help with hebrew in linux
hello everybody
i need help with 2 things
1. how do i save settings and accounts in hardisks while using Mandrake-Move(=Live CD)
2. how do i install hebrew support in Mandrake-Move? and where can i find it
10x
Omri
I don't think you can save the settings on a live cd.
ok.. 10x
but where can i get hebrew support?
ofcourse you can save settings from a live cd to a disk... i dont know how to do it in manrdake-move but you can check here
http://mandrakeusers.org/lofiversion/index.php/t21037.html
also... try using knoppix is has a builtin script which can save configuration to hard disk and also install it on HD if you want
for hebrew support, i dont know ....
  • 2 שבועות מאוחר יותר...
אם תתקין את המערכת למחשב שלך בתהליך ההתקנה אני חושב יש מספר שפות לבחירה ככה לפחות זה בFEDORA .
