פורסם 2003 באוקטובר 3123 שנים Well, or my memory is lousy or my computer is just fucked up. I took my old cdrw and tried to connect it into my pc, now, I had connected the IDE ATAPI CONNECTOR to the regular cdrom, and the DC INPUT to such other electricity support. I got on my cdrw also: "F.GND", "RESERVED", "AUDIO OUT, R GND L", "CABLE SELET", "SLAVE", "MASTER".What have I done wrong? btw, when I connect it in my way the pc just crush.Answer me in hebrew if you can. thx in advance.
פורסם 2003 באוקטובר 3123 שנים Bumping = adding a reply to your own thread in order to *bump* it to the top of the board.It's in the forum rules.
פורסם 2003 בנובמבר 123 שנים you seriesly didn't get the point mate?any way where are you from israel?
