צריך עזרה עם hotbox log
אהלן. מהבוקר hotbox לא עובד טוב (עובד כמה דקות ואז אין רשת), כיביתי והפעלתי מחדש מספר פעמים, וכל פעם זה מציג בLOG:
ניסיתי לכבות wireless ובלי רשת אלחוטית עובד יותר טוב. מה יכולה להיות הבעיה?
Tue May 14 09:52:31 2013 Error (4) SW upgrade Failed before download - File not Present
Tue May 14 09:52:14 2013 Error (4) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=2c:e4:...
Tue May 14 09:52:14 2013 Error (4) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=2c:e4:...
Tue May 14 09:52:14 2013 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC...
Tue May 14 09:52:02 2013 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:e4:12:eb...
Tue May 14 09:51:22 2013 Warning (5) B-INIT-RNG Failure - Retries exceeded;CM-MAC=2c:e4:12:eb:4f:c...
Tue May 14 09:51:22 2013 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:e4:12:eb...
Tue May 14 09:50:34 2013 Critical (3) Received Response to Broadcast Maintenance Request, But no Un...
Tue May 14 09:50:27 2013 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC f...
Tue May 14 09:50:14 2013 Warning (5) MDD message timeout;CM-MAC=2c:e4:12:eb:4f:c6;CMTS-MAC=00:12:4...
Tue May 14 09:50:13 2013 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC f...
Tue May 14 09:50:08 2013 Warning (5) MDD message timeout;CM-MAC=2c:e4:12:eb:4f:c6;CMTS-MAC=00:12:4...
Tue May 14 09:50:07 2013 Critical (3) SYNC Timing Synchronization failure - Failed to acquire FEC f...
Tue May 14 09:50:01 2013 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Tue May 14 09:48:47 2013 Error (4) SW upgrade Failed before download - File not Present
Tue May 14 09:48:30 2013 Error (4) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=2c:e4:...
Tue May 14 09:48:29 2013 Error (4) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=2c:e4:...
Tue May 14 09:48:29 2013 Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC...
Tue May 14 09:48:20 2013 Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:e4:12:eb...
Tue May 14 09:47:33 2013 Critical (3) Received Response to Broadcast Maintenance Request, But no Un...
Tue May 14 09:47:00 2013 Critical (3) Started Unicast Maintenance Ranging - No Response received - ...
Tue May 14 09:45:07 2013 Error (4) SW upgrade Failed before download - File not Present
Tue May 14 09:44:50 2013 Error (4) Missing BP Configuration Setting TLV Type: 17.9;CM-MAC=2c:e4:...
Tue May 14 09:44:50 2013 Error (4) Missing BP Configuration Setting TLV Type: 17.8;CM-MAC=2c:e4:...
Time Not Established Warning (5) DHCP WARNING - Non-critical field invalid in response ;CM-MAC...
Time Not Established Critical (3) No Ranging Response received - T3 time-out;CM-MAC=2c:e4:12:eb...
Time Not Established Warning (5) B-INIT-RNG Failure - Retries exceeded;CM-MAC=2c:e4:12:eb:4f:c...
Time Not Established Critical (3) Received Response to Broadcast Maintenance Request, But no Un...
Time Not Established Critical (3) DHCP FAILED - Request sent, No response;CM-MAC=2c:e4:12:eb:4f...
נערך על-ידי Zeev86
