מערכים ומחלקות בC++
יותר מידי שגיאות. לא מצליח להתמודד עם השפה המיושנת =]]
הקוד ולאחריו שאלות:
mydate.h
#ifndef MYDATE
#define MYDATE
#include <stdio.h>
#include <string.h>
class MyDate
private:
static const int DAY_MIN_VALUE = 1;
static const int MONTH_MIN_VALUE = 1;
static const int YEAR_MIN_VALUE = 1901;
static const int DAY_MAX_VALUE = 30;
static const int MONTH_MAX_VALUE = 12;
static const int YEAR_MAX_VALUE = 2099;
int _day;
int _month;
int _year;
char *_comment;
Checks if the date that the function gets is valid
Valid: day = 1,..,30 , except febuar where day = 1,..,28
month = 1,..,12
year = 1901,..,2099
bool checkDate(int day, int month, int year);
public:
The Ctor of the class put default values
MyDate()
_day = DAY_MIN_VALUE;
_month = MONTH_MIN_VALUE;
_year = YEAR_MIN_VALUE;
_comment = NULL;
MyDate(const MyDate& date)
_day = date._day;
_month = date._month;
_year = date._year;
if(date._comment != NULL)
if(_comment!=NULL)
delete[]_comment;
_comment=new char[strlen(date._comment)+1];
strcpy(_comment,date._comment);
else
_comment = NULL;
Sets the Date to 8.8.10
void Init();
Sets the date to the day, month and year that the function gets
void Set(int day, int month, int year);
Compare the two dates and return if the object date is earler then the date that he gets
bool isBefore(MyDate date);
Change the date's comment to be the comment that the function gets, max comment length - 20
void changeComment(char *comment);
Delay the date by delay, max value is 365. min value 1
void Delay(int delay);
Bring foward the date by foward, max value is 365. min value 1
void bringFoward(int foward);
Sets the day if its valid
Valid: 1,..,30 , except febuar where day = 1,..,28
void setDay(int day);
Sets the month if its valid
Valid: 1,..,12
void setMonth(int month);
Sets the year if its valid
Valid: 1901,..,2099
void setYear(int year);
Prints the date
void Print();
#endif
calander.h
#include "MyDate.h"
#ifndef CALANDER
#define CALANDER
class Calander
private:
static const int CALANDER_SIZE = 30;
MyDate **_dates;
int _currentSize;
int _nextFreeSpace;
Go over the array and finds the next free space
int getNextFreeSpace();
public:
The Ctor of the class, init all parameters
Calander()
_dates = new MyDate[CALANDER_SIZE];
int i;
for(i = 0 ; i< CALANDER_SIZE ; ++i)
_dates[i] = NULL;
_currentSize = 0;
_nextFreeSpace = 0;
Set the date parameter at the num place on the calander
void setDate(int num, MyDate date);
Gets a number from 1 to 30 and check if this place on the calander is free
bool isFree(int num);
Return the first place on the calander thats available, return 0 if it full
int firstFree();
Insert the date into the first available place on the calander
void Insert(MyDate date);
Return the earler date from the calander
int Oldest();
Return the number of cell that have dates
int DatesNum();
Delete all saved date on the calander
void deleteAll();
Delete specific date on num place
void Delete(int num);
Prints all the calander's dates
void Print();
#endif
calander.cpp
#include "Calander.h"
void Calander::setDate(int num, MyDate date)
if(isFree(num))
_dates[num-1] = new MyDate(date);
++_currentSize;
if(num-1 == _nextFreeSpace)
_nextFreeSpace = getNextFreeSpace();
else
printf("The space on calander is not free\n");
bool Calander::isFree(int num)
return _dates[num-1] == NULL;
int Calander::firstFree()
if(_currentSize == CALANDER_SIZE)
return 0;
else
return _nextFreeSpace+1;
void Calander::Insert(MyDate date)
if(_currentSize < CALANDER_SIZE)
_dates[_nextFreeSpace] = new MyDate(date);
++_currentSize;
else
printf("Calander is full\n");
int Calander::Oldest()
int min = -1;
if (_currentSize > 0)
int i;
for(i=0 ; i < CALANDER_SIZE ; ++i)
if(_dates[i] != NULL)
if(min == -1)
min = i;
else if(_dates[i].isBefore(_dates[min]))
min = i;
else
printf("No dates to compare - the calander is empty");
return min;
int Calander::datesNum()
return _currentSize;
void Calander::deleteAll()
int i;
for(i=0; i< CALANDER_SIZE ; ++i)
delete[]_dates[i];
_dates[i] = NULL;
void Calander::Delete(int num)
if(num >= 1 && num <= CALANDER_SIZE)
delete[]_dates[num-1];
else
printf("The specified location does not exist");
void Calander::Print()
if(_currentSize > 0)
int i;
_dates[i].print();
else
printf("Calander is empty");
int Calander::getNextFreeSpace()
return -1;
else
int i;
for (i = _nextFreeSpace ; i < CALANDER_SIZE ; ++i )
if(_dates[i] == NULL)
return i;
return -1;
main.cpp
void main()
the content isnt relevant
השגיאות:
Error	2	error C2628: 'Calander' followed by 'void' is illegal (did you forget a ';'?)	d:\documents\visual studio 2008\projects\targil1\targil1\main.cpp	7	targil1
Error 3 error C3874: return type of 'main' should be 'int' instead of 'Calander' d:\documents\visual studio 2008\projects\targil1\targil1\main.cpp 8 targil1
Error 4 error C2440: '=' : cannot convert from 'MyDate *' to 'MyDate **' d:\documents\visual studio 2008\projects\targil1\targil1\calander.h 24 targil1
Error 7 error C2628: 'Calander' followed by 'void' is illegal (did you forget a ';'?) d:\documents\visual studio 2008\projects\targil1\targil1\calander.cpp 6 targil1
Error 8 error C2556: 'Calander Calander::setDate(int,MyDate)' : overloaded function differs only by return type from 'void Calander::setDate(int,MyDate)' d:\documents\visual studio 2008\projects\targil1\targil1\calander.cpp 7 targil1
Error 9 error C2371: 'Calander::setDate' : redefinition; different basic types d:\documents\visual studio 2008\projects\targil1\targil1\calander.cpp 7 targil1
Error 10 error C2228: left of '.isBefore' must have class/struct/union d:\documents\visual studio 2008\projects\targil1\targil1\calander.cpp 80 targil1
Error 11 error C2039: 'datesNum' : is not a member of 'Calander' d:\documents\visual studio 2008\projects\targil1\targil1\calander.cpp 98 targil1
Error 12 error C2065: '_currentSize' : undeclared identifier d:\documents\visual studio 2008\projects\targil1\targil1\calander.cpp 100 targil1
חוץ שגיאה 4 - WTF? במה אני טועה?
בקשר לשגיאה 4, במה אני טועה? וחוץ מזה איך הגישה ועבודה שלי עם המערך הדינאמי של מצביעים?
הקומפילר גם אומר לי שעדיף לי להשתמש בstrcpy_s במקום strcpy הבעיה שלא הצלחתי כי כל פעם הוא זרק משהו אחר אז כבר נשארתי עם זה...
דרך אגב,
הדרישה היא ששדה המידע של CALANDER יכיל מערך דינאמי של מצביעים מטיפוס MYDATE ושגודל המערך הוא תמיד 30... ועל השיטה הזו עליתי. האם VECTOR גם עונה על זה? אני חשבתי שלא, דעתכם?
תודה על הכל!
שגיאה 2: בסוף ההגדרה של מחלקה (אחרי הסוגר המסולסל) אתה צריך נקודה-פסיק. הקומפיילר אפילו אומר לך את זה.
שגיאה 4: הקריאה ל-new מחזירה מצביע לטיפוס, כלומר במקרה שלך זה *MyDate. על מנת לעשות מערך של מצביעים אתה צריך לעשות:
new MyDate*[size]
רוב השגיאות נובעות ממה שציינתי בשגיאה 2.
אתה יכול בינתיים להתעלם מהאזהרה על strcpy - קודם כל תדאג שהתכנית שלך תעבוד. אבל חוץ מזה, אם אתה עובד ב-++C, למה אתה עובד עם מחרוזות של C, ועם printf, במקום לעבוד עם string ועם cout?
באמת עשה קצת סדר =]
שגיאה 10, אני אמרו לעשות CASTING בפירוש? הוא לא מכיר את MYDATE?
עריכה:
אני עובד עם CHAR כי זוהי ההגדרה...
בקשר לCOUT, פשוט לא עבדתי הרבה עם C++ וזוהי התוכנית הראשונה שאני כותב בC++ בשנתיים שלוש האחרונות..
תחשוב מה הטיפוס של [myDates[i ותבין מה הבעיה.
מצביע לMYDATE?
אכן. עכשיו תחשוב איך ניגשים לאיברים של אובייקט דרך המצביע (יש אפילו שתי דרכים).
ואי בכלל שכחתי מ->
_dates[i]->isBefore(*_dates[min])
הארגומט שנשלח הוא בצורה תקינה? כאילו ה* לא שולח בעצם את הכתובת לMYDATE? ובלי ה* הוא שולח את האובייקט עצמו?
