Need Help in getting good codec pack.
right now i am using LH-codec Pack which is nice, but allmost all of the moviez that i watching at looks not completely smooth, can someone help me ?
Thanks alot! :)
K-Lite Codec Pack
Where can i download it ?
Did you try it allready ?
Edit:
Should i un-install the LH codecs before installing the new codec pack ?
Thanks again. :)
try to mix with the FFDSHOW codak
this kodad may cost alot of problams
Can you please rewrite the message, its not clear.
Thanks! :)
search with google to find K-lite codec pack
and you dont need to uninstall LH codec pack
k-lite mega codec pack
>>> DEFILER PACK <<<
Nimo Codec Pack
look at this:
http://www.hwzone.co.il/community/index.php?topic=87632.0
תעיף את החבילת מקודדים הגרועה הזאת !! (הכוונה לאוסף המקודדים של ליונטוורק)
http://www.doom9.org/software.htm
כנס לשם
תחפש את Gordian Knot Codec Pack 1.8
יש שם את כל מה שאתה צריך
בנוסף לכך
תתקין את הקודק LAME ACM בגירסה האחרונה (3.משהו...)
I am not sure that i need all the codecs that its contain, and btw, can you explaine why one codec is better than the other ?
BTW, whats wrong with LH codec pack, it contains AC3 filter, LameACM, and other needed codecs.
so what makes the different between the different codecs that you rcommended ?
Thanks! :)
