יצירת עץ אלמנטים של דף HTML באמצעות C#
יש לי את הקוד הבא:
מחלקת HtmlElement:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
namespace p2
public class HtmlElement
public string id { get; set; }
public string name { get; set; }
public List<string> attributes { get; set; }
public List<string> classes { get; set; }
public string innerHtml { get; set; }
public HtmlElement parent { get; set; }
public List<HtmlElement> children { get; set; }
public HtmlElement()
attributes = new List<string>();
classes = new List<string>();
children = new List<HtmlElement>();
public override string ToString()
return "["+"id: "+id+", name: "+name+", attributes: "+attributes.ToString()+", classes: "+classes.ToString()
+", innerHtml: "+innerHtml+", parent: "+parent+", children: "+children.ToString()+" ]";
מחלקת HtmlHelper:
using System;
using System.Linq;
using System.Text;
using System.Text.Json;
namespace p2
public class HtmlHelper
private readonly static HtmlHelper instance = new HtmlHelper();
public static HtmlHelper Instance => instance;
public string[] openCloseTags { get; set; }
public string[] openTags { get; set; }
public HtmlHelper()
openCloseTags= JsonSerializer.Deserialize<string[]>(File.ReadAllText("seed/HtmlTags.json"));
openTags = JsonSerializer.Deserialize<string[]>(File.ReadAllText("seed/HtmlVoidTags.json"));
Program:
using p2;
using System.Text.RegularExpressions;
var html = await Load("https://hebrewbooks.org/beis");
var cleanHtml = new Regex(@"\s+").Replace(html, " ");
var htmlLines = new Regex("<(.*?)>").Split(cleanHtml).Where(s => !string.IsNullOrWhiteSpace(s)).ToList();
var htmlE = "<div id=\"my-id\" class=\"my-class-1 my-class-2\" width=\"100%\">text</div>";
var attributes = new Regex("([^\\s]*?)=\"(.*?)\"").Matches(htmlE);
//HtmlHelper a = new HtmlHelper();
//Console.WriteLine();
Console.ReadLine();
var handler = new HttpClientHandler();
async Task<string> Load(string url)
HttpClient client = new HttpClient();
var response = await client.GetAsync(url);
var html = await response.Content.ReadAsStringAsync();
return html;
//בניית העץ
HtmlElement root = new HtmlElement();
root.name = htmlLines[0];
root.parent = null;
HtmlElement tElement = new HtmlElement();
string tempElement;
string pattern = @"(\w+)=[""']?([^""' >]+)[""']?";
List<string> allTags = new List<string>();
foreach (var tag in HtmlHelper.Instance.openTags)
allTags.Add(tag);
foreach (var tag in HtmlHelper.Instance.openCloseTags)
allTags.Add(tag);
for (int i = 1; i < htmlLines.Count; i++)
var l = htmlLines[i].Split(" ");
tempElement = l[0];
if (tempElement == "/html")
break;
if (tempElement[0] == '/')
tElement = tElement.parent;
else
if (tempElement == "html")
HtmlElement obj = new HtmlElement();
obj.name = tempElement;
obj.parent = root;
root.children.Add(obj);
tElement = obj;
else
if (allTags.Contains(tempElement))
obj.parent = tElement;
var strLine = htmlLines[i].Substring(tempElement.Length);
MatchCollection maches = Regex.Matches(strLine, pattern);
foreach (Match m in maches)
obj.attributes.Add(m.Groups[1].Value);
if (m.Groups[1].Value == "class")
foreach (var v in m.Groups[2].Value.Split(" "))
obj.classes.Add(v);
else if (m.Groups[1].Value == "id")
obj.id = m.Groups[2].Value;
tElement.children.Add(obj);
if (HtmlHelper.Instance.openCloseTags.Contains(tempElement))
tElement = obj;
break;
else
tElement.innerHtml = htmlLines[i];
HtmlElement ht = root;
Console.ReadLine();
כל הזמן נופלת לי שגיאה שה-root שלי null, וגם כל אוביקט מסוג HtmlElement הוא null
כלומר יש איזה שגיאה בקוד.
הצטרפ/י לדיון
אורח
הוסף תגובה
