im buying a new pc and i need your help
hi so at last im buying a new pc!!!
so in cristmas im buying a new pc and i wanted you to build mea pc in about 2000-3000 canadian dolars
and i want that the pc will be for big and havy games but also for internet music and movies
a and by the way if you can give me an advice about a good computer store in canada and if some body knows "winnipeg" (if you want an internet store is fine too i guese...)but if its a relyable one!!!
k thanx any way
bye
ASUS A8V DELUXE MOTHERBOARD ATHLON64 S939 K8T800PRO DUAL DDR AGP 5PCI SATA 1394 SOUND 1000LAN [176.70]
AMD ATHLON 64 FX-55 PROCESSOR S939 2.6GHZ 1MB CACHE RETAIL BOX [1127.74]
THERMALRIGHT XP-90 S478/754/939 92MM ALUMINUM HEATPIP COOLER *FAN NOT INCLUDED* [50.18]
SILENX 14DBA SILENT CASE FAN 92MM 2000RPM 36CFM 3/4PIN [24.17]
CREATIVE SOUND BLASTER AUDIGY 2 ZS 7.1 1394 PCI RETAIL BOX [116.97]
OCZ DUAL CHANNEL OPTIMIZED PLATINUM 2X512MB DDR PC3200 HEAT SPREADER REV.2 CL 2-2-2-5 [388.50]
CHAINTECH APOGEE GEFORCE 6800 GT 256MB DDR3 AGP8X VGA DVI-I TV OUT VIDEO CARD [540.71]
HITACHI DESKSTAR 7K250 SATA 160GB HARD DRIVE SERIAL ATA 8MB 7200RPM OEM [132.59]
NEC ND-3500A DVD+-RW 16X4X16 DUAL LAYER+R 4X INT IDE OEM W/ SW BEIGE [94.01]
BENQ 1650S 16X DVD-ROM INT. IDE BEIGE W/ SW OEM [36.77]
1.44 MB High Density Floppy Drive [9.23]
ANTEC NEOPOWER 480W POWER SUPPLY ATX12V PS/2 DUAL 12V RAILS ACTIVE PFC W/ DETACHABLE OUTPUT CABLES [149.02]
THERMALTAKE TSUNAMI VA3000 ALUMINUM CASE 4X5.25 2X3.5 5X3.5INT NO PS SILVER MIRRORED [147.20]
subtotal: 2993.79 CAD
from www.ncix.com
the motherboard should be rev 2 at least according to a customer review but you should verify it,ask em if it's revision 2,only rev2 supports fx55 and have a working pci/agp lock
extremly strong cpu,1gb great overclocking ram,high quality sound card/superb gfx card/dvdrw/
here some reviews
athlon fx 55
http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2249
http://www.hexus.net/content/reviews/review.php?dXJsX3Jldmlld19JRD04ODgmdXJsX3BhZ2U9MQ==
http://www.amdzone.com/modules.php?op=modload&name=Sections&file=index&req=viewarticle&artid=70&page=1
http://www.sharkyextreme.com/hardware/cpu/article.php/3424131
http://www.hardocp.com/article.html?art=Njc1LDE=
OCZ PC3200 EL Platinum Revision 2
http://www.3dvelocity.com/reviews/ocz3200/ocz3200.htm
http://www.cluboverclocker.com/reviews/memory/ocz/3200el_rev2/
http://www.hardcoreware.net/reviews/review-240-1.htm
geforce 6800 gt (not the chaintech one but they all have same performance)
http://www.nvnews.net/reviews/evga_geforce_6800gt/index.shtml
http://www.vr-zone.com/?i=1317&s=1
http://www.hardocp.com/article.html?art=NjM3
http://www.xbitlabs.com/articles/video/display/leadtek68u.html
audigy 2 zs
http://www.guru3d.com/article/sound/120/
http://www.techspot.com/reviews/hardware/audigy2zs/index.shtml
http://www.extremetech.com/article2/0,3973,1383335,00.asp
http://www.games-fusion.net/content/000296.php
thermaltake tsunami dream case
http://www.rbmods.com/Articles/Thermaltake/Tsunami/1.php
http://www.techtastic.ca/reviews3/tsunami.html
http://www.a1-electronics.net/Cases/2004/Thermtake_Tsunami_July.shtml
http://www.envynews.com/index.php?ID=691
http://www.overclockercafe.com/Reviews/cases/Tt_Tsunami/
http://www.vr-zone.com/?i=1087&s=1
http://www.fastlanehw.com/reviews.php?i=132
http://reviews.pimprig.com/cases/thermaltake_tsunami_dream_case.php
antec neopower 480w
http://www.datafuse.net/neopower.php
http://www.cluboverclocker.com/reviews/power/antec/neopower/page1.htm
http://www.legitreviews.com/article.php?aid=120
http://www.ascully.com/modules.php?name=Reviews&rop=showcontent&id=404
http://www.silentpcreview.com/article177-page1.html
http://www.bjorn3d.com/read.php?cID=705
:xyxthumbs:
פששששששששששש רון איזה השקעה!!!! :yelclap: :yelclap: :yelclap: :yelclap: :xyxthumbs: :xyxthumbs: :xyxthumbs:
yes!!!
thank you very much but do i really need so powerfull CPU does it realy worth it???
and is it a good RAM memory?
and i dont think i need a dual layer the medias are too expencive right?
and i sad this pc is for gaming porpuses so is the video card is enought to run even the haviest games??
and i repeat the question somebody know a store in "winnipeg"k
thanx anyway
bye
thank you very much
you welcome :yelclap:
you can settle for less powerfull cpu but its worth it if you can afford yourself
yeah,read the reviews
at the moment they are expensive but that may change in the future
you dont have to buy dl medias,it also supports regular ones not just dl
and like any other dvdrw it can also be used for writing cdr's
yes
cant help with that one,you might wanna check the yellow pages
תודה על המחמאה :smile1:
and i have one more question whats better one 6800 GT or 2 6600 GT (with SLI technology)?k
thanx
bye
what is it GT ??
thanx but say in these reviews the 6600GT is with 128mb or is there with 256mb?
thanx
bye
k and one more question what should i buy 2 6600GT with 256mb each or one 6800GT or 2 or 6800 ultra
whats gives the best preformance and the best value?
thanx
bye
Motherboards with SLI are not available (not in canada also), and one 6800GT is better than 2 6600GTs. Also, one 6800GT is more than enough for any game in the next 2 years. Regarding the CPU - I'd take a 3800+ and a good water cooling system or a 3500+ and a Vapochill LS, and OC it much higher than what the FX-55 will give you on air.
until which point i can push the 3500+with an OC and how cuse im not so good at this
what should i conceder?
thanx and bye
I think the 3500+ will go up to 2.8-3.0 at least with a vapochill. But on the other hand an fx-55 on air will do that too, where you get from there is usually a matter of luck. The fx has an open multiplier and 400Mhz more, which help it. other than that you can't really tell.
Looking again at the budget and prices, I think this will give you the best combination:
AMD ATHLON 64 3500+ S939 PROCESSOR NEWCASTLE 2.2GHZ 512KB CACHE RETAIL BOX - $355.53
MSI K8N NEO2 PLATINUM NFORCE3 ULTRA S939 AGP 5PCI SATA 1394 SOUND 1000LAN MOTHERBOARD - $189.24
OCZ DUAL CHANNEL OPTIMIZED PLATINUM 2X512MB DDR PC3200 HEAT SPREADER REV.2 CL 2-2-2-5 - $388.50
MAXTOR DIAMONDMAX 10 250GB HARD DRIVE 7200RPM 9MS 16MB ATA133 OEM - $223.44 (for the cache)
SAPPHIRE RADEON X800 XT 256MB AGP8X VGA DVI-I TV OUT VIDEO CARD RETAIL BOX - $659.40
NEC ND-3500A DVD+-RW 16X4X16 DUAL LAYER+R 4X INT IDE OEM W/ SW BLACK - $94.01
ANTEC NEOPOWER 480W POWER SUPPLY ATX12V PS/2 DUAL 12V RAILS ACTIVE PFC W/ DETACHABLE OUTPUT CABLES - $149.02
And that case:
Kit-Tronics Mach 2 with Enlight 7238 Case #3020
- Gives you a Mach 2 (Which is very similar to Vapochill) and a case fit to hold it.
Together everything is 2917$ CAD
BTW - There's one more thing to consider - the Mach 2 will stay for years to come. the FX will get old in a couple of years.
hey
so i have a question is this case is noisey?because it looks like a monster!!!
and whats better to buy a radeon or a geforce?for havy games ofcource
and one last question what do you mean by mach 2?
thanx
bye
Big doesn't mean noisy...
It's just a case which was specially fit to hold a Mach 2.
the Mach 2 is a bit noisy, I don't know if it will disturb you:
Noise Level App. 35 db(A) at normal operation, 40dbA during start-up
Mach 2 is just like Vapochill, only from a different manufacturer.
And both the 6800ultra and the X800XT are great cards, it doesn't really matter which one you take.
If you want complete silence, I can give you specs for a watercooled computer.
