VxWorks Connectivity issue
Here is the log file from connectivity of vxworks appliance components
VxWorks login: root
Password:
-> mdmForceHB
value = 0 = 0x0
-> mRouteSh<3178000 ; tMdmMngr> : <i> Failed to connect to server Managment server 1 (heartbeat) (IP 172.29.69.41, port 1966)!
<3178000 ; tMdmMngr> : <i> Disconnecting from server...
o<3178070 ; tMdmMngr> : wireless default GW:172.29.69.40
<3178320 ; tMdmMngr> : <i> Connecting to server... (IP 172.29.69.41)
w
Destination Mask Proto TOS Gateway Flags RefCnt Use Interface
0.0.0.0 0 1 0 10.228.18.126 0x103 2 0 motfcc0
1.1.1.0 0xffffff00 2 0 10.228.18.50 0x101 0 0 motfcc0
10.228.18.0 0xffffff80 2 0 10.228.18.50 0x101 5 0 motfcc0
10.228.87.211 0 0 0 10.228.18.126 0x8007 1 680 motfcc0
110.1.2.3 0 2 0 172.29.69.40 0x5 0 0 ppp1
127.0.0.1 0 2 0 127.0.0.1 0x5 0 0 lo0
172.29.69.40 0 0 0 10.228.18.126 0x8007 1 1 motfcc0
172.29.69.41 0 1 0 172.29.69.40 0x7 1 1 ppp1
value = 0 = 0x0
-> <3198000 ; tMdmMngr> : <i> Failed to connect to server Managment server 1 (heartbeat) (IP 172.29.69.41, port 1966)!
<3198000 ; tMdmMngr> : <i> Disconnecting from server...
<3198120 ; tMdmMngr> : <i> Heartbeat FAILED for server #0 via path ETH
<3198120 ; tMdmMngr> : <i> Heartbeat FAILED for server #0 via path CELL
<3198120 ; tMdmMngr> : <i> Heartbeat FAILED for server #1 via path ETH
<3198120 ; tMdmMngr> : <i> Heartbeat FAILED for server #1 via path CELL
<3198120 ; tBlackbx> : <i> Setting heartbeat interval to 0 hours, 42 minutes, 10 seconds.
<3198120 ; tBlackbx> : <i> Setting heartbeat interval to 0 hours, 52 minutes, 10 seconds.
<3198850 ; tMdmMngr> :
<3198850 ; tMdmMngr> : <i> Performing heartbeat!
<3199010 ; tMdmMngr> : <i> RF reception: -89
<3199670 ; tMdmMngr> : wired default GW:10.228.18.126
<3199920 ; tMdmMngr> : <i> Connecting to server... (IP 172.29.69.41)
<3219500 ; tMdmMngr> : <i> Failed to connect to server Managment server 0 (heartbeat) (IP 172.29.69.41, port 1966)!
<3219500 ; tMdmMngr> : <i> Disconnecting from server...
<3219570 ; tMdmMngr> : wireless default GW:172.29.69.40
<3219820 ; tMdmMngr> : <i> Connecting to server... (IP 172.29.69.41)
<3239500 ; tMdmMngr> : <i> Failed to connect to server Managment server 0 (heartbeat) (IP 172.29.69.41, port 1966)!
<3239500 ; tMdmMngr> : <i> Disconnecting from server...
<3239570 ; tMdmMngr> : wired default GW:10.228.18.126
<3239820 ; tMdmMngr> : <i> Connecting to server... (IP 172.29.69.41)
10.228.18.54<3259500 ; tMdmMngr> : <i> Failed to connect to server Managment server 1 (heartbeat) (IP 172.29.69.41, port 1966)!
<3259500 ; tMdmMngr> : <i> Disconnecting from server...
<3259570 ; tMdmMngr> : wireless default GW:172.29.69.40
<3259820 ; tMdmMngr> : <i> Connecting to server... (IP 172.29.69.41)
<3279500 ; tMdmMngr> : <i> Failed to connect to server Managment server 1 (heartbeat) (IP 172.29.69.41, port 1966)!
<3279500 ; tMdmMngr> : <i> Disconnecting from server...
<3279620 ; tMdmMngr> : <i> Heartbeat FAILED for server #0 via path ETH
<3279620 ; tMdmMngr> : <i> Heartbeat FAILED for server #0 via path CELL
<3279620 ; tMdmMngr> : <i> Heartbeat FAILED for server #1 via path ETH
<3279620 ; tMdmMngr> : <i> Heartbeat FAILED for server #1 via path CELL
<3279620 ; tBlackbx> : <i> Setting heartbeat interval to 1 hours, 0 minutes, 0 seconds.
<3331470 ; tBlackbx> : <i> Awake time: 0d 0h 55m; Accumulated time on: 32d 9h
<3331470 ; tBlackbx> : <i> System temperature 47C.
תעשה טובה ולפחות תכניס מידע כזה לטאג של קוד כמו בן אדם.
אני לא ממש מומחה לRTOS ומערכות embedded אבל מה verbose הזה לא ניתן להבין הברבה מהלי לדעת אם טבלת הניתובים שיש לך בהתחלה בכלל נכונה.
