How to Remove Security Tool and SecurityTool
Symptoms
One day suddenly most of the important features of Windows are grayed out or turned off (like the taskbar is not working anymore, or services.msc or msconfig etc'...) and this appears on the desktop:
Solution
To Remove Security Tool and SecurityTool, download Malware bytes, run it and restart your PC
http://www.malwarebytes.org
*This is a case study of an issue I just had and thought to share with the readers.
Alexander Turovsky.
