cod ghosts עם כרטיס מסך GeForce GT 640
לפי אתר can you run it - לא אוכל להריץ את המשחק כי זה מתחת למינימום.
מה אתם אומרים?
[TABLE=width: 650]
[TR]
[TD]red_x.gif[/TD]
[TD=class: details-grp-name, bgcolor: #ECEEF5]VIDEO CARD[/TD]
[/TR]
[/TABLE]
[TABLE=width: 619]
[TR]
[TD][TABLE=width: 615]
[TR]
[TD][TABLE=class: details-table]
[TR]
[TD]Minimum: NVIDIA GeForce GTS 450 / ATI Radeon HD 5870 or better[/TD]
[/TR]
[TR]
[TD=class: you-have-text]You Have: GeForce GT 640[TABLE]
[TR]
[TD]drivers-updates.gif[/TD]
[TD]Click here for the latest Video Card drivers.[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=colspan: 2]Upgrade Suggested[/TD]
[TD=align: center][TABLE=class: noborder]
[TR]
[TD]bars_67-79.png[/TD]
[/TR]
[TR]
[TD]69th percentile[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[TR=class: a-row analysis-row]
[TD=colspan: 3][TABLE]
[TR]
[TD]Features: Minimum attributes of your Video Card[/TD]
[/TR]
[TR=class: details-row]
[TD][TABLE=class: sub-details-tbl]
[TR]
[TH=class: sub-details-tbl-th][/TH]
[TH=class: sub-details-tbl-th]Required[/TH]
[TH=class: sub-details-tbl-th]You Have[/TH]
[/TR]
[TR=class: sub-details-row]
[TD]green_checkmark_small.gif[/TD]
[TD]Pixel Shader version[/TD]
[TD]5.0[/TD]
[TD=class: you-have-text]5.0[/TD]
[/TR]
[TD]Vertex Shader version[/TD]
[TD]5.0[/TD]
[/TR]
[TD]Dedicated Video RAM[/TD]
[TD]1024 MB[/TD]
[TD=class: you-have-text]2.0 GB[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
זה כרטיס חלש. (ויקר ממש!)
אתה תריץ, על הגדרות נמוכות מאוד.
מה שאר המחשב ומה רזולוציית המסך?
נערך על-ידי Ymac
[TABLE=class: section, width: 476]
[TR]
[TD=class: primary-title, align: right]Processor[/TD]
[TD=class: value]Intel® Core i5-4440 CPU @ 3.10GHz[/TD]
[/TR]
[/TABLE]
[TR]
[TD=class: primary-title, align: right]Video Card[/TD]
[TD=class: value]NVIDIA GeForce GT 640[/TD]
[/TR]
[/TABLE]
[TR]
[TD=class: primary-title, align: right]Memory[/TD]
[TD=class: value]8.1 GB[/TD]
[/TR]
[/TABLE]
[TR]
[TD=class: primary-title, align: right]Operating System[/TD]
[TD=class: value]Microsoft Windows 7 Home Premium Edition Service Pack 1 (build 7601), 64-bit[/TD]
[/TR]
[/TABLE]
הרזולוציה 1440 על 900
תודה על התשובה!
אז מה נראה לך, באופן כללי?
כדאי או לא?
נערך על-ידי udiitai
מה כדאי?
מה רזולוציית המסך שלך?
לחילופין הדגם שלו.
המסך [h=1]Dell U2312HM[/h]
הרזולוציה של המסך שלך היא FHD 1920/1080P
אם הכרטיס כבר קיים אצלך, האפשרות היחידה היא לרכוש אחר או לשחק איתו ברזולוציה פחותה.
אם עדיין לא, אל תרכוש אותו.​ יש אחרים יותר טובים.
תודה!
ממה שבדקתי קצת, הכרטיסים הטובים יותר מגיעים כבר לסקאלות של 700 ש"ח ומעלה...
יש המלצות למשהו יותר טוב באזור המחיר של 500 ש"ח?
רק צריך ספק מתאים, 500W איכותי ומעלה.
הייתי מסתכל גם ביד2 ובמדור היד שנייה של האתר, יש מציאות בתקופה הזאת.
היי, המון תודה!
אני למעשה כבר קניתי את המחשב, אבל החנות תהיה מוכנה להחליף לי את הכרטיס באחר, בגלל שעבר ממש מעט זמן.
הוא מציע:
geforcegtx 750
או geforce gtx 750 ti (יקר יותר)
מה אתם אומרים על הדגמים?
אני את הלקחים על כרטיס מסך כבר למדתי:
1. בדקתי די בשטחיות את הדרישות של המשחק לפני שקניתי את המחשב ולא הבנתי שיש הבדל מהותי בין GTS / GTX / GT
2. לקנות רכיבים יקרים כמו כרטיס מסך בנפרד - במחשב הבא (נראה איך ירוץ כל עניין הגיימינג אחרי שיהיו ילדים...).
2 שאלות נוספות:
1. אני מחפש משחקי FPS מפחידים, סגנון DOOM או QUAKE (מול חייזירם, מפלצות וכו'), מה יש חדש וטוב?
2. רכישה בסטים - הגיוני שזה עולה יותר יקר מאשר הזמנה מחנות אינטרנטית מישראל? בסטים COD GHOSTS עולה בערך 204 ש"ח ומצאתי בזאפ ב-150 ש"ח -
מה הקטע? סטים לא אמור להיות זול יותר תמיד?
נערך על-ידי udiitai
לא, אך הוא זול הרבה פעמים.
אין GTS בכרטיסי מסך כבר הרבה זמן.
GTX750 TI חזק משמעותית.
למה לא לבטל לגמרי כרטיס מסך ובהפרש לקנות בנפרד משהו משתלם יותר?
כי כבר קניתי והמחשב כבר אצלי ועובד... וחוץ מזה, אם אקנה בנפרד אני לא יודע להרכיב ולהתקין.
אני מניח שזה שטויות, אבל אני לא יודע אם בא לי להתעסק עם זה.
בקיצור... אין כאן שאלה.
