פורסם 2005 בפברואר 1621 שנים מסתבר ש SLI עוזר רק במשחקים ש - NVIDIA החליטה\הואילה בטובה לאפשר לנו לשחק בהם ב SLI ולא SINGLE GPU MODE - חובה לקרוא.http://www.hardocp.com/article.html?art=NzExעוד מעניין - שרשימת המשחקים התומכים ב SLI שהיתה מימלא מצומצמת מאוד - נעלמה מהאתר של NVIDIA.רשימת המשחקים והאפלקציות שכן תומכים ב SLI:Aquamark3Battlefield 1942 Desert Combat Modbattlefield VietnamCity of HeroesCode Creatures ProColin McRae Rally 4 DemoCommand and Conquer: GeneralsDoom3FarCryGround Control 2Half-Life 2HaloPainkillerSims 2Star Wars: Knights of the Old RepublicTomb Raider: Angel of DarknessTron 2Unreal Engine 3Warhammer: Dawn of War3DMark2003 Gold3DMark2005 Goldומתוך הרשימה הזאת - יש 1 דמו, 4 בנצמרקים (הסרקזם צועק לשמיים) ומנוע משחקים שעוד לא נמצא בשימוש.ורק לחיזוק :http://graphics.tomshardware.com/graphic/20041123/sli-performance-05.html Quote: After several benchmark tests we noticed some relatively slow performance in two of our games. After turning on SLI HUD in the driver we saw that SLI was not active during these games. Even our efforts to force SLI operation through the expanded driver settings had no effect. After talking with NVIDIA we learned the cause: SLI is not available with some games. NVIDIA has so-called SLI Profiles for games that are defined in the driver. The driver recognizes the game via application detection and executes the SLI mode (split or balancing) designated for that profile. If no SLI profile exists for a game, there is no SLI rendering. It is not possible to force SLI mode or generate your own profile. According to NVIDIA however the driver already contains over 50 profiles for games running with SLI. For newer titles this therefore means that SLI system owners have to wait for a new driver. But even then there is no guarantee that SLI will be possible with a particular game. According to NVIDIA there are games that are simply not compatible with SLI. Microsoft's Flight Simulator 9 and Novalogic's Joint Operations for example both cause problems. As of the test date we were unable to find out the precise reasons why. NVIDIA only talks about frame buffering techniques used in games of this sort that are problematic for SLI. Of the 10 games we included in this test, two of them were non-SLI-compatible.http://www.extremetech.com/article2/0,1558,1735048,00.asp Quote: We also found out from nVidia that currently, the ForceWare SLI driver needs an application profile to be able to apply SLI acceleration. These take the form of an XML file that the driver reads when an application is launched. Under this current model, if a new game shipped tomorrow that could benefit from SLI, nVidia would make available on its nZone Web site an XML-based profile that you could download, and when that game's EXE was launched, the driver would read in the new XML profile, and be able to run the game using SLI. nVidia pointed out that this profile-based architecture is a transitional solution, and that these app profiles would go away in an upcoming driver release early next year.http://www.anandtech.com/video/showdoc.aspx?i=2284 Quote: Surprisingly enough, throughout all of our testing, we didnt encounter any rendering issues in SLI mode. NVIDIA insists that they have tested quite a few of the top 100 games to ensure that there arent any issues with SLI mode and it does seem that theyve done a good job with their driver. If the driver hasnt been profiled with a game, it will default to single-GPU mode to avoid any rendering issues, but the user can always force SLI mode if they wish.HardOcp's own guide: http://www2.hardocp.com/article.html?art=Njk2LDI= Quote: SFR and AFR describe how SLI is being done in a particular game. Most new games will allow SFR to be done. This allows both video cards to share the workload of any single frame shown on the screen. However, some games do not play friendly with SFR and there require AFR. With AFR, each card draws every other full frame. AFR is not as efficient as SFR in most cases, but does solve some issues when SFR does not output the desired image. Profiles are set up in the driver to help selection of the appropriate mode and should be invisible to the user. That said, it will be very likely that SLI users need to update their driver set as newer games are purchased. It will be interesting to see how this works out.EDIT: took this from a post at Beyond3D
פורסם 2005 בפברואר 1621 שנים בקיצור sli לא שווה את כל הוצאת סכומי הכסף המיותרים האלה של 200-400 שקל הפרש בלוח ועוד 1000-3000 שקל על עוד כרטיס מסך..במקום לקנות 2 של 6600gt ב sli פשוט לקנות 6800 gtאו ultraאחד ולסגור ענייןובאותו סכום תקבלו ביצועים בכל משחק שיש בלי מגבלות
פורסם 2005 בפברואר 1621 שנים מחבר בשביל לדעת איזה משחקים כן נתמכים (מאחר ו NVIDIA לא מפרסמים זאת) - ניתן לפתוח את הקובץ הנ"ל ולבדוק:C:\WINDOWS\system32\nvapps.xml - (במידה ואתם משתמשים בכרטיסי GEFORCE למיניהם - אז הקובץ קיים במערכת).
פורסם 2005 בפברואר 1621 שנים סלחו לי על הבוטות אבל שווה לתחת כל עניין ה sli הזה (בינתיים,אני מקווה שזה ישתפר)
פורסם 2005 בפברואר 1621 שנים מסתבר ש SLI עוזר רק במשחקים ש - NVIDIA החליטה\הואילה בטובה לאפשר לנו לשחק בהם ב SLI ולא SINGLE GPU MODE - חובה לקרוא.עוד מעניין - שרשימת המשחקים התומכים ב SLI שהיתה מימלא מצומצמת מאוד - נעלמה מהאתר של NVIDIA.נו אז מה??איפה פה ההולכה שולל?הרשימה היתה קיימת באתר שלהם מזמן ואם היתה טורח לקרוא קצת באתר שלהם ולא לרוץ ולחפש בנצ'ים אז היתה יודע את זה כי היא פורסמה באתר שלהם עוד לפני שהSLI הגיעו לחנויות בכלל.סתם חבל שאתה משמיץ...דרך אגב, אני באופן אישי חושב שSLI זה קישקוש שלא תורם כלום אבל לפחות אני לא טוען שהוליכו אותי שולל..
פורסם 2006 בפברואר 2720 שנים שלום לכולם, אני אוהב את ה-SLI שלי, אני אפילו מאוד אוהב את ה-SLI שלי.עדכונים יוצאים כל שבוע וNVIDIA מתאימה לאט לאט את עצמה לכ-ו-ל-ם.אז למה לזרוק האשמות של הולכת שולל - הרי שציינתם שהייתה רשימה שNVIDIA פרסמה.למיטב זכרוני HALF-LIFE 2 הולך יד ביד עם ATI עוד מיום ההכרזה והוא הגיע אפילו עם רכישת כרטיס ATI.ואם HL2 תומך בSLI של NVIDIA אז על מה הרעש? על Worms?! תאמינו לי שהרשימה הזו כבר לא אקטואלית בגרוש.וכמו שציינתי במפרט המחשב שלי, ה-SLI שלי הביא לי ציון של 7498 ב-3dmark06.והוא מריץ לי את Battlefield 2, NFS:MW ו-HL2 על המקסימום ....אז, אני מאושר.
פורסם 2006 בפברואר 2720 שנים מר כתום היקר,שים לב לעובדה שהקפצת דיון משנת 2005 (?!). אין לי מושג מדוע עשית את זה שכן הנושא לא אקטואלי.אני רואה שאתה משתמש חדש, קרא בבקשה את חוקי הפורום. כמו-כן, קיבלת אזהרה 1 מתוך 3.
