פורסם פברואר 12פברואר 12 Review | Ugoos X5M Pro Amlogic S905x5m Android 14 TV Ugoos X5M Pro is a TV box based on Amlogic S905X5M chipset, which is one of the new budget chipsets from Amlogic (no VCC/H.266 support for instance). This box is similar if not identical to it’s older brothers from X4 family (reviewed here in the past), and the specs are simply upgraded. Aside for BT 5.4, the included IR/BT Remote control also functions as a air mouse (saving you a few bucks).
הצטרפ/י לדיון
