פורסם 2002 במרץ 724 שנים Unhiding Add/Remove ItemsThis is VERY usefull in taking out those annoying programs that the install didn't allow you to select NOT to install. Messenger and MSN Explorer for example. In your c:\windows\inf is a file called sysoc.inf edit this file with Notepad. If you can't find that file... I suggest you show all files.You should see lines that look something like this:msmsgs=ocgen.dll,OcEntry,msmsgs.inf,hide,7Isn't it interesting how that word hide is in there? Yep you guessed it. Hit CTRL + H to Replace. In the "Find what" box type hide and then hit the "Replace All" button. Save, exit and go check your add/remove programs. Nice huh? A very clean way to un-install crap you don't need.
פורסם 2002 במרץ 724 שנים או בצורה הפשוטה והקלה הבאה: start >Run לשם תעתיק את השורה הבאה: RunDll32 advpack.dll,LaunchINFSection %windir%\INF\msmsgs.inf,BLC.Remove תלחץ OK וזהו
