מחפש דרייבר ל-Win98SE
VIA Tech 3038 PCI to USB Universal Host Controller
תודה.
ניסית את
http://download.driverguide.com/driver/VIA+Tech+3038+PCI+to+USB+Universal+Host+Controller/Samsung/d130082.html
אפשר להוריד מפה:
http://www.4shared.com/file/HOLjCMpG/c10_all_drv.html
אם לא עובד תנסה:
"Disable all integrated USB controllers in BIOS so that you are not forcing the Intel USB controller to use VIA drivers by mistake. Install latest VIA driver for USB2.0 chips:v2.70p (OCT2005)
Remove/uninstall USB controllers in Device Manager and allow the system to redetect/reinstall the VIA hardware and drivers. After the VIA hardware and drivers are installed properly, enter BIOS and enable integrated USB controllers again."
