Babylon 8.0.9 (r4) - Babylon Globe feature doesn't work
שלום לכולם,
I have installed Babylon 8.0.9 (r4). Babylon works, but Babylon Globe feature doesn't work (I enabled this feature in Options, but Globe isn't appear on Desktop).
Adobe Flash Player (latest version 10.1.82.76) is successfully installed on my computer.
I can view flash videos in Internet Explorer 8, Firefox 3.6.9 and Google Chrome 6.0.472.55 without any problems.
I even see item "Hide Globe" in the Menu, when I right-click on Babylon icon in the Notification Area (near clock), BUT I DON'T SEE THE GLOBE ITSELF ON THE DESKTOP.
The problem exists in Windows 7 and Windows XP, but not in all computers. I have 4 computers:
1. Windows XP, Babylon 8.0.9 (r4) - Globe works
2. Windows XP, Babylon 8.0.9 (r4) - Globe doesn't work.
3. Windows 7, Babylon 8.0.9 (r4) - Globe works
4. Windows 7, Babylon 8.0.9 (r4) - Globe doesn't work.
סליחה שכתבתי באנגלית ולא בעברית, פשוט פתחתי את הקריאה באתר של בבילון אך הם לא היו מסוגלים לפתור את הבעיה.
