1920X1080
• האם תחבר מערכת סאונד (אוזניות/רמקולים) 7.1CH, 5.1CH או 2.1CH למחשב? יש לי אוזניות ורמקולים 2.1 אבל אם אפשר שיהיה לי גם תמיכה ב 7.1 זה יהיה אחלה.
מידע על מערכות הסאונד נמצא בסוף באשכול.
חומרה אופציונלית:
• האם ברצונך לקנות צורב (כונן דיסקים) עם המפרט (כן או לא):כן
צורב סטנדרטי יעלה לכל היותר בין 100 ל-120 ש"ח, שים לא שלא יהיה ניתן להכניס דיסקים למחשב ללא הכונן.
• מהו נפח האחסון שתרצה בדיסק קשיח (500GB, 1TB וכדומה): 1TB+
• האם יש רכיב מסוים שאין צורך לכלול במפרט? אם כן, מהו:
• במידה שישנו רכיב כזה, ציין את הדגם שלו:
• האם ברשותך יש חלפים ישנים ממחשב אחר? אם כן, ציין אילו.
אפשרויות רכישה:
• האם קיימת העדפה לרכישת המחשב מחנות מסויימת:לא
• אם לא, נוכל להתאים לך חנות לפי איזור מגורים. עיר מגורים:פתח תקווה
• מומלץ מאוד לציין את מקום המגורים אם אין ברשותך העדפה לחנות.
• האם באפשרותך לבצע הזמנה מחנות רחוקה:לא.
• אם אינך בטוח לגבי חנות ספציפית לקנייה, נוכל להמליץ לך על חנות שתוכל לבצע בה את הקנייה המשתלמת ביותר.
• מתי מתוכננת רכישת המחשב:בחודשים הקרובים.
• שים לב שכשמדובר בפרק זמן משמעותי, המפרט שתקבל עשוי להיות לא רלוונטי לעת הרכישה, לכן מומלץ להתייעץ עמנו כמה ימים לפני הקנייה.
• את המחשב לא מקבלים מורכב אלא רק את הקופסאות עם הרכיבים שהזמנת. האם תרצה שהחנות תרכיב לך אותו? כן
• הרכבה עשויה לעלות עד כ-100 ש"ח (בהתאם לרשתות השונות).
• עד כמה חשובה לך רמת השקט מ1-10? חשוב חשוב.
• שים לב שרוב המארזים בתקציב של עד כ-400 ש"ח לא מתמקדים בשקט.
• האם יש חשיבות לשמור על אפשרות לשדרוג עתידי?כן
• שים לב שאופציה זו בדרך כלל מתאימה לתקציבים גבוהים.
• הערות נוספות: אם יש לך הערות נוספות או בקשות מיוחדות, כתוב אותן פה (עבודה רצופה, חיבורים מסוימים, גודל המארז וכיוצא בזאת).
אתה מוזמן לחפש "fps higher than monitor refresh rate" ולקרוא קצת על הנושא :)
בקצרה מאוד זה אומר שאם המסך שלך מציג 60 תמונות לשנייה, זה לא משנה שהכרטיס מסך שלך מייצר יותר, עדין יוצגו לך 60.
ראיתי שאתה אומר שאתה לא הולך לעשות OC(Overclock), זה אומר שכבר אפשר את המעבד והלוח אם להוזיל במחיר, שניהם כרגע תומכים בOC ואין סיבה להשקיע את התוספת הזאת אם אתה לא מתכנן לעשות OC בכלל.
השארתי לך את אותו המארז שבחרת, אני לא יודע עד כמה הוא שקט ואני לא מוצא הרבה מידע עליו באינטרנט, שווה לעשות בדיקה נוספת בנושא
קירור למעבד, בנושא הזה אני פחות מבין אבל אני יודע שזה קירור שמומלץ הרבה פעמים על ידי חברי הפורום.
[TABLE]
[TR]
[TD]CM8064601560722.jpg[/TD]
[TD]1[/TD]
[TD]Intel[/TD]
[TD]BX80646I54590[/TD]
BX80646I54590 - Intel - i5-4590 Quad core CPU - LGA1150 - 3.3 GHz - 6MB cache - 22nm - 84W TDP - Integrated HD Graphics 4600 at 1150MHz - Haswell Refresh - Box (With Fan)...
[TD]₪1053/1032[/TD]
[/TR]
[TR]
[TD]H97-PC-Mate.jpg[/TD]
[TD]1[/TD]
[TD]MSI[/TD]
[TD]H97-PC-Mate[/TD]
H97-PC-Mate - MSI - Socket LGA1150 CPU support - Intel H97 chipset - Dual channel DDR3 up to 1600 MHz memory - Integrated Graphics with VGA, DVI-D, HDMI video outputs - 2 PCI Express x16 slots - 8-channel audio - Gigabit...
שלוש שנות אחריות[/TD]
[TD]₪451/442[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]Zeppelin[/TD]
[TD]₪299/293[/TD]
[/TR]
[TR]
[TD]GTX-960-GAMING-2G.jpg[/TD]
[TD]1[/TD]
[TD]MSI[/TD]
[TD]GTX-960-GAMING-2G[/TD]
[TD]כרטיסי מסך - nVidia PCIe
GTX-960-GAMING-2G - MSI - GeForce GTX960 GPU - Gaming version - 2GB 128 bits GDDR5 memory - PCI-Express 3.0 interfce - HDMI, DVI, 3 x DisplayPort video outputs - GPU/Memory clocks up to 1304/7010 MHz...
[TD]₪1279/1253[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]Seagate[/TD]
[TD]₪274/269[/TD]
[/TR]
[TR]
[TD]X1-T.jpg[/TD]
[TD]1[/TD]
[TD]Antec[/TD]
[TD]X1-T-A550[/TD]
[TD]₪436/427[/TD]
[/TR]
[TR]
[TD]UCACO-FI11001-CSA01.jpg[/TD]
[TD]1[/TD]
[TD]Arctic[/TD]
[TD]UCACO-FI11001-CSA01[/TD]
UCACO-FI11001-CSA01 - Arctic - Arctic Freezer i11...
שנה אחריות[/TD]
[TD]₪155/152[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]LG[/TD]
[TD]GH24NSB0[/TD]
שנתיים אחריות[/TD]
[TD]₪83/81[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]Plonter[/TD]
[TD]₪1/1[/TD]
[/TR]
[/TABLE]
4031.00 / 3950 ₪
עד 3 תשלומים ללא ריבית אלא אם מצויין אחרת במפרט המוצר
המחיר אינו כולל משלוח
אל תקנה יש הצעות יותר טובות
[TABLE]
[TR]
[TD]1[/TD]
[TD]Intel[/TD]
[TD]₪1053/1032[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]MSI[/TD]
[TD]₪451/442[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]Zeppelin[/TD]
[TD]₪299/293[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]MSI[/TD]
[TD]₪1279/1253[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]Seagate[/TD]
[TD]₪274/269[/TD]
[/TR]
[TR]
[TD]X1-T.jpg[/TD]
[TD]1[/TD]
[TD]Antec[/TD]
[TD]X1-T-A550[/TD]
[TD]₪436/427[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]Arctic[/TD]
שנה אחריות[/TD]
[TD]₪155/152[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]LG[/TD]
[TD]GH24NSB0[/TD]
שנתיים אחריות[/TD]
[TD]₪83/81[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]Plonter[/TD]
[TD]₪1/1[/TD]
[/TR]
[/TABLE]
4031.00 / 3950 ₪
גרוע מאוד,הורדת לי גם את הביצועים של הכרטיס מסך וגם של המעבד וגם נשאר אותו כסף,מה עשיתי פה? ו OVERCLOCKING אני יודע מה זה כבר פחות או יותר אז הכל בסדר,וגם החברה עושה את זה.
יפה שאתה זורק את המשפט בלי כלום.
אם תרצה לעשות המרה למעבד את צריך לוח אם Z97 ומאוורר למעבד כמו NH-D15 זה יעלה לכך כסף. מומלץ לקנות I7 4790 נעול עם לוח אם H97-GAMING 3 GIGABYTE זיכרון 2X4G את יכול להוסיף בעתיד. עם כונן SSD למערכת הפעלה וכרטיס מסך GTX970 יזה יעלה לך בסביבות 5000 ש"ח או אתה יכול לקנות ביד שניה ותחסוך הרבה כסף
USER68009 - אם תמשיך לזרוק שטויות ולזהם את הפורום, אתה לא תהיה פה.
darkonerxd - המפרט שלך במסגרת התקציב בסדר גמור.
לגבי אוברקלוק - רוב החנויות לא עושות את זה בשבילך, לכן צריך לשאול.
לגבי לוח-אם - במקום ה-Z87M-G43 ששמת, הייתי מחליף ל-Z87-Pro4 של אסרוק שגם זול יותר וגם טוב יותר.
לגבי הקירור למעבד - אם אתה רוצה שהוא יגביל אותך ב-OC גבוה, הייתי מוסיף כמה עשרות שקלים ולוקח את ה-mugen של scythe שעולה באיזור ה-200 ש"ח.
אם תוכל לדחוף SSD למפרט, אפילו בנפח של 128GB, זה יעשה רק טוב. הבוט יהיה משמעותית מהיר יותר, השימוש השוטף במחשב יהיה חלק יותר וטעינות במשחקים שיותקנו עליו יהיו משמעותית מהירים יותר.
אני יוצא מהפורם תמשיך לצחוק על האנשים
^ אל תאיים עלינו.. :cwm31:
MBoomer
הוא צודק ואתה טועה.
תאורטית מה שאתה אומר הוא נכון אבל משום מה החוקים האילו לא תופסים בCS . שם זה עבוד כך שככול שהFPS גבוהה יותר, חווים תחושה של משחקיות חלקה יותר.
כן, יש הבדל משמעותי בין 60 ל100 במשחק הזה ברמה כזו שכל אחד יכול לשים לב על כל מסך...
אני יודע על מה הוא מדבר כשהו אומר ש60~80 FPS הוא מרגיש שזה תקוע בהשוואה לחבר שלו עם 300 .....
darkonerxd
בחרתי לוותר על האופציה שאתה לא מבין בה - OC, וסידרתי לך מפרט מהסרטים עם מעבד I7 והכרטיס מסך שרצית:
[TABLE]
[TR]
[TD]1[/TD]
[TD]Intel[/TD]
[TD]CM8064601560113[/TD]
CM8064601560113 - Intel - i7-4790 Quad core CPU - LGA1150 - 3.6 GHz - 8MB cache - 22nm - 84W TDP - Integrated HD Graphics 4600 at 1200MHz - Haswell Refresh - Tray...
[TD]₪1569/1538[/TD]
[/TR]
[TR]
[TD]Z87-Pro4.jpg[/TD]
[TD]1[/TD]
[TD]ASRock[/TD]
[TD]Z87-Pro4[/TD]
Z87-Pro4 - ASRock - Socket LGA1150 CPU (Haswell, Broadwell) support - Intel Z87 chipset - Dual channel DDR3 up to 2933 MHz memory - Integrated Graphics with HDMI, VGA, DVI video outputs - HDMI-In Port - 2 PCI Express x16...
[TD]₪361/354[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]Zeppelin[/TD]
[TD]₪299/293[/TD]
[/TR]
[TR]
[TD]MR928X3GD5G.jpg[/TD]
[TD]1[/TD]
[TD]MSI[/TD]
[TD]MR928X3GD5Gu-PC[/TD]
[TD]כרטיסי מסך - AMD PCIe
MR928X3GD5Gu-PC - MSI - RADEON R9 280X GPU - Factory Refurbished by MSI - With new PC Only - 3GB 384bit GDDR5 memory - PCIe x16 v3.0 interface - DVI, HDMI, Dual mini DisplayPort video outputs - GPU/Memory clock 1020/6000 MHz...
בקניית מחשב חדש בלבד - משופץ על ידי MSI - אחריות שנה ו 8 חודשים[/TD]
[TD]₪750/735[/TD]
[/TR]
[TR]
[TD]DT01ACA100.jpg[/TD]
[TD]1[/TD]
[TD]Toshiba[/TD]
[TD]DT01ACA100[/TD]
DT01ACA100 - Toshiba - 1TB - 3.5 inch - 7200 RPM - SATA3 6Gb/s - 32MB Cache - DT01ACA series...
שנתיים אחריות[/TD]
[TD]₪266/261[/TD]
[/TR]
[TR]
[TD]VSP-5000.jpg[/TD]
[TD]1[/TD]
[TD]Antec[/TD]
[TD]VSP5000-550[/TD]
VSP5000-550 - Antec - Antec VSP-5000 2x USB3.0 - 550W - 3x 120mm - with Antec VP-550P - Also know as the Antec P70...
שנה אחריות למארז ושלוש שנים לספק[/TD]
[TD]₪476/466[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]Arctic[/TD]
שנה אחריות[/TD]
[TD]₪155/152[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]LG[/TD]
[TD]GH24NSB0[/TD]
שנתיים אחריות[/TD]
[TD]₪83/81[/TD]
[/TR]
[TR]
[TD]1[/TD]
[TD]Plonter[/TD]
[TD]₪1/1[/TD]
[/TR]
[/TABLE]
3960.00 / 3881 ₪
קישור להצעת המחיר
http://www.plonter.co.il/priceoffer_shoppingcart.tmpl?PriceOffer=21741
*** ממליץ בחום להוסיף SSD בהמשך הדרך או אפילו אם מתאפשר לך לחרוג ולהנות ממנו כבר המעמד הרכישה!
ההמלצה לכונן SSD כרגע היא לדגם BX100 256G בעלות של 542ש"ח .
בהצלחה !
נערך על-ידי furyanaor
^ אל תאיים עלינו.. :cwm31:MBoomer הוא צודק ואתה טועה. תאורטית מה שאתה אומר הוא נכון אבל משום מה החוקים האילו לא תופסים בCS . שם זה עבוד כך שככול שהFPS גבוהה יותר, חווים תחושה של משחקיות חלקה יותר. כן, יש הבדל משמעותי בין 60 ל100 במשחק הזה ברמה כזו שכל אחד יכול לשים לב על כל מסך... אני יודע על מה הוא מדבר כשהו אומר ש60~80 FPS הוא מרגיש שזה תקוע בהשוואה לחבר שלו עם 300 ..... darkonerxd בחרתי לוותר על האופציה שאתה לא מבין בה - OC, וסידרתי לך מפרט מהסרטים עם מעבד I7 והכרטיס מסך שרצית: plonter_logo.png הצעת מחיר למערכת מחשב - www.plonter.co.il - המקום לאנשים שאוהבים מחשבים [TABLE] [TR] [TD]CM8064601560722.jpg[/TD] [TD]1[/TD] [TD]Intel[/TD] [TD]CM8064601560113[/TD] [TD]מעבדים - Intel Socket LGA1150 CM8064601560113 - Intel - i7-4790 Quad core CPU - LGA1150 - 3.6 GHz - 8MB cache - 22nm - 84W TDP - Integrated HD Graphics 4600 at 1200MHz - Haswell Refresh - Tray... שלוש שנים אחריות[/TD] [TD]₪1569/1538[/TD] [/TR] [TR] [TD]Z87-Pro4.jpg[/TD] [TD]1[/TD] [TD]ASRock[/TD] [TD]Z87-Pro4[/TD] [TD]לוחות אם - Intel LGA1150 Z87-Pro4 - ASRock - Socket LGA1150 CPU (Haswell, Broadwell) support - Intel Z87 chipset - Dual channel DDR3 up to 2933 MHz memory - Integrated Graphics with HDMI, VGA, DVI video outputs - HDMI-In Port - 2 PCI Express x16... שלוש שנים אחריות[/TD] [TD]₪361/354[/TD] [/TR] [TR] [TD]0514-012TB0.jpg[/TD] [TD]1[/TD] [TD]Zeppelin[/TD] [TD]0514-012TB0[/TD] [TD]זכרונות - DDR3 - לנייח 0514-012TB0 - Zeppelin - 8GB DDR3 PC3-12800 - CL11 - DDR3-1600 - 1.5V... Lifetime Warranty[/TD] [TD]₪299/293[/TD] [/TR] [TR] [TD]MR928X3GD5G.jpg[/TD] [TD]1[/TD] [TD]MSI[/TD] [TD]MR928X3GD5Gu-PC[/TD] [TD]כרטיסי מסך - AMD PCIe MR928X3GD5Gu-PC - MSI - RADEON R9 280X GPU - Factory Refurbished by MSI - With new PC Only - 3GB 384bit GDDR5 memory - PCIe x16 v3.0 interface - DVI, HDMI, Dual mini DisplayPort video outputs - GPU/Memory clock 1020/6000 MHz... בקניית מחשב חדש בלבד - משופץ על ידי MSI - אחריות שנה ו 8 חודשים[/TD] [TD]₪750/735[/TD] [/TR] [TR] [TD]DT01ACA100.jpg[/TD] [TD]1[/TD] [TD]Toshiba[/TD] [TD]DT01ACA100[/TD] [TD]דיסקים קשיחים ו SSD - SATA DT01ACA100 - Toshiba - 1TB - 3.5 inch - 7200 RPM - SATA3 6Gb/s - 32MB Cache - DT01ACA series... שנתיים אחריות[/TD] [TD]₪266/261[/TD] [/TR] [TR] [TD]VSP-5000.jpg[/TD] [TD]1[/TD] [TD]Antec[/TD] [TD]VSP5000-550[/TD] [TD]מארזי מחשב - מארז עם ספק VSP5000-550 - Antec - Antec VSP-5000 2x USB3.0 - 550W - 3x 120mm - with Antec VP-550P - Also know as the Antec P70... שנה אחריות למארז ושלוש שנים לספק[/TD] [TD]₪476/466[/TD] [/TR] [TR] [TD]UCACO-FI11001-CSA01.jpg[/TD] [TD]1[/TD] [TD]Arctic[/TD] [TD]UCACO-FI11001-CSA01[/TD] [TD]פתרונות קרור - מאווררים למעבדים UCACO-FI11001-CSA01 - Arctic - Arctic Freezer i11... שנה אחריות[/TD] [TD]₪155/152[/TD] [/TR] [TR] [TD]GH24NS95.jpg[/TD] [TD]1[/TD] [TD]LG[/TD] [TD]GH24NSB0[/TD] [TD]DVD צורבים תקליטורים ו - פנימי SATA DVD צורב GH24NSB0 - LG - x24 DVD-RW Drive with M-DISC™ Support - Burns DVD+R/-R discs at 24x speed - SATA interface - Black (GH24NSC0)... שנתיים אחריות[/TD] [TD]₪83/81[/TD] [/TR] [TR] [TD]SERVICEFORUM.jpg[/TD] [TD]1[/TD] [TD]Plonter[/TD] [TD]SERVICEFORUM[/TD] [TD]שרות במעבדות פלונטר - הרכבת חלקים SERVICEFORUM - Plonter - הרכבת מחשב, חיווט ובדיקות מקיפות חינם להזמנה של חבר פורום. זיכרו למלא בעת פתיחת בכרטיס הלקוח מאיזה פורום הגעתם או הודיעו לנו אחרי...[/TD] [TD]₪1/1[/TD] [/TR] [/TABLE] 3960.00 / 3881 ₪ עד 3 תשלומים ללא ריבית אלא אם מצויין אחרת במפרט המוצר המחירים הזולים יותר הינם לתשלום במזומן/העברה בנקאית או תשלום בביטקוין - סכום ההנחה עומד על 2% ממחיר המוצר/עסקה הזמנה שתיווצר בפורום לא תחוייב בדמי הרכבה המחיר אינו כולל משלוח קישור להצעת המחיר http://www.plonter.co.il/priceoffer_shoppingcart.tmpl?PriceOffer=21741 *** ממליץ בחום להוסיף SSD בהמשך הדרך או אפילו אם מתאפשר לך לחרוג ולהנות ממנו כבר המעמד הרכישה! ההמלצה לכונן SSD כרגע היא לדגם BX100 256G בעלות של 542ש"ח . בהצלחה !
וואו מטורף גבר,אבל שמע אני מתכוון להשקיע פעם אחרונה במחשב אז אני הולך על הכי טוב בכסף.
OC לפי מה שאני הבנתי זה משדרג או מוסיף יותר כוח למעבד או למה שאתה עושה לו את הדבר הזה.
אין לי בעיה עם OC,להפך זה נראה לי אחלה חח ויש לי טכנאי גאון שהוא שכן שלי ויכול לעשות את זה בקלות.
אני מעדיף לקחת אולי אפילו את גרסאת ה K של המעבד ולעשות לו OC או לקחת כרטיס מסך יותר חזק.
מה שחשוב לי בתכלס שהמחשב יחזיק לי כמה שיותר זמן בגלל שזאת ההוצאה האחרונה שלי.
SSD שמעתי גם שזה מטורף אבל 500 שקל זה מוגזם,אבל אתה יותר מבין אז תגיד לי כבר מה לעשות בהנחה שאני כן יודע מה זה OC ואני יחסית לפי דעתי יודע כבר מה זה פחות או יותר.
נתחיל מזה שאני מצטער על המפרט. בדיוק מיהרתי לצאת ורציתי להספיק לעזור לך לפני שאני אצא. אני מסתכל עליו עכשיו ולא יודע מה עשיתי שם בדיוק.. אנא קבל את התנצלותי
המפרט החדש שנתנו לך מעולה.
לפי מה שאמרתה לנו ולפי דעתי אין לך צורך ממשי בOC, במיוחד עם מעבד חזק כמו שהכניסו לך שם. המעבד הזה יחזיק עוד שנים גם ללא OC.
בקשר לSSD, הוא באמת יגביר את החוויה שלך.
תגובה אחרונה בנוגע לFPS, בלי לנסות להעליב אף אחד, אבל אני לא מאמין שמישהו באמת שם לב להבדל גדול בין 80fps - 300fps. מה שכן קיים זה קצת חוסר סנכרון בין המכשירים, דבר שיכול לגרום להאטה קטנה אם מסופק בדיוק 60fps או אפילו טיפה מעל, כלומר חוסר התאמה בין הכרטיס מסך והמסך, וירידת פריימים מוסתרת.
^ בCS ההבדל מאוד משמעותי משום מה. .. לא חשוב.
darkonerxd
עכשיו אתה אומר משהו אחר לגמרי, בהנחה שאנחנו הולכים על מעבד K לטובת OC, סכום החריגה שלך חורג משמעותית מעבר לתקרת החריגה שהצבת (200 ש"ח להזכירך).
אם זה המצב ואתה מוכן לחרוג בהרבה לטובת OC אז תיתן תקציב ראלי ונרכיב לך מפרט שכזה.
4000שח לטובת מחשב עם SSD מעבד I7K וכרטיס 280X שהוא לא משומש (משופץ) זה לא משהו שניתן ליישם.
בנוגע לOC - מדובר בהמהרת תדרי השעון שהציב היצרן למעבד. זה משהו שהוא לא הדבר הכי מומלץ בעולם מה סיבה הפשוטה שלא לזה התכוון המשורר.
אם היה אפשר לתת תדר X בלי שום בעיה אז אני מאמין שהוא היה עושה כך. מה שאנחנו עושים על דעת עצמינו זה למתוח את הגבולות עד לנקודת ההתחממות שחזה המתכנן.
משם לקרר את המעבד בעזרת קירור חיצוני מסיבי יותר מזה שהמעבד דורש כשהוא יוצא מהמפעל בתדר X.
כלומר מומלץ להשקיע בקירור קצת יותר טוב כדי להגיע לתוצאות שהם משמעותיות (משמעותי זה 15% הפרש ביצועים).
אבל כל זה לא רלוונטי כשאתה לא מגיע לצוואר בקבוק במעבד והעוד 15% האילו ירימו לך את הראש מעל המים.
זה גם לא משהו שצפוי להגיע בזמן הקרוב למעבד שכזה אז אין יותר מידיי מה לרוץ אחרי K ולעשות לו OC בהשקעה מטורפת של כמעט אלפיה.
שמור כבר את הכסף הזה לטובת המחשב הבא.
ועוד דבר, לקחת I5K ולעשות לו OC זה אחד הדברים היותר דביליים ששמעתי. קח כבר I7 נורמלי וזהו.
אתה כלכך רוצה I7K ? תן תקציב תקבל. שוב זה לא דבר מומלץ ותאמין לי שCS לא דורש יותר מI3.
בקיצור מיותר. ..
SSD שאלת? 500 זה לא הרבה,קח תציץ בסרטון המצורף ותבין כמה שזה שווה את הכסף:
https://www.youtube.com/watch?v=6iBhf8rpobo
אגב זה השדרוג הכי משמעותי שניתן לעשות למחשב בתקציב הנמוך ביותר. זה פותר צוואר בקבוק מטורף (!) בקיצור חובה.
*ניתן לחסוך ולרכוש כונן 128G שיכיל רק את המערכת בלבד אבל אז טעינת משחקים לא תשתפר משמעותית גם היא וחבל .
darkonerxd
בקיצור מיותר. ..
אוקיי הבנתי,אם אתה אומר שזה יספק אותי במהלך השנים הקרובות אני אלך על זה.
עקב משהו משפחתי שנוצר בלילה אני אקנה את המחשב רק בקיץ,אתה חושב שהיו שינויים דרסטיים?
כניסת USB 2.0 נכנסת ב 3.0? יש לי מטען של פלאפון וגם יש לי כונן חיצוני של 2TB ואני רוצה שהוא ייכנס לזה.
וראיתי גם שהמעבד בא 3.6GHZ , וראיתי שיש דבר כזה MAX TURBO FRQ 4.0
מה זה אומר?
אם תוכל לסדר לי שוב את המפרט ורק במקום הכרטיס מסך ששמת להשים משהו שיישאר תמיד,כי אני לא הולך לקנות עכשיו את המחשב אז כנראה שהוא יימכר עוד כמה ימים(הכרטיס מסך) וגם להוסיף לי SSD.
באמת תודה רבה,ידעתי ששווה לעשות עוד בדיקה באיזה פורום אחר לראות הצעות אחרות :)
נערך על-ידי darkonerxd
לגבי הUSB יש תאימות לאחור ככה שלא תיהיה בעיה.
בסביבות מאי-ספטמבר יצאו מעבדי הדור החמישי(Broadwell) וכנראה בסביבות סוף השנה או יותר בטוח החל מתחילת שנה הבאה מעבדי הדור השישי(Skylake).
אגב furyanaor כמו שאני תמיד אומר אתה כרגיל לא ממש מבין הרי מה הקשר שמת את הלוח שיאיר הציע(Z87-Pro4) למפרט שפותח הדיון תכנן בכלל להמהיר דיי ברור שעשית את זה רק כי יאיר אמר במקום להשתמש בשכל וללכת על לוח אחר שיחסוך בשביל להפנות את התקציב לדברים אחרים, גם כן מפרט מהסרטים...
זה יהיה מפרט עדיף בתקציב דומה.
ספק בתקן 80+ Bronze עם נצילות גבוהה יותר.
HDD בנפח 1TB מדגם מומלץ יותר.
SSD בנפח 250GB.
HD7950 שממותג גם מחדש כR9 280 משומש עם שנה וחצי אחריות ב349ש"ח.
*המשלוח עם שליח חינם אצל TMS.
מעבד:
Intel Core i7-4790 3.6Ghz 4.0 Ghz Turbo LGA1150 Tray
כמות: 1 - מחיר: ₪1605
קירור למעבד:
Arctic Cooling Freezer i11
כמות: 1 - מחיר: ₪156
לוח אם:
Gigabyte GA-H81M-HD3 Front USB3
כמות: 1 - מחיר: ₪289
מארז:
בקניית מחשב חדש בלבד IPPON i04 case Gaming Beast Black with 2X 120mm fan + SS-500ET
כמות: 1 - מחיר: ₪393
זיכרון:
בקניית מחשב חדש בלבד - Hynix DDR3 8GB 1600
כמות: 1 - מחיר: ₪329
כרטיס מסך:
משומש אחריות שנה וחצי ברכישה עם מחשב חדש בלבד - Sapphire 7950 3GB GDDR5 Retail BULK DUAL X בקניית מחשב חדש בלבד
כמות: 1 - מחיר: ₪349
קשיח למחשב שולחני:
Seagate Barracuda 7200.14 1TB SATA3
כמות: 1 - מחיר: ₪295
קשיח למחשב שולחני:
Crucial SSD 250G BX100 MLC SATA3
כמות: 1 - מחיר: ₪519
כונן אופטי:
LG DVDRW X24 SATA
כמות: 1 - מחיר: ₪110
הרכבה:
הרכבת מערכת מחשב כולל בדיקות מלאות וחיווט ברמה גבוהה לחברי הפורומים חינם או בהזמנה מעל 3500 ש"ח - זמן הספקה בחנות עד 7 ימי עבודה
כמות: 1 - מחיר: ₪0
סה"כ: ₪4045
תשלום מזומן (תשלום מזומן לשליח, צ'ק מזומן, כסף שטרות, העברה בנקאית) מקנה 2% הנחה
מחיר אחרי הנחת מזומן הינו: 3965 ₪
http://www.tms.co.il/preview/spec/efyqx3d6
אם מנצלים את החריגה ועולים ל4200ש"ח אז אפשר לקחת את הMX100 ולעלות ללוח אם עם תמיכה בעד 32GB RAM יחד עם 6 חיבורי SATA3
מעבד:
קירור למעבד:
לוח אם:
MSI H87-G41 PC Mate
כמות: 1 - מחיר: ₪406
מארז:
זיכרון:
כרטיס מסך:
קשיח למחשב שולחני:
קשיח למחשב שולחני:
Crucial SSD 256G MX100 MLC SATA3
כמות: 1 - מחיר: ₪575
כונן אופטי:
LG DVDRW X24 SATA
סה"כ: ₪4218
מחיר אחרי הנחת מזומן הינו: 4134 ₪
http://www.tms.co.il/preview/spec/78yjpzrf
או רק עם MX100 וללא עלייה בלוח האם יצא לפני הנחת מזומן עם חריגה של 100ש"ח ולאחר הנחת מזומן כמעט בדיוק בתקציב 4019ש"ח
http://www.tms.co.il/pcbuilder/preview/1:13333:1/6:13144:1/2:13853:1/4:13506:1/3:14430:1/9:13090:1/20:11269:1/20:14508:1/11:7424:1/18:10042:1/
נערך על-ידי rony2
