Asus A8N SLI + A64 3000+ Overclocking
Got my new system assembled last week and I couldn't help but start overclocking right away.
Asus A8N SLI
A64 3000+ 939
Albatron 6600GT (Not overclocked yet)
ADATA PC4000 256x2
Goal was to find apart the highest CPU speed (with and withouth adding voltage) and the highest FSB and then combine them in the best way that complements the memory aswell. Currently the memory is holding me back from running a higher FSB 1:1 (not to mention the timings are horrible). I'm hoping to bring some G.skill PC4400 TCCD from the US soon.
The maximum FSB the motherboard did stabely was 295 which is quite good, especially after all of the rumors that the A8N series is bad for overclocking.
The CPU does 2500 mhz on default voltage, rock solid after 8 hours of Prime 95 and 9 hours of World of Warcraft.
With overvolting to 1.650v (maximum the board can give) I can reach 2600 mhz but that comes with an increase of about 12 degrees and I'm currently still using the stock cooler.
The temperatures according to the Asus monitoring program are 36c idle and about 47c load @ 2500 mhz.
Benchmark results:
3Dmark 2005: 3490
3Dmark 2003: 8293
To conclude, a pic:
:xyxthumbs:
יפה מאוד, דרך צלחה בהמשך.
אצלי ב2500 עם NEO2 עושה 34 שניות
36 נראה גבוה קצת
אבל תוצאה יפה בכל זאת
That's cause you have 512x2 and not 256x2, a gig of RAM drops atleast 1 second compared to 512.
Also, you may have been running better timings at the time, Super Pi is effected by memory speed/quantity.
הגודל לא משפיע המהירות כן
התזמונים אצלי הם על 2.5-3-3-7
אחלה אוברקלוק
זה רק אני או שאתה על 2T?
The size certainly has an imapct, I tested 512x2 compared to 256x2 (old memory review) and 512x2 was always 1 second faster.
Yea, it's 2T, I haven't even began tweaking the timings yet, that's just a headache. I'm not sure I'll even bother since I don't intend to stay with this mem much longer.
nice work :)
the scores r a bit low, try to set your aperture size to 256mb for 3dmark scores
לא רע, עדיין לא גילית את הפוטנציאל האמיתי שטמון במעבדי ה-3000+ wini...
עם זכרונות איכותיים אני מאמין שהיית יכול להגיע ל-300 באס, מה גם שאתה עומד על 2T זה הרבה פחות איכותי מבחינת תוצאת ה-FSB...
נפלת על מעבד לא רע שסוגר 2500 על מתח מקורי - זה אומר שיש לך עוד לאן לשאוף...
האם ביטלתה את אפשרות peg root control כי אמרו לי שביטול הpeg גורם ליציבות
I unsynced the mem and moved to 1T, 2.5-3-3-10 1T now, better performance than synced with crappy timings.
I can't move further than 2500 without adding voltage and I'd rather wait with that till I get some better cooling.
I'll test if the board can reach a higher FSB if I cancel PEG thingie, thanks for the tip.
Once I get rid of these ADATA and get those G.skill TCCD I excpect much better results.
