The PC reboot itself, urgent problem
Well i'm writing in English since my Hebrew on my pc dosen't work on some places(i can read here Hebrew, can't write).
So after two great years with my great PC he suddenly started to reset itslef every once and a while,
but it's not just that, he can be on for hours, but when i turn the Counter Strike , or any other game, on it let me play for 10-60 min' and then reset itself, afterwards he keeps reseting itself until i close him and wait for a few min.
I didn't have that problem before its just in the past days.
I formated him, scanned for trojans, did scan disk or any other program.
so it might be hardware problem, so please give ur ideas what can i do
and if you decide to help please be specific in the problem, if i need a software link me and so on.
Thanks ahead, Matan.
overheating ?
שיט הקדמת אותי...
(הוא אמר שהוא יכול לקרוא, אין סיבה לא לכתוב בעברית)
Yes i can read hebrew...
well "over heating" dosent say to me anything besides the obvius..
so if you can explain what i need to do to stop it?
מה שאתה צריך זה לבדוק את התחממות המחשב תוריד את התוכנה SPEEDFAN ממדור ההורדות ודווח לנו פה מה הטמפ ואז נציע פתרון
Well i dont know what to look excatly so i tell you everything.
it looks like this:
Left side list:
Fan01: 3125 RPM
Fan02: 0 RPM
Fan03: 0 RPM
Right side list:
Temp2:57 C
Temp3:36 C
HD0: 35 C
Temp:1 25 C
above:
CPU usage - from 1.5% to 6%
HELP ME :D
And don't forget it does reset only when i play games , mainly CS.
If im just on the interent(sites,ICQ,porn :) ) it dosent do anything
its impossible to determine if the cpu heat is at fault without knowin what cpu you have
download cpu-z and take a screenshot - http://www.cpuid.com/download/cpu-z-126.zip
anyway i believe the psu is at fault cuz it only happens on games when the graphic card takes more power ,check the voltages ,what graphic card you have and what psu (and i dont mean just watt's give the model name) ?
edit - i explained on another thread how to add hebrew support to winxp you might wanna check it out http://www.hwzone.co.il/community/index.php?topic=94362.msg797698#msg797698
For the Hebrew,still didn't help :\
here's the shot:
and after i opned some programs it shows me this look:
and again, only when i play games like HL or CS :\
guys it's kinda urgent, i show u what i have...
i dont know what is "psu" and i really need to get this problem fixed
PSU = power supply unit (sapak :) )
it looks like its either the CPU or the motherboard getting heated up, if you know how, then remove the CPU fan
and give it a good clean - ONLY if you know how. northwood p4 shouldn't get that heated up, and so does the motherboard.
also check if the case is getting enough air intake, if the comp is pressed to a corner, the air coming inside is limited,
try running those games when the case is wide open, and well-chilled
good luck with that, post any progress
באמת נראה שזו בעית התחממות רצינית - לי יש P4 עם אותה ליבה והוא עובד אצלי על 26 מעלות ב IDLE (אבל יש לי 10 מאוררים :smile1: ) מה שאתה צריך לבדוק זה בעיקר האם גוף הקירור על המעבד יושב טוב ואם לא לחזק את הישיבה שלו באיזו שהי דרך או להוריד אותו ולהעביר בו ניקוי רציני.
First of all thank you for your help.
Secondly, i dont know how to remove the CPU ;\ , ill try to open the sides and give him more air,atough he is quite ok :|.
and i dont know how to check if the "guf kirur" is placed right on the proccesor ;\
and i really need to get it fix, im playing CS for cash too and i need it ;D
אתה צריך לבדוק שגוף הקירור יושב נכון כלומר נסה ללחוץ עליו או לנסות להזיז אותו (לא ביותר מדי כח) אם בוא זז יבכלל אז הוא לא יושב נכון
Dude, the only "guf kirur" that i know is the mekarer :D
try to explain better to a computer newb
