Skyrim Better Performance
This .dll will make your game run like Oblivion.
You runned oblivion on max settings? and Skyrim only on High or Medium with lags?
This file is for you!
You can jump from Medium to Ultra in less than 1 minute!
I was encountering lags on High settings with old .dll file, So i maked this one and now i play Skyrim on High settings without any lags!
Before i used this dll. my auto detect settings set game to MEDIUM quality after repleacing .dll auto detect settings set game to HIGH quality.
Also my FPS went up over by 10.
Possible Fix for "The Glowing Eye Glitch" - Some dude told this fixed that glitch for him.
IMPORTANT: You will need program called "WinRar" to unpack archive.
IMPORTANT: If your PC can run Skyrim on High or Ultra settings i suggest to do not use this file, however some peoples could run Skyrim on High and with this mod they now play game on ultra.
I have permissions from Boris.V creator of ENB Series.
Here is received email from Boris when i asked about editing second .dll
Image: http://i44.tinypic.com/erblux.jpg
2nd Dll is using materials from ENB Series by Boris Vorontsov.
He is credited.
This works with both Ati and Nvidia.
It allows transparency AA so trees and grass will look much better if you have AA turned On.
Confirmed by (shuriken200) First .dll works with XFX Radeon HD 5770
INSTALLATION!
1. Unpack archive called "Skyrim Performance for Nvidia" with WinRar.
2. Make backup of your original d3d9.dll file - IMPORTANT
3. Copy d3d9.dll File to your Skyrim folder.
It goes in your regular game folder not in the "data" folder with the mods.
If you placed .dll file in right place launcher will re-scan settings, and you will have to set them again how you want.
BUGS!
- Launcher Bug: d3d9.dll file will change name of your Graphic Adapter in settings.
I have Nvidia GeForce9600GT and after repleacing .dll file, in options i see GeForce 8800 GS instead of my real Graphic Adapter name - THIS REALLY DOESN'T MATTER!
- Many peoples might get crash with Crossfire or SLI
- usually crashes with XFIRE possible fix for this - In Xfire go to Tools>options>'game' tab and click on the checkbox "Disable Xfire in game"
UNINSTALLING!
1. It does not change any files!
Just delete .dll file you downloaded and place the old one.
NOTES:
- Make sure you are running the launcher or .exe shortcut as administrator if you have crash when launching.
- This isn't lowering your Graphics!
- I play game with AA on - some ppl's asking if it works with AA on.
- If you don't have d3d9.dll in your game folder don't worry!
Just place my .dll in game folder and if you will want to uninstall it just simply delete it, but it's still unexplained why some ppl's dont have this file in game folder.
- I highly recommend to lower Anisiotropic Filtering because it might lag pretty much.
- Mod might don't work on some Graphic Cards from GTX series and others.
Still don't know why it's not working i will try to fix this.
- Mod is not compatible with any other that replaces d3d9.dll
- If you have issues, try updating your official DX runtime first from Microsoft, a quick google search for "DirectX End User Runtime" will get you what you need.
- DX is card/driver agnostic, so it should run on any card, though the particular optimization in this likely favors older nVidia cards of the pre G200 cores, so 9000 and 8000 series.
If you have performance issues, instead of using this mod turn off AA and use FXAA.
In the game launcher you can find this advanced option. It is a post process (after rendering) algorithm that removes jagged edges without much loss of fidelity or framerate.
http://www.skyrimnexus.com/downloads/file.php?id=123
נראה שהמוד נמחק מסקיירים נקסוס, אז העלתי אותו כאן: http://www.mediafire.com/?40l6vu0enbymnn5
מבדיקה שלי שהמוד באמת עוזר ולמי שיש מחשב יחסית חלש הייתי אומר שזה די חובה...
במקרה שלי היתי צריך עוד להעסק קצת בINI ולשנות כמה הגדרות ידנית, אבל עכשיו אני יכול לשחק כמו שצריך וברזולוציה נורמלית.
בהצלחה, וכמובן שאני לא לוקח אחריות אם משהו יתקלקל ;)
*ואם לשניה חשבתם כך, אז לא, המוד הזה לא שלי... מצאתי אותו ברשת והרגשתי צורך לשתף
  • 2 שבועות מאוחר יותר...
יש שם למוד הזה? כי הקובץ ישן וכבר לא באתר, והייתי רוצה לנסות.
המוד לא נתמך יותר.. אם המשחק שלך מעודכן - אי אפשר להתקין את המוד כי העדכון שבר את המוד.
יש שניים אם תרצו:
http://www.skyrimnexus.com/downloads/file.php?id=131
http://www.skyrimnexus.com/downloads/file.php?id=1013
השני זה בגלל שהמשחק לא תומך ביותר מ2GB(רשמית הם לא אמרו כלום אבל בפועל המשחק תומך רק ב2GB RAM) אז שווה להוריד גם תשני
אני עכשיו יפרסם אשכול של מודים שניסיתי היום(האומנם רק היום המשחק התחיל לפעול לי לראשונה כי הייתה לי בעיות הרצה איתו אבל ניסיתי את כל המודים ותאמינו לי שווים הורדה)
מבאס...
בכל זאת אני יעלה אותו למי שרוצה (ונשאר בגרסה הישנה) כשאני יגיע הביתה...
omerbr אם אני מבין נכון המוד הראשון בא לשפר גרפיקה ולא בהכרח ביצועים...
מבאס...
אהה שמע אם אתה רוצה ביצועיים טובים יותר כנס לאשכול מודים שלי יש שם כמה חוץ מזה תוריד את ה4GB זה יעזור במידה מסויימת
אם מישהו צריך, העלתי את הקובץ פה: http://www.mediafire.com/?40l6vu0enbymnn5
omerbr זאת המטרה של הת'רד שלי... ונראה לי שאני אנסה את המוד של ה4GB, נראה אם הוא יעזור לי במשהו...
מנסיון שלי יש שיפור מסוים בביצועים עם המוד- במקומות שיש הרבה מים בד"כ היו לי לאגים וזה טיפל בזה.
בנוסף אחרי עדכון 1.2 היו לי קריסות בגלל המודים המותקנים, אחרי שהתקנתי מחדש את המוד של ה4GB הוא תיקן את זה, כנראה בזכות הlauncher העצמאי שמגיע איתו:
ניסיתי לשים את המוד אחרי עדכון המשחק ולא נראה שיש איזה קריסות או דברים כאלו ואחרים, אבל נראה שהוא לא כל כך עוזר - לא ממש עובד...
מה שכן המוד של ה 4GB עוזר ממש קצת...
מעניין.
נבדוק :)
טוב ניסיתי את המוד.
אני חייב לציין שאכן רואים שיפור בביצועים, אבל השיפור בגרפיקה לא רציני.
יש לי Q6600 עם 4 גיגה זיכרון ו4870 כ.מסך וזה לא כזה נורא להישאר בלי המוד.
מצד שני גם התקנתי הרבה מודים אחרים - העיקרי שמוסיף המון זה המוד של המים REAL WATER TEXTURE MEDIUM שעושה עבודה מדהימה.
הוא עובד לך עם גרסה 1.2?
אצלי הוא מותקן ואני לא שם לב לשיפור בביצועים לעומת הגרסה הקודמת של המשחק, שראיתי שיפור משמעותי...
:facepalm:
Performance != Graphics
זה כמו שתגיד ששידרגת ל GTX580 אבל אין שיפור בגראפיקה.
ציטוט מהמוד עצמו "You can jump from Medium to Ultra in less than 1 minute!"
והוא מציין שזה ללא יותר הרעה בביצועים.
אז אולי לא הסברתי את עצמי כמו שצריך.
התכוונתי לזה שלא רואים את השיפור בגרפיקה לפי מה שכתוב.
אם שמים את המוד ומגדירים גרפיקה באיכות יותר גבוהה, עדיין הביצועים לא משהו.
  • 3 שבועות מאוחר יותר...
מכירים את TESV Acceleration Layer ?
http://forums.guru3d.com/showpost.php?p=4200832&postcount=688
This patch will improve your framerate by up to 40% in all CPU-dependent situations, ie, especially in cities.
It works mostly by rewriting some x87 FPU code inlining and a whole ton of useless getter functions along the critical paths because the developers at Bethesda, for some reason, compiled the game without using any of the optimization flags for release builds.
For those wary of downloading this plugin because it was made ​​by an unknown author, do not worry, it was actually ianpatt (one of the main developers of SKSE) who actually compiled the plugin from source provided by the original author of the optimization code .
