לינוקס אובונטו וממיר דיגיטלי dvb-t usb
קיבלת הודעות ארור ב sudo make install ?
מה שבדקת עכשו - ה USB היה מחובר למחשב בזמן הבדיקה ? אם לא אז תבדוק כשהוא מחובר
Apr 15 07:54:46 fox-linux rsyslogd: [origin software="rsyslogd" swVersion="4.2.0" x-pid="621" x-info="
http://www.rsyslog.com"] rsyslogd was HUPed, type 'lightweight'.
Apr 15 07:54:46 fox-linux kernel: [254971.247348] __ratelimit: 26 callbacks suppressed
Apr 15 07:54:46 fox-linux kernel: [254971.247354] type=1502 audit(1334465686.747:42): operation="mknod" pid=7955 parent=1 profile="/usr/sbin/nmbd" requested_mask="c::" denied_mask="c::" fsuid=0 ouid=0 name="/var/run/samba/namelist.debug"
Apr 15 07:54:46 fox-linux kernel: [254971.247376] type=1502 audit(1334465686.747:43): operation="open" pid=7955 parent=1 profile="/usr/sbin/nmbd" requested_mask="wc::" denied_mask="wc::" fsuid=0 ouid=0 name="/var/run/samba/namelist.debug"
Apr 15 07:54:46 fox-linux kernel: [254971.382354] type=1502 audit(1334465686.880:44): operation="truncate" pid=7955 parent=1 profile="/usr/sbin/nmbd" requested_mask="w::" denied_mask="w::" fsuid=0 ouid=0 name="/var/run/samba/namelist.debug"
Apr 15 07:54:46 fox-linux kernel: [254971.382383] type=1502 audit(1334465686.880:45): operation="open" pid=7955 parent=1 profile="/usr/sbin/nmbd" requested_mask="wc::" denied_mask="wc::" fsuid=0 ouid=0 name="/var/run/samba/namelist.debug"
Apr 15 19:16:20 fox-linux kernel: [295864.728044] usb 1-2: new high speed USB device using ehci_hcd and address 18
Apr 15 19:16:20 fox-linux kernel: [295864.866691] usb 1-2: configuration #1 chosen from 1 choice
Apr 15 19:16:20 fox-linux kernel: [295864.874564] input: Afa Technologies Inc. AF9035A USB Device as /devices/pci0000:00/0000:00:1d.7/usb1/1-2/1-2:1.1/input/input17
Apr 15 19:16:20 fox-linux kernel: [295864.874754] generic-usb 0003:15A4:1001.000F: input,hidraw0: USB HID v1.01 Keyboard [Afa Technologies Inc. AF9035A USB Device] on usb-0000:00:1d.7-2/input1
Module Size Used by
nls_utf8 1069 0
ums_cypress 2058 0
usb_storage 40033 1 ums_cypress
isofs 29250 0
udf 78785 0
crc_itu_t 1371 1 udf
binfmt_misc 6587 1
rfcomm 33453 0
sco 7949 0
bridge 45646 0
stp 1655 1 bridge
bnep 9436 0
l2cap 30656 4 rfcomm,bnep
nfsd 238775 11
lockd 64881 1 nfsd
nfs_acl 2245 1 nfsd
auth_rpcgss 33767 1 nfsd
sunrpc 193609 10 nfsd,lockd,nfs_acl,auth_rpcgss
exportfs 3437 1 nfsd
fbcon 35102 71
tileblit 1999 1 fbcon
font 7557 1 fbcon
bitblit 4707 1 fbcon
softcursor 1189 1 bitblit
vga16fb 11385 0
vgastate 8961 1 vga16fb
tuner_simple 13577 1
tuner_types 14233 1 tuner_simple
wm8775 2873 1
tda9887 9589 1
snd_intel8x0 25652 2
snd_ac97_codec 100646 1 snd_intel8x0
ac97_bus 1002 1 snd_ac97_codec
snd_pcm_oss 35308 0
snd_mixer_oss 13746 1 snd_pcm_oss
tda8290 12092 0
snd_pcm 70694 3 snd_intel8x0,snd_ac97_codec,snd_pcm_oss
snd_seq_dummy 1338 0
tuner 20412 2
snd_seq_oss 26722 0
cx25840 25839 1
snd_seq_midi 4557 0
snd_rawmidi 19056 1 snd_seq_midi
snd_seq_midi_event 6003 2 snd_seq_oss,snd_seq_midi
snd_seq 47263 6 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_seq_midi_event
snd_timer 19130 2 snd_pcm,snd_seq
radeon 678831 2
snd_seq_device 5700 5 snd_seq_dummy,snd_seq_oss,snd_seq_midi,snd_rawmidi,snd_seq
ivtv 137807 0
ttm 49847 1 radeon
cx2341x 12469 1 ivtv
v4l2_common 15431 5 wm8775,tuner,cx25840,ivtv,cx2341x
drm_kms_helper 29329 1 radeon
snd 54244 14 snd_intel8x0,snd_ac97_codec,snd_pcm_oss,snd_mixer_oss,snd_pcm,snd_seq_oss,snd_rawmidi,snd_seq,snd_timer,snd_seq_device
videodev 34457 5 wm8775,tuner,cx25840,ivtv,v4l2_common
drm 163779 4 radeon,ttm,drm_kms_helper
ppdev 5259 0
psmouse 63677 0
i2c_algo_bit 5028 2 radeon,ivtv
v4l1_compat 13251 1 videodev
tveeprom 11102 1 ivtv
soundcore 6620 1 snd
parport_pc 25962 1
serio_raw 3978 0
intel_agp 24375 1
snd_page_alloc 7076 2 snd_intel8x0,snd_pcm
btusb 11053 0
bluetooth 49892 5 rfcomm,sco,bnep,l2cap,btusb
shpchp 28835 0
agpgart 31724 3 ttm,drm,intel_agp
lp 7028 0
parport 32635 3 ppdev,parport_pc,lp
usbhid 36110 0
hid 67288 1 usbhid
e100 28211 0
mii 4381 1 e100
floppy 53016 0
אלו התוצאות שהסטיק מחובר
וכן אחרי קיבלתי הודעת ארור גם עם sudo
תעיף את התוכנה אם make remove ו make clean בדומה לאיך שהתקנת אותה, ואז make ותן לראות את ההודעות
fox@fox-linux:~$ cd AF9035
fox@fox-linux:~/AF9035$ make remove
echo -e "\nRemoving old /lib/modules/2.6.32-40-generic/kernel/drivers/media/dvb/dvb-usb/ files:"
-e
fox@fox-linux:~/AF9035$ make clean
make -C /lib/modules/2.6.32-40-generic/build SUBDIRS=/home/fox/AF9035 modules
/usr/src/linux-headers-2.6.32-40-generic/scripts/gcc-version.sh: line 25: gcc: command not found
/usr/src/linux-headers-2.6.32-40-generic/scripts/gcc-version.sh: line 26: gcc: command not found
make[1]: Entering directory `/usr/src/linux-headers-2.6.32-40-generic'
/usr/src/linux-headers-2.6.32-40-generic/arch/x86/Makefile:81: stack protector enabled but no compiler support
make[1]: gcc: Command not found
CC [M] /home/fox/AF9035/af903x-core.o
/bin/sh: gcc: not found
make[2]: *** [/home/fox/AF9035/af903x-core.o] Error 127
make[1]: *** [_module_/home/fox/AF9035] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-2.6.32-40-generic'
make: *** [default] Error 2
נקרא מה הודעת השגיאה הראשונה אומרת (השגיאות הבאות הן בדרך כלל תוצאה של השגיא הראשונה):
תוכנת ה Make מנסה להריץ את gcc אל ידיי הפקודה gcc ,אבל אין פקודה כזאת. למה ?
הפקודה gcc מריצה את הקומפיילר gcc. אם אין פקודה כזאת זה אומר שהוא לא מותקן במחשב
ברוב המערכות לינוקס קיים pack שמתקין את gcc וכלים נוספים שצריך כדיי לקמפל תוכנות אל המחשב. באובונטו ה pack הזה נקרא build-essential ואתה יכול להתקין אותו דרך מנהל ההתקנות
אם התקנת אותו ובמנהל ההתקנות gcc עדיין מופיע כלא מותקן. תתקין גם אותו ידנית
שניהם מופעים שמותקנים
איך אני מתקין את זה דרך השורת פקודה
ידנית = דרך מנהל ההתקנות
תעיף ותתקין את כל אלה מחדש : build-essential gcc make
עשיתי גם את זה וזה לא שינה כלום
הסטיק הזה יועבר למחשב שמישתמש ב ווינדוס 7
איזה סטיק נתמך הכי טוב בלינוקס ?
תכתוב gcc ותבדוק אם הוא כותב fatal error no input file (כלומר : gcc מותקן ואמור לעבוד) או command not found (כלומר : יש בעיה אם gcc)
הבעיה נראית לי כמו פאק של gcc
לא יצא לי להכיר סטיקים של DVB T - הכרטיס טלויזיה PCI הישן שיש לי עובד כמו שהוא לי שהתקנתי דרייבר מיוחד
רושם
no input files
תוריד את הדרייבר מחדש לתיקיה חדשה ותעשה את הכול עד ה make (כולל) אבל לא כולל ה make install. תעתיק את מה שהוא כותב
בנוסף תתייעץ ב whatsup.co.il ו ubuntu-il.org יתכן שיוכלו לעזור לך יותר. תפרט מה השגיאות ותן להם לינק לכאן שייראו מה כבר הספקנו לבדוק
כבר שאלתי בשניהם
אני ירד מזה
אני יחפש אחד שניתמך יותר
תודה על כל העזרה
דונגלים מבוססים ציפ AF9015 כמו שיש לך, עובדים באובנטו עוד מגרסה 8.10 (*עם קצת עבודה ופאטצ'ים). עם איזה גרסה של אובנטו אתה עובד?
אם תצליח להשיג אחד מבוסס ציפ של אינטל CE6230, הוא יעבוד לך בלי שום התחכמויות. את שלי קניתי ב EBAY .
