1 TB HARD DISK
לא הייתי מתנגד לכמה כאלו
http://www.lacie.com/products/product.htm?id=10118
Bigger Disk
Unprecedented 1 terabyte capacity
User Benefits :
Unique triple interface solution
FireWire 800, FireWire and USB 2.0 hard drive
Sturdy aluminum alloy design
Stackable desktop or rackmount configuration
largest capacity available
The LaCie Bigger Disk, with the largest hard drive capacity available, is a unique innovation that packs an amazing 1 terabyte of storage space in a manageable 5.25" form factor. With this unsurpassed storage capacity, the LaCie Bigger Disk allows users to store nearly two years of continuous music and up to one month of non-stop MPEG-2 video1. Truly plug and play, this device requires no driver or software installation for Windows XP and Mac OS X users. triple interface solution
Built with a unique triple interface solution, the LaCie Bigger Disk can be connected to any computer equipped with FireWire 800, FireWire 400, iLink/DV, Hi-Speed USB 2.0 or USB 1.1, making it the most universal drive ever. The FireWire 400 port can be used to conveniently chain a DV camera to your computer for direct digital video capture. The LaCie Bigger Disk can also be daisy chained to most storage, audio and video devices to achieve even greater storage capacity.
digital video, audio, 3D imaging
The LaCie Bigger Disk is ideal for demanding projects such as archiving image banks and 3D images, storing large desktop publishing files, and editing digital audio and uncompressed digital video. Hot-pluggable with immediate device recognition, this drive can be easily shared and its data quickly exchanged among computers and workstations. With such an unbelievably-large capacity, the LaCie Bigger Disk is also ideal for large-scale backup among multiple users without causing network congestion. stylish, metallic design
The LaCie Bigger Disk was created with a sturdy, aluminum design that dissipates heat. A drive stand provides stability and allows for upright desktop use to save valuable desk space, while an optional rack-mounting kit enables versatile configuration in standard 19-inch racks. Minimizing noise when the drive is not in use, this drive features a convenient, automatic on/off feature that conserves energy and prolongs the life of the drive. Stackable to provide a uniform look, the LaCie Bigger Disk is also compatible with Kensington-type locks for added security, at home or away.
1Calculations are based on 4 MB per 4-minute song, 1GB/hour of MPEG-2 compressed video and 13GB/hour of uncompressed DV video.
This product is expected to ship in mid February
לא הייתי מתנגד לאחד או לחצי ממנו
תגידו מישהו יכול להגיד לי את הסדר של כל הדברים (מגהבייט , ג'יגה בייט , טרהבייט וכו'....)
הכוונה מה יש אחרי זה(יש עוד אני רק לא זוכר.)
בייט , קילו בייט , מגה בייט , ג'יגה בייט, טרה בייט, פטה בייט
אני לא חושב שצריך עוד
כבר אמרו דברים כאלו לגבי הרבה דברים במחשבים, כולם טעו.
הכונן הזה פשוט בנויי ממערך RAID עם בקר שנמצא בתוך הקופסא.
עדיף לקנות 4x250GB ולצאת יותר בזול.
וגם יותר בטוח,תארו לעצמכם הארדיסק אחד כזה ענק,נגמר האחריות ויש לכם bad sectors מפה עד להודעה חדשה.
תקרא שוב מה שאמירם כתב..
זה רק 931 גיגה :(
691 ג"ב יותר ממה שיש לי כרגע.
לא היה מזיק לי יוטה בייט אחד...
