לא יכול להגדיל מחיצה..
איזה בלאגן. :)
אחרי מה שירח אפל ציין כמובן צריך לעזות resize כדי להרחיב על חשבון המרחב שלא מנוצל.
ה resize יקח כמה דקות, אבל הmove באמת יכול לקחת כמה שעות טובות.
Can you please write in english? because google translate translation isnt so good and i can't really understand what are you saying..
or tell me how to enable hebrew.
Basically, what you need to do is move the partition to the start of the disk and then re-size them forward using the remaining unallocated space.
First you should choose dev/SDA2 and then right click on it and choose move. On the next dialog move the petition to the left and proceed to SDA3 with the same action.
After you do that click on "Apply" in order to start moving the clusters. This might take the whole day so you should plan ahead.
After the partitions has successfully and completely moved you should choose the second one from the left and re-size it the same way you moved it before.
i moved sda2 like you said,did i do it right?
http://img138.imageshack.us/img138/9491/screenshotfkk.png
and i can't move sda3,the whole"line" is only sda3..
Please don't quote message above you.
Why you choose to grow the partition after you moved it the left?
That's the reason you can't move SDA3 after.
The more correct answer will be moving SDA5 to the left then resizing SDA2.
After that the next step is moving SDA3 to the left and resizing it to the right.
It's suppose to be something like this in the beginning:
[100MB reserved space for RE]-->[SDA2--->[SDA5]--]-->[SDA3]
First action in the sequence is to move SDA5 so
[100MB reserved space for RE]-->[SDA2[SDA5]--]-->[SDA3]
Then re-size SDA2
[100MB reserved space for RE]-->[SDA2[SDA5]]-->[SDA3]
Then move SDA3
[100MB reserved space for RE]-->[SDA2[SDA5]][SDA3-----]
re-size SDA3 to the right taking the unallocated space
[100MB reserved space for RE]-->[SDA2[SDA5]][SDA3]
