how far will athlon Xp go??
simple math - since Xp can get 18 multiplier and model number goes up a 1000
evrey 0.5 increse in clock multiplier...
which means it will get to model 3100
and were not even talking about AMD pumping the FSB to 150 or 166
and the next Ali chip set for socet A will be able to run with an Xp cpu that has
166MHZ (DDR) FSB and 166MHZ (DDR) DDR-Sdram
my quistion is can Xp ran at 18 multiplier and higher FSB? like - 17 * 166 or 18 *166 ??
