עזרה בהתקנת גרסת ניסיון פוטושופ CS5 ...
אני מתקין גרסת CS5 תומכת עברית
על מערכת WIN 7 ULTIMATE
לא מצליח לסיים את ההתקנה.מקבל הודעת שגיעה
מצרף קובץ.
תודה על העזרה מראש
(נ.ב.- העלאה של דרמוב)
דוח שגיאות:
Exit Code: 6
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 45 error(s), 42 warning(s)
WARNING: The payload: Adobe Photoshop CS5 Core {545421F8-F4B3-40D2-9418-9D4EA9A73905} requires a UI parent with following specification:
Family: Photoshop
ProductName: Adobe Photoshop CS5 Core_x64
This parent relationship is not satisfied, because this payload is not present in this session.
WARNING: OS requirements not met for {545421F8-F4B3-40D2-9418-9D4EA9A73905}
WARNING: Payload cannot be installed due to dependent operation failure
ERROR: MsiConfigureProductEx failed with error: 1612
ERROR: The following payload errors were found during install:
ERROR: - Adobe CSXS Infrastructure CS5: Install failed
ERROR: - Microsoft_VC90_ATL_x86: Install failed
ERROR: - Adobe Media Player: Install failed
ERROR: - Microsoft_VC90_CRT_x86: Install failed
ERROR: - Adobe Bridge CS5: Install failed
ERROR: - Microsoft_VC80_ATL_x86: Install failed
ERROR: - Adobe XMP Panels CS5: Install failed
ERROR: - Photoshop Camera Raw: Install failed
ERROR: - AdobeColorCommonSetCMYK: Install failed
ERROR: - Adobe Mini Bridge CS5: Install failed
ERROR: - Adobe Photoshop CS5 Core: Failed due to Language Pack installation failure
ERROR: - AdobeColorJA CS5: Install failed
ERROR: - Adobe ReviewPanel CS5: Install failed
ERROR: - Microsoft_VC90_MFC_x86: Install failed
ERROR: - Adobe Linguistics CS5: Install failed
ERROR: - PDF Settings CS5: Install failed
ERROR: - DeviceCentral: Install failed
ERROR: - AdobeTypeSupport CS5: Install failed
ERROR: - AdobeColorVideoProfilesCS CS5: Install failed
ERROR: - AdobeColorCommonSetRGB: Install failed
ERROR: - Adobe CSXS Extensions CS5: Install failed
ERROR: - AdobeOutputModule: Install failed
ERROR: - Microsoft_VC80_CRT_x86: Install failed
ERROR: - Adobe Photoshop CS5 International English Language Pack_AdobePhotoshop12-en_GB: Install failed
ERROR: - Adobe WinSoft Linguistics Plugin CS5: Install failed
ERROR: - AdobeColorEU CS5: Install failed
ERROR: - AdobePDFL CS5: Install failed
ERROR: - AdobeCMaps CS5: Install failed
ERROR: - AdobeColorNA CS5: Install failed
ERROR: - Required Common Fonts Installation: Install failed
ERROR: - Adobe SwitchBoard 2.0: Install failed
ERROR: - Microsoft_VC80_MFC_x86: Install failed
ERROR: - AdobeColorPhotoshop CS5: Install failed
ERROR: - Microsoft_VC80_MFCLOC_x86: Install failed
ERROR: - Recommended Common Fonts Installation: Install failed
ERROR: - Adobe Extension Manager CS5: Install failed
ERROR: - AdobeJRE: Install failed
ERROR: - Adobe ExtendScript Toolkit CS5: Install failed
ERROR: - Adobe Photoshop CS5 Support: Install failed
ERROR: - Adobe AIR: Install failed
ERROR: - Suite Shared Configuration CS5: Install failed
ERROR: - WinSoftMEsti: Install failed
תנסה להרים אליהם טלפון מחר בבוקר.
