ייעוץ בקניית דיסק קשיח חיצוני 3.5" 1000/1500TB
HD Tune Pro: Samsung G3 Station Information
Firmware version : 1AG01118
Serial number : S292JD1Z801158
Capacity : 1500.3 gB (1397.3 GB)
Buffer size : 33553920 bytes
Sector size : 512 bytes
Standard : ATA/ATAPI-7 - SATA II
Supported mode : UDMA Mode 6
Current mode : UDMA Mode 6
Avergae speed : 76 MB/s
Rotation speed : -
S.M.A.R.T : yes
48-bit Address : yes
Read Look-Ahead : yes
Write Cache : yes
Host Protected Area : yes
Device Configuration Overlay : yes
Firmware Upgradable : yes
Automatic Acoustic Management: yes
Power Management : yes
Advanced Power Management : yes
Interface Power Management : yes
Power-up in Standby : yes
Security Mode : yes
SCT Tables : yes
Native Command Queuing (NCQ) : no
Trim : no
Volume : SAMSUNG (G:)
Capacity : 1430796 MB
Free : 1430434 MB
Usage : 0%
File system : NTFS
Serial : D839-BB3D
Alignment : 32 KB
HD Tune Pro: Samsung G3 Station Health
ID Current Worst ThresholdData Status
(01) Raw Read Error Rate 100 100 51 0 ok
(03) Spin Up Time 71 71 11 9420 ok
(04) Start/Stop Count 100 100 0 11 ok
(05) Reallocated Sector Count 100 100 10 0 ok
(07) Seek Error Rate 253 253 51 0 ok
(08) Seek Time Performance 100 100 15 0 ok
(09) Power On Hours Count 100 100 0 17 ok
(0A) Spin Retry Count 100 100 51 0 ok
(0B) Calibration Retry Count 100 100 0 0 ok
(0C) Power Cycle Count 100 100 0 6 ok
(0D) Soft Read Error Rate 100 100 0 0 ok
(B7) (unknown attribute) 100 100 0 0 ok
(B8) End To End Error Detection 100 100 0 0 ok
(BB) Reported Uncorrectable Errors 100 100 0 0 ok
(BC) Command Timeout 100 100 0 0 ok
(BE) Airflow Temperature 76 76 0 403767320 ok
(C2) Temperature 68 68 0 537985056 ok
(C3) Hardware ECC Recovered 100 100 0 42155 ok
(C4) Reallocated Event Count 100 100 0 0 ok
(C5) Current Pending Sector 100 100 0 0 ok
(C6) Offline Uncorrectable 100 100 0 0 ok
(C7) Ultra DMA CRC Error Count 100 100 0 0 ok
(C8) Write Error Rate 100 100 0 0 ok
(C9) Soft Read Error Rate 253 253 0 0 ok
Health Status : ok
ולסיכום ראיתי שגם מומלץ לבצע פירמוט מלא ולא מהיר דרך המערכת, אך לפני זה באתי לבדוק את הדיסק עם ESTOOL התוכנה הרשמית של סמסונג והוא לא מזהה אותו. אולי בגלל שהוא חיצוני והתוכנה מיועדת לדיסקים פנימיים? יש קשר?
מקפיץ. מישהו/י?
לאן כולם נעלמו??
אני מעוניין לדעת איך אתה בעצם יודע שכונני סמסונג חיצוניים/פנימיים יותר טובים מסיגייט ולמה,במה זה מתבטא..
אמרת אמינות - כיצד מודדים את העניין? כי תיקח לדוגמה דיסק חיצוני של SEGATE FREEAGENT 2TB שעולה בערך 30 ש"ח יותר מהG3 שקניתי לו
כמובן גם אשמח אם תתייחס לWD היטאצי'
לIOMEGA לא אתייחס מכיוון שהם מכילים דיסק של SEGATE ולכן חוות הדעת על סיגייט תספק
וVERBATIM גם סה"כ משתמשים בדיסקים של SEGATE
TREKSTOR - אין כלום עליהם באיטרנט, והדבר היחידי שמצאת זה שבAlibaba הצהירו שהם משתמשים בדיסקים של טושיבה (שלא ידעתי שעדיין מייצרים). בכל מקרה השבוע אני אדע אם אני מקבל את ה2TB חיצוני במתנה או לא מהספק שלי.
ולגבי סמסונג - STORY VS G3, באמת משהו מפורט ככה... לגבי פירוק הדיסק - בהנחה שלא הייתה יותר אחריות, איך עושים את זה? כי אין כאן שום ברגים, זה נראה כמו איטום שברגע שאתה פותח הלכה לך הקופסה החיצונית.
שמעתי גם על דיסקים עם אופצייה של "השמדה עצמית" - אופצייה חכמה במיוחד, אבל לא נתקלתי.
לגבי HD TUNE - לא הצליח לאתר את הדגם של הדיסק אך את הדברים הבאים כן
*הכונן במצב המתנה נע בין 30 מעלות ל32 מעלות.
Rotation speed : -
S.M.A.R.T : yes
Write Cache : yes
Security Mode : yes
SCT Tables : yes
Trim : no
Free : 1430434 MB
Usage : 0%
File system : NTFS
Serial : D839-BB3D
Alignment : 32 KB
Health Status : ok
