whats holding my oc back
i have a p4p800 mobo and p4 2.4c
and after i raise more then 220 mhz fsb it starts freezing and shit like that
i also tried to raise the voltage from 1.52 to 1.58 and it didnt help either
whats wrong?
did you try memory divider?
what kind of memory are you using?
memory divider? whats that?
im using twimos 3200 256x2 ddr
my ram voltage is at 2.85 and i cant increase it more for some reason and vcore is at 1.58
timings are at 2.5-3-3-6
try to pot the timming on 2-2-2-5
maby it will help...
how can tighter timing help him to achive higher fsb
:kopfpatsch:
your memory is ddr 400
when you rise the fsb the memory frequency is rising too
you should use divider like 166/200
to reduce the memory frequency
