מסך כחול עזרה בבקשה
המחשב נכבה לבד באמצע משחק עדכנתי דרייברים ועדיין יש אותה בעיה עד שקבלתי מסך כחול :nixweiss:
הנה קובץ DUMP
תודה רבה לכל העוזרים
[attachment deleted by admin]
Loading unloaded module list
Loading User Symbols
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 1000000A, {58, 1c, 0, 805452fa}
Probably caused by : memory_corruption
Followup: memory_corruption
1: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: 00000058, memory referenced
Arg2: 0000001c, IRQL
Arg3: 00000000, value 0 = read operation, 1 = write operation
Arg4: 805452fa, address which referenced memory
Debugging Details:
READ_ADDRESS: 00000058
CURRENT_IRQL: 1c
FAULTING_IP:
nt!KeProfileInterruptWithSource+1e
805452fa 807e5700 cmp byte ptr [esi+0x57],0x0
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: CODE_CORRUPTION
BUGCHECK_STR: 0xA
LAST_CONTROL_TRANSFER: from 4fe59db2 to 805452fa
STACK_TEXT:
b380ad64 4fe59db2 badb0d00 00000008 00000000 nt!KeProfileInterruptWithSource+0x1e
WARNING: Frame IP not in any known module. Following frames may be wrong.
b380ad68 badb0d00 00000008 00000000 00000000 0x4fe59db2
b380ad6c 00000000 00000000 00000000 00000000 0xbadb0d00
CHKIMG_EXTENSION: !chkimg -lo 50 -d !nt
805452c0-805452c1 2 bytes - nt!KeUpdateRunTime+148
[ ac 09:7d 1c ]
805452c3-805452ff 61 bytes - nt!KeUpdateRunTime+14b (+0x03)
[ 00 b9 02 00 00 00 ff 15:8a 46 54 74 09 24 fb 0c ]
63 errors : !nt (805452c0-805452ff)
MODULE_NAME: memory_corruption
IMAGE_NAME: memory_corruption
FOLLOWUP_NAME: memory_corruption
DEBUG_FLR_IMAGE_TIMESTAMP: 0
MEMORY_CORRUPTOR: LARGE_64
STACK_COMMAND: kb
FAILURE_BUCKET_ID: MEMORY_CORRUPTION_LARGE_64
בעיה בזיכרון, אך שים לב שהוא רושם:
כנראה שהמשחק שלך ניגש לכתובות שגויות בזיכרון :nixweiss:
מה לעשות כדי לפתור את הבעיה ? להחליף זיכרון ? :facepalm::s07:
לא בהכרח. אם הבנתי נכון, ממך ומדוח השגיאה, ישנה רק אפליקציה אחת שגורמת לכך וזה המשחק שלך. מה קורה כשאתה עושה דברים אחרים במחשב או משחק במשחקים אחרים?
המחשב נכבה כמעט בכל המשחקים אבל לא בכולם למשל ב MAFIA II הוא נכבה בASS CREED II לא
עדכנתי דרבריים אז ממה זה יכול להיות ? :kopfpatsch:
המחשב נכבה או שאתה מקבל מסך כחול? יש הבדל גדול בין שני הדברים!
הוא נכבה במשחקים ונדלק לבד זה מה שקורה במשחקים
אבל לאחרונה אני מקבל מסכים כחולים הכל קשור לזכרון
איזה זכרונות יש לך וכמה כרטיסים?
