אזהרה לכול בעלי הפלייסטיישן 3
:hi:
שלום לכולם -הנה מידע חדש ומטריד שכדאי לכם לקרא
Playstation maker Sony appears to have had a rush of blood to the head when it designed the new EULA for its Playstation 3.
Apparently that machine that you shelled out good money for is not actually yours to do with what you want but is on loan from at the whim of the company. The latest firmware comes with a 1,770 word End User License Agreement which you have to digitally sign. Version 3.30 fixes some stability issues, adds sorting options for trophies and reportedly paves the way for forthcoming 3D content.
However it also includes a new EULA which says that Sony may provide updates, upgrades or services to your PS3 system to ensure it is functioning properly in accordance with SCE guidelines or provide you with new offerings. “Some services may be provided automatically without notice when you are online, and others may be available to you through Sony's online network or authorised channels.”
Services may include the provision of the latest update or download of new release that may include security patches, new technology or revised settings and features which may prevent access to unauthorised or pirated content, or use of unauthorised hardware or software in connection with the PS3 system.
You may not be able to view your own content if it includes or displays content that is protected by authentication technology. Some services may change your current settings, cause a loss of data or content, or cause some loss of functionality.
One line has got our attention which is "Some services may be provided automatically without notice when you are online". This means that Sony can do whatever the hell it wants to do to the content of your PS3 without notifying you or asking your permission.
It appears that Sony forces users to sign an agreement which allows you to use a piece of hardware which you have paid for, but allows Sony to make any changes they see fit to the way the console operates without notification or permission. In fact it could just switch you off completely and you would not have a leg to stand on.
קצת חצוף ומעצבן :pissed:
leelevin77@gmail.com
יש לך GMAIL ואתה בוכה על הEULA של sony?
מסכים עם דובי.
מה גם שהשינויים האלו הם די סמנטיקה.
בכלל - קרא עוד כמה EULAים של מוצרים ושירותים שאתה משתמש בהם (אני אתפלא אם זה של הXBOX לא כזה מגביל גם ככה).
תתפלא למה אתה מסכים אוטומטית.
ליביו
הרבה פעמים הEULA לא עומדים לבדיקה בבתי משפט
זה שיש חוזה לא תמיד אומר שהוא חוקי ובטח שמחשיבים מדינות שונות וחוקים שונים
השאלה הגדולה אם אנשים באמת ירצו לקחת את סוני למשפט על זה או לא
בינתים לא ראינו יותר מידי ריצות למשפט בגלל EULA כזאת או אחרת
אני מסכים שזו גישה חצופה מצידם וגם מצד חברות אחרות שמחתימות את הלקוח על רשיון דומה,
אבל לי, בתור אחד שלא מתכוון להשתמש בתוכן פיראטי במכשיר, זה לא אמור להפריע.
גם אני לא אהבתי בכלל את האקט הלא חוקי שלה בעליל של לבטל לי פיצ'ר ששלמתי עליו - OTHER OS.
אבל הבנתי שאין לי יותר מידי מה לעשות בעניין ועדכנתי.. (אני מקווה שמישהו בעולם ירים את הכפפה של תביעה יצוגית)
מה הפיצ'ר הזה עושה?
מאפשר לך להתקין על המכשיר מערכת הפעלה שונה, דוגמאת הלינוקס.
יש לא מעט אנשים שהשתמשו בזה ברחבי העולם וביום בהיר אחד האפשרות הזו פשוט בוטלה לאלתר.
אותי אישית הפיצ'ר הזה לא כל כך עניין, אך האקט עצמו פשוט הרגיז.
זה נראה לי תמוה שחברה מרשה לעצמה לעשות מה שעולה על רוחה.
אם כל הכבוד לפירצה לכאורה שמשתמשת בפיצ'ר הזה כפירצת אבטחה,
מחר מישהו בעולם ייגלה איזה פירצה למכשיר דרך חיבורית ה WI-FI או משהו דומה,
אז מה סוני יעשו ? יבטלו למכשירים את ה WI-FI ? :bash:
