פינגים לא עקביים?
אני מחובר בכבלים לבזק בינלאומי. מחשב יחיד, ללא חייגן. ברקע כמה חלונות אקספלורר ופיירוול. שמתי לב שקפיצות בפינגים. אומנם לא גבוהות, אבל אני מאמין שהן משמעותיות יחסית ומשפיעות על איכות החיבור. להלן התוצאות:
Pinging hwzone.co.il [212.199.164.181] with 32 bytes of dat
Reply from 212.199.164.181: bytes=32 time=9ms TTL=55
Reply from 212.199.164.181: bytes=32 time=16ms TTL=55
Reply from 212.199.164.181: bytes=32 time=11ms TTL=55
Reply from 212.199.164.181: bytes=32 time=10ms TTL=55
Reply from 212.199.164.181: bytes=32 time=12ms TTL=55
Reply from 212.199.164.181: bytes=32 time=37ms TTL=55
Reply from 212.199.164.181: bytes=32 time=18ms TTL=55
Reply from 212.199.164.181: bytes=32 time=13ms TTL=55
Reply from 212.199.164.181: bytes=32 time=35ms TTL=55
Reply from 212.199.164.181: bytes=32 time=27ms TTL=55
Reply from 212.199.164.181: bytes=32 time=40ms TTL=55
Reply from 212.199.164.181: bytes=32 time=14ms TTL=55
Reply from 212.199.164.181: bytes=32 time=21ms TTL=55
Reply from 212.199.164.181: bytes=32 time=39ms TTL=55
Reply from 212.199.164.181: bytes=32 time=20ms TTL=55
Reply from 212.199.164.181: bytes=32 time=38ms TTL=55
Reply from 212.199.164.181: bytes=32 time=28ms TTL=55
Reply from 212.199.164.181: bytes=32 time=19ms TTL=55
Reply from 212.199.164.181: bytes=32 time=30ms TTL=55
Ping statistics for 212.199.164.181:
    Packets: Sent = 50, Received = 50, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 9ms, Maximum = 40ms, Average = 15ms
Pinging a.co.il [192.116.202.58] with 32 bytes of data:
Reply from 192.116.202.58: bytes=32 time=13ms TTL=244
Reply from 192.116.202.58: bytes=32 time=11ms TTL=244
Reply from 192.116.202.58: bytes=32 time=36ms TTL=244
Reply from 192.116.202.58: bytes=32 time=12ms TTL=244
Reply from 192.116.202.58: bytes=32 time=14ms TTL=244
Reply from 192.116.202.58: bytes=32 time=34ms TTL=244
Reply from 192.116.202.58: bytes=32 time=10ms TTL=244
Reply from 192.116.202.58: bytes=32 time=35ms TTL=244
Reply from 192.116.202.58: bytes=32 time=20ms TTL=244
Ping statistics for 192.116.202.58:
    Packets: Sent = 25, Received = 25, Lost = 0 (0% loss),
    Minimum = 10ms, Maximum = 36ms, Average = 14ms
מה לדעתכם יכולה להיות הבעיה?
נסה לנטרל את הפיירוול לחלוטין (אם זה נורטון, ניטרול הפיירוול לחלוטין = הסרה שלו מהמחשב לצערי). לפעמים הם גורמים לבעיות בפינגים או לאיטיות לא מובנת.
בנוסף, אם אתה רוצה שהבדיקה שלך תהייה מהימנה, כדאי שתעשה אותה כששום דבר (אדם/מחשב/אפליקציה) לא משתמש בחיבור באותו זמן. כל שימוש כזה יכול להשפיע על הבדיקה.
אם אחרי שני הדברים האלה אתה עדיין חווה את הבעייה, נסה לדבר עם הספקית שלך ולספר להם על זה (יכול להיות שזה יעזור, למרות שבד"כ הם לא מסוגלים להודות שהבעייה אצלם ולא אצל משתמש הקצה).
