קריסת Partition Table של הארד דיסק נייד?
שלום לכולם, ניגשתי בהתחלה עם הבעיה הזו לפורומים של Tom's Hardware - אך טרם כנו לי שם על השאלה, כך שכעת אני בא אליכם, אולי מכאן תצמח הישועה?
אני מביא את הבעיה במקור בשפה האנגלית.
תקציר בעברית: דיסק קשיח חיצוני של Maxtor, בנפח של טרה-בייט (בבעלותי כ-4 שנים). פתאום אני לא יכול להיכנס אליו, ולאחר התעסקות עם כמה תוכנות, אחת מהן הצליחה אפילו לשנות את הנפח שלו לצערי הרב מ1000 ג'יגה ל-43 ג'יגה! אני לא יודע מה לעשות, אשמח אם תעזרו לי.
ההודעה המקורית, יותר מפורטת ועם תמונה להמחשה בסופה:
I own an external HDD for about 4 years now.
It's a Maxtor Basics Desktop Storage 1TB.
A few days ago I tried to access it from My Computer but windows popped an error "The disk in drive H is not formatted. Do you want to format it now?"
Of course I didn't click Yes, but what I did do, is freak out.
Since then I have learned a whole lot about how hard disks work, and realized that somehow the partition table was damaged and this is why I cannot access the drive.
I have used several programs to help me revive the disk, like TestDisk, Partition Table Doctor (which I think killed my drive conclusively) and some other programs to help me copy the data from the disk (Power data recovery and some other, which were able to access the folders and view the contents, but unable to execute it even after copying the files to my desktop).
Further more, the wonderful and most kind application Partition Table Doctor" screwed the drive up. After I used the Fixboot feature, it turned the drive from a 1000GB drive to a 43GB drive (TestDisk application even mentioned the drive is somewhat small, and after a search it identifies it as a 1000GB drive - but it cannot do anything about it probably, since I was not able to make it revive it).
I know this issue probably closed itself once Partition Table Doctor ruined the disk even more, but is there any hope for me?
I am attaching this photo to show you what TestDisk tells me once it finishes performing the search on the drive:
Thanks for any help granted!
אתה מנסה לחלץ את המידע הקיים או רק להשתמש שוב בדיסק?
אני מנסה להגיע למצב האידיאלי- שמבחינתי הוא להחזיר את הכונן למצב של 1000 ג'יגה וכל החומר המקורי עדיין שמור עליו.
מאחר ואפשרות זו לא נראית סבירה, אני אשמח אם אצליח להעתיק את החומר מהכונן למחשב (הצלחתי להעתיק למשל קבצי MKV מהכונן למחשב, שהועתקו בהצלחה, אך הקבצים פגומים) או לפחות להרוויח את ה-1000 ג'יגה בחזרה, עם או בלי מידע על הכונן.
בתור התחלה תנסה להשתמש בGETDATABACK ובRSTUDIO ותתן להם לבצע סריקה מלאה ותראה מה הן מסוגלות לחלץ.
תודה על העזרה בינתיים.
את GetDataBack for NTFS כבר היה לי (גרסה מלאה) והוא, בניגוד לשאר התוכנות - מצליח לראות את כל הקבצים שהיו על הכונן, ובמחיצה אחת (מזהה שבאמת 911GB היו בשימוש מתוך 1000). אבל בשחזור הקבצים הוא כמו כל שאר התוכנות - מצליח להעתיק כביכול את הקובץ - אך לא משנה מה סוג הקובץ (PDF, AVI, MKV), אי אפשר לפתוח אותו כי הוא פגום.
?Any ideas
ללא קשר, אני אנסה את RSTUDIO ואקווה לתוצאות טובות יותר.
וואו!
R-STUDIO הצליחה לעשות מה שאף תוכנה אחרת עד עכשיו לא הצליחה.
לא רק שהיא זיהתה את כל התוכן שבכונן, היא גם מאפשרת לי לפתוח את כל סוגי הקבצים והכל עובד!
תודה רבה לך!
כעת השאלה המתבקשת, מה אני עושה עכשיו?
האם יש תקווה לשחזר את הכונן, או שמא אצטרך לקנות אחד חדש ולהעתיק אליו את כל מה שהיה בדיסק שנהרס עכשיו?
ואיך אני מונע ממקרה דומה למה שקרה לי להישנות בכוננים אחרים, יש הסבר למה שקרה כאן?
בברכה,
אופיר
תחלץ את כל הקבצים לכונן אחר, תמחק את כל המחיצות בדיסק, תיצור אחת חדשה ותמשיך להשתמש בו. בקשר לגורם הבעיה - קשה לדעת,
זו יכולה להיות תקלה חד פעמית או סימן לבעיה כרונית. תריץ את כלי האבחון של היצרן.
יוחנן, שוב תודה על כל העזרה עד כה.
לא באמת האמנתי שיש סיכוי שלפחות אוכל להציל את הקבצים עצמם.
כעת, אינני בטוח איך לבצע את הוראותיך.
איך אני מוחק את המחיצות שבכונן ויוצר אחת חדשה, והאם היא תהיה אכן מחיצה של כ-1000GB או שמא 43GB כמו שהתוכנות בהן השתמשתי עד כה מזהות כנפח הכונן?
יש לציין, השתמשתי עד כה בכונן גם בחיבור למחשב הנייח שלי וגם בחיבור לסטרימר לשם ניגון קבצי HD.
האם זה יכול להיות מקור הבעיה (שינוי מבנה הקבצים כתוצאה מחיבור לסוגי חומרה ומערכת שונים)?
בתור התחלה תעתיק את הקבצים לכונן אחר. אח"כ תיכנס ללוח הבקרה -> כלי ניהול -> ניהול מחשב -> ניהול דיסקים ותעלה צילום של מה
שאתה רואה שם.
מצ"ב תמונה של ניהול הדיסקים.
ניתן לשים לב כי כעת הדיסק מזוהה כבעל נפח של כ-345GB ומקום פנוי של כ-100%, אך עדיין אין גישה אליו דרך ה-Windows והוא מוגדר כ-RAW במאפיינים.
כפתור ימני על הדיסק הנ"ל ותבחר במחיקת מחיצה (כמובן אחרי שכל הקבצים כבר גובו!) ואח"כ תנסה ליצור מחיצה אחרת על הכונן
(עיין במדריך לניהול מחיצות בחלק המדריכים של האתר).
עריכה: אהבתי את שמות הכוננים שלך :)
תודה :)
ובכן, עדיין קשה לי להאמין - אבל, עשיתי זאת. הצלחתי להחזיר את הכונן למצבו הקודם!
הייתכן שמיקרוסופט יצרו כלי מועיל?
הרצתי בתוך מערכת ההפעלה בדיקת Chkdsk /f על הכונן, והוא תיקן מלא שגיאות ולאחר מכן (בערך 3 דקות סה"כ של הרצה) מערכת ההפעלה זיהתה מחדש את הכונן ויש לי גישה אליו, כל הקבצים עובדים כאשר אני מפעיל אותם מתוך הכונן.
תודה רבה יוחנן, אין לי מושג איך פתאום מערכת ההפעלה אפשרה לי מלכתחילה לגשת ל-Root של הכונן אך מה שהיה מוזר זה שהיא אפשרה גישה אך ורק ל-Root, וכל נסיון להיכנס תיקיה אחת פנימה גרר הודעת שגיאה שהקבצים פגומים (לאחר שראיתי שלפחות הגישה ל-Root מתאפשרת לי, עלה לי הרעיון להריץ את הבדיקה).
