שאלה לגבי לוח אם, האם הוא טוב?
שלום, ברצוני לשמוע את דעתכם על הלוח שברשותי (אגב קניתי אותו לפני שנה, בינואר), אנא, השקיעו כמה דקות של קריאה אם כי אני השקעתי כמעט שעה של העתקה מהחוברת כאשר אני מאד עייף!
תודה על ההבנה והרצון לעזור!  :xyxthumbs:
Mainboard Specifications:
865PE Neo2 MS-6727 ATX Mainboard
CPU
>Supports Intel P4 Northwood/Prescott (Socket)478 processors.
>FSB 400 (for Northwood only), 533, 800MHz, depending on the integrated North Bridge.
>Supports up to 3.6GHz or higher speed.
Chipset
>Intel 865PE/G chipset
     -Supports FSB 800/533/400MHz
     -Supports AGP 8X interface.
     -A Gigabit Ethernet (GbE) controlleris supported through the CSA (Communications Streaming Architecture) interface.
     -Supports DDR 400/333/266 memory interface
>Intel ICH5/ICH5R chipset
     -Hi-Speed USB (USB2.0) controller, 480Mb/sec, 8 ports.
     -2 Serial ATA/150 ports.
     -2 channel Ultra ATA 100 bus Master IDE controller.
     -PCI Master v2.3, I/O APIC.
     -Supports both ACPI and legacy APM power management.
     -Serial ATA/150RAID 0 (Optional).
Main Memory
>Supports four underbuffed DIMM of 2.5 Volt DDR SDRAM.
>Supports up to 4GB memory size without ECC.
>Supports Dual Channel DDR266/333/400MHz and up.
Slots
>One AGP slot supports 8x/4x at 0.8V (AGP 3.0) or 4x at 1.5V (3.3V is not supported).
>Five 32-bit v2.3 Master PCI bus slots (support 3.3v/5v PCI bus interface).
On-Board IDE
>Dual Ultra DMA 66/100 IDE controllers integrated in ICH5/ICH5R.
     -Supports PIO, Bus Master operation modes.
     -Can connect up to four Ultra ATA Drives.
>Serial ATA/150 controller integrated in ICH5/ICH5R.
     -Up to 150MB/sec transfer speeds.
     -Can connect up to two Serial ATA drives.
     -Supports SATA RAID . (Optional).
Promise 20378 On-Board (Optional)
>Supports Ultra ATA, Serial ATA, Ultra ATA RAID 0 or 1, Serial ATA RAID 0 or 1, Ultra/Serial ATA RAID 0+1 supported.
>Connect up to 2 Serial ATA devices and 2 Ultra ATA 133 devices.
On-Board Peripherals
>On-Board Peripherals include:
     -1 floppy port supports 2 FDDs with 360k, 720k, 1.2M, 1.44M and 2.88Mbytes
     -1 serial port COM1, 1 VGA port (for 865G only) (Optional)
     -1 parallel port supports SPP/EPP/ECP mode
     -8 USB 2.0 ports (Rear * 6/Front * 2 or Rear * 4/ Front * 4)
     -1 Line-In/Line-Out/Mic-In port
     -1 RJ LAN jack (Optional)
     -3 IEEE 1394 pinheaders (Optional)
Audio
>6 channels software audio codec C-media 9739A.
     -Compliance with AC97 v2.2 Spec.
     -Meet PC2001 audio performance requirement.
     - Can support SPDIF Out via S-Bracket only.
LAN (Optional)
>Intel 82547EI(CSA interface)/Intel 82562EZ Dual layout.
     -Integrated Fast Ethernet MAC and PHY in one chip.
     -Supports10Mb/s, 100Mb/s and 1000Mb/s (1000Mb/s only for Intel 82547EI).
     -Compliance with PCI 2.2.
     -Supports ACPI Power Management.
BIOS
>The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatially.
>The Mainboard provides a Desktop Management Interface (DMI) function which records your mainboard specifications.
Dimension
>ATX Form Factor: 30.5 cm (L) x 24.4 cm (W).
Mounting
>9 mounting holes.
מה יש כבר להגיד? שבזבזת הרבה זמן על העתקה במקום פשוט לתת לינק לאתר היצרן?
הלוח מבוסס 865pe, שזה אחלה, וזהו
הנך מתכנן לרכוש מחשב חדש עם מעבד חדש או לשדרג רק את הלוח כאשר המעבד קנוי כבר?
לא, כתבתי שקניתי אותו לפני שנה, פשוט רציתי לדעת אם הלוח טוב, איכותי ואמין?
תודה! :)
לוח מצויין.
חחח העתקה אני חושב שהוא עשה העתק הדבק וזהו..ואחלה לוח.
