כשלון.בהתקנת.VS2010
הנה.הלוג,אני.מקבל.שגיאה.אחרי.הריבוט.הראשון:
[04/07/10,12:03:07] Microsoft Silverlight: [2] Error code 1502 for this component means "The event log file is full.
[04/07/10,12:03:08] Microsoft Silverlight: [2] Component Microsoft Silverlight returned an unexpected value.
[04/07/10,12:03:08] Microsoft Silverlight: [2] Return from system messaging: The event log file is full.
[04/07/10,12:29:40] VS70pgui: [2] DepCheck indicates Microsoft Silverlight is not installed.
***EndOfSession***[04/11/10,11:50:36] Microsoft Application Error Reporting: [2] Error: Installation failed for component Microsoft Application Error Reporting. MSI returned error code 1603
[04/11/10,11:50:42] VS70pgui: [2] DepCheck indicates Microsoft Application Error Reporting is not installed.
[04/11/10,11:50:42] VS70pgui: [2] DepCheck indicates VC 9.0 Runtime (x86) was not attempted to be installed.
[04/11/10,11:50:43] VS70pgui: [2] DepCheck indicates VC 10.0 Runtime (x86) was not attempted to be installed.
[04/11/10,11:50:43] VS70pgui: [2] DepCheck indicates Microsoft .NET Framework 4 Beta 2 was not attempted to be installed.
[04/11/10,11:50:43] VS70pgui: [2] DepCheck indicates Microsoft Visual F# 1.0 Runtime was not attempted to be installed.
[04/11/10,11:50:44] VS70pgui: [2] DepCheck indicates TFS Object Model (x86) was not attempted to be installed.
[04/11/10,11:50:44] VS70pgui: [2] DepCheck indicates .NET Framework 4 Multi-Targeting Pack was not attempted to be installed.
[04/11/10,11:50:44] VS70pgui: [2] DepCheck indicates Microsoft Visual Studio 2010 Ultimate Beta 2 - ENU was not attempted to be installed.
[04/11/10,11:50:44] VS70pgui: [2] DepCheck indicates Microsoft Web Deployment Tool (x86) was not attempted to be installed.
[04/11/10,11:50:44] VS70pgui: [2] DepCheck indicates Microsoft ASP.NET MVC 2 - Visual Studio 2010 Tools was not attempted to be installed.
[04/11/10,11:50:45] VS70pgui: [2] DepCheck indicates Microsoft ASP.NET MVC 2 was not attempted to be installed.
[04/11/10,11:50:45] VS70pgui: [2] DepCheck indicates Microsoft Silverlight was not attempted to be installed.
[04/11/10,11:50:45] VS70pgui: [2] DepCheck indicates Microsoft Silverlight 3 SDK was not attempted to be installed.
[04/11/10,11:50:45] VS70pgui: [2] DepCheck indicates Visual Studio 2010 Tools for Office Runtime Beta 2 (x86) was not attempted to be installed.
[04/11/10,11:50:45] VS70pgui: [2] DepCheck indicates Microsoft Office Development Tools for Visual Studio 2010 (x86) was not attempted to be installed.
[04/11/10,11:50:46] VS70pgui: [2] DepCheck indicates Dotfuscator Software Services - Community Edition was not attempted to be installed.
[04/11/10,11:50:46] VS70pgui: [2] DepCheck indicates Crystal Reports templates for Visual Studio 2010 was not attempted to be installed.
[04/11/10,11:50:46] VS70pgui: [2] DepCheck indicates Microsoft SQL Server Compact 3.5 SP2 Beta ENU was not attempted to be installed.
[04/11/10,11:50:46] VS70pgui: [2] DepCheck indicates Visual Studio 2010 Beta 2 Tools for SQL Server Compact ENU was not attempted to be installed.
[04/11/10,11:50:47] VS70pgui: [2] DepCheck indicates Microsoft Sync Framework Runtime v1.0 (x86) ENU was not attempted to be installed.
[04/11/10,11:50:47] VS70pgui: [2] DepCheck indicates Microsoft Sync Services for ADO.NET v2.0 (x86) ENU was not attempted to be installed.
[04/11/10,11:50:47] VS70pgui: [2] DepCheck indicates Microsoft Sync Framework Services v1.0 (x86) ENU was not attempted to be installed.
[04/11/10,11:50:47] VS70pgui: [2] DepCheck indicates Microsoft Sync Framework SDK v1.0 (x86) ENU was not attempted to be installed.
[04/11/10,11:50:48] VS70pgui: [2] DepCheck indicates Microsoft Visual Studio 2010 Performance Collection Tools (x86) was not attempted to be installed.
[04/11/10,11:50:48] VS70pgui: [2] DepCheck indicates Microsoft SQL Publishing Wizard 1.4 was not attempted to be installed.
[04/11/10,11:50:48] VS70pgui: [2] DepCheck indicates SQL Server System CLR Types was not attempted to be installed.
[04/11/10,11:50:49] VS70pgui: [2] DepCheck indicates SQL Server 2008 R2 Management Objects was not attempted to be installed.
[04/11/10,11:50:49] VS70pgui: [2] DepCheck indicates Microsoft SQL Server 2008 Express Service Pack 1 (x86) was not attempted to be installed.
[04/11/10,11:50:49] VS70pgui: [2] DepCheck indicates Data-tier Application Component Framework was not attempted to be installed.
[04/11/10,11:50:49] VS70pgui: [2] DepCheck indicates Data-tier Application Component Project System was not attempted to be installed.
[04/11/10,11:50:50] VS70pgui: [2] DepCheck indicates Transact-SQL Language Service was not attempted to be installed.
[04/11/10,11:50:50] VS70pgui: [2] DepCheck indicates Microsoft SharePoint Development Tools was not attempted to be installed.
[04/11/10,11:50:50] VS70pgui: [2] DepCheck indicates Microsoft Visual Studio 2010 ADO.NET Entity Framework Tools was not attempted to be installed.
[04/11/10,11:50:50] VS70pgui: [2] DepCheck indicates Microsoft Help 3.0 Beta 2 was not attempted to be installed.
***EndOfSession***[04/11/10,12:03:51] Microsoft Application Error Reporting: [2] Error: Installation failed for component Microsoft Application Error Reporting. MSI returned error code 1603
[04/11/10,12:03:56] VS70pgui: [2] DepCheck indicates Microsoft Application Error Reporting is not installed.
[04/11/10,12:03:56] VS70pgui: [2] DepCheck indicates VC 9.0 Runtime (x86) was not attempted to be installed.
[04/11/10,12:03:56] VS70pgui: [2] DepCheck indicates VC 10.0 Runtime (x86) was not attempted to be installed.
[04/11/10,12:03:56] VS70pgui: [2] DepCheck indicates Microsoft .NET Framework 4 Beta 2 was not attempted to be installed.
[04/11/10,12:03:57] VS70pgui: [2] DepCheck indicates Microsoft Visual F# 1.0 Runtime was not attempted to be installed.
[04/11/10,12:03:57] VS70pgui: [2] DepCheck indicates TFS Object Model (x86) was not attempted to be installed.
[04/11/10,12:03:57] VS70pgui: [2] DepCheck indicates .NET Framework 4 Multi-Targeting Pack was not attempted to be installed.
[04/11/10,12:03:57] VS70pgui: [2] DepCheck indicates Microsoft Visual Studio 2010 Ultimate Beta 2 - ENU was not attempted to be installed.
[04/11/10,12:03:57] VS70pgui: [2] DepCheck indicates Microsoft Web Deployment Tool (x86) was not attempted to be installed.
[04/11/10,12:03:57] VS70pgui: [2] DepCheck indicates Microsoft ASP.NET MVC 2 - Visual Studio 2010 Tools was not attempted to be installed.
[04/11/10,12:03:57] VS70pgui: [2] DepCheck indicates Microsoft ASP.NET MVC 2 was not attempted to be installed.
[04/11/10,12:03:58] VS70pgui: [2] DepCheck indicates Microsoft Silverlight was not attempted to be installed.
[04/11/10,12:03:58] VS70pgui: [2] DepCheck indicates Microsoft Silverlight 3 SDK was not attempted to be installed.
[04/11/10,12:03:58] VS70pgui: [2] DepCheck indicates Visual Studio 2010 Tools for Office Runtime Beta 2 (x86) was not attempted to be installed.
[04/11/10,12:03:58] VS70pgui: [2] DepCheck indicates Microsoft Office Development Tools for Visual Studio 2010 (x86) was not attempted to be installed.
[04/11/10,12:03:58] VS70pgui: [2] DepCheck indicates Dotfuscator Software Services - Community Edition was not attempted to be installed.
[04/11/10,12:03:58] VS70pgui: [2] DepCheck indicates Crystal Reports templates for Visual Studio 2010 was not attempted to be installed.
[04/11/10,12:03:59] VS70pgui: [2] DepCheck indicates Microsoft SQL Server Compact 3.5 SP2 Beta ENU was not attempted to be installed.
[04/11/10,12:03:59] VS70pgui: [2] DepCheck indicates Visual Studio 2010 Beta 2 Tools for SQL Server Compact ENU was not attempted to be installed.
[04/11/10,12:03:59] VS70pgui: [2] DepCheck indicates Microsoft Sync Framework Runtime v1.0 (x86) ENU was not attempted to be installed.
[04/11/10,12:03:59] VS70pgui: [2] DepCheck indicates Microsoft Sync Services for ADO.NET v2.0 (x86) ENU was not attempted to be installed.
[04/11/10,12:03:59] VS70pgui: [2] DepCheck indicates Microsoft Sync Framework Services v1.0 (x86) ENU was not attempted to be installed.
[04/11/10,12:04:00] VS70pgui: [2] DepCheck indicates Microsoft Sync Framework SDK v1.0 (x86) ENU was not attempted to be installed.
[04/11/10,12:04:00] VS70pgui: [2] DepCheck indicates Microsoft Visual Studio 2010 Performance Collection Tools (x86) was not attempted to be installed.
[04/11/10,12:04:00] VS70pgui: [2] DepCheck indicates Microsoft SQL Publishing Wizard 1.4 was not attempted to be installed.
[04/11/10,12:04:01] VS70pgui: [2] DepCheck indicates SQL Server System CLR Types was not attempted to be installed.
[04/11/10,12:04:01] VS70pgui: [2] DepCheck indicates SQL Server 2008 R2 Management Objects was not attempted to be installed.
[04/11/10,12:04:01] VS70pgui: [2] DepCheck indicates Microsoft SQL Server 2008 Express Service Pack 1 (x86) was not attempted to be installed.
[04/11/10,12:04:02] VS70pgui: [2] DepCheck indicates Data-tier Application Component Framework was not attempted to be installed.
[04/11/10,12:04:02] VS70pgui: [2] DepCheck indicates Data-tier Application Component Project System was not attempted to be installed.
[04/11/10,12:04:03] VS70pgui: [2] DepCheck indicates Transact-SQL Language Service was not attempted to be installed.
[04/11/10,12:04:04] VS70pgui: [2] DepCheck indicates Microsoft SharePoint Development Tools was not attempted to be installed.
[04/11/10,12:04:04] VS70pgui: [2] DepCheck indicates Microsoft Visual Studio 2010 ADO.NET Entity Framework Tools was not attempted to be installed.
[04/11/10,12:04:05] VS70pgui: [2] DepCheck indicates Microsoft Help 3.0 Beta 2 was not attempted to be installed.
***EndOfSession***[04/11/10,12:31:58] Microsoft Application Error Reporting: [2] Error: Installation failed for component Microsoft Application Error Reporting. MSI returned error code 1603
[04/11/10,12:32:04] VS70pgui: [2] DepCheck indicates Microsoft Application Error Reporting is not installed.
[04/11/10,12:32:04] VS70pgui: [2] DepCheck indicates VC 9.0 Runtime (x86) was not attempted to be installed.
[04/11/10,12:32:04] VS70pgui: [2] DepCheck indicates VC 10.0 Runtime (x86) was not attempted to be installed.
[04/11/10,12:32:05] VS70pgui: [2] DepCheck indicates Microsoft .NET Framework 4 Beta 2 was not attempted to be installed.
[04/11/10,12:32:05] VS70pgui: [2] DepCheck indicates Microsoft Visual F# 1.0 Runtime was not attempted to be installed.
[04/11/10,12:32:05] VS70pgui: [2] DepCheck indicates TFS Object Model (x86) was not attempted to be installed.
[04/11/10,12:32:06] VS70pgui: [2] DepCheck indicates .NET Framework 4 Multi-Targeting Pack was not attempted to be installed.
[04/11/10,12:32:06] VS70pgui: [2] DepCheck indicates Microsoft Visual Studio 2010 Ultimate Beta 2 - ENU was not attempted to be installed.
[04/11/10,12:32:06] VS70pgui: [2] DepCheck indicates Microsoft Web Deployment Tool (x86) was not attempted to be installed.
[04/11/10,12:32:06] VS70pgui: [2] DepCheck indicates Microsoft ASP.NET MVC 2 - Visual Studio 2010 Tools was not attempted to be installed.
[04/11/10,12:32:06] VS70pgui: [2] DepCheck indicates Microsoft ASP.NET MVC 2 was not attempted to be installed.
[04/11/10,12:32:07] VS70pgui: [2] DepCheck indicates Microsoft Silverlight was not attempted to be installed.
[04/11/10,12:32:07] VS70pgui: [2] DepCheck indicates Microsoft Silverlight 3 SDK was not attempted to be installed.
[04/11/10,12:32:07] VS70pgui: [2] DepCheck indicates Visual Studio 2010 Tools for Office Runtime Beta 2 (x86) was not attempted to be installed.
[04/11/10,12:32:07] VS70pgui: [2] DepCheck indicates Microsoft Office Development Tools for Visual Studio 2010 (x86) was not attempted to be installed.
[04/11/10,12:32:08] VS70pgui: [2] DepCheck indicates Dotfuscator Software Services - Community Edition was not attempted to be installed.
[04/11/10,12:32:08] VS70pgui: [2] DepCheck indicates Crystal Reports templates for Visual Studio 2010 was not attempted to be installed.
[04/11/10,12:32:08] VS70pgui: [2] DepCheck indicates Microsoft SQL Server Compact 3.5 SP2 Beta ENU was not attempted to be installed.
[04/11/10,12:32:08] VS70pgui: [2] DepCheck indicates Visual Studio 2010 Beta 2 Tools for SQL Server Compact ENU was not attempted to be installed.
[04/11/10,12:32:09] VS70pgui: [2] DepCheck indicates Microsoft Sync Framework Runtime v1.0 (x86) ENU was not attempted to be installed.
[04/11/10,12:32:09] VS70pgui: [2] DepCheck indicates Microsoft Sync Services for ADO.NET v2.0 (x86) ENU was not attempted to be installed.
[04/11/10,12:32:09] VS70pgui: [2] DepCheck indicates Microsoft Sync Framework Services v1.0 (x86) ENU was not attempted to be installed.
[04/11/10,12:32:10] VS70pgui: [2] DepCheck indicates Microsoft Sync Framework SDK v1.0 (x86) ENU was not attempted to be installed.
[04/11/10,12:32:10] VS70pgui: [2] DepCheck indicates Microsoft Visual Studio 2010 Performance Collection Tools (x86) was not attempted to be installed.
[04/11/10,12:32:10] VS70pgui: [2] DepCheck indicates Microsoft SQL Publishing Wizard 1.4 was not attempted to be installed.
[04/11/10,12:32:11] VS70pgui: [2] DepCheck indicates SQL Server System CLR Types was not attempted to be installed.
[04/11/10,12:32:11] VS70pgui: [2] DepCheck indicates SQL Server 2008 R2 Management Objects was not attempted to be installed.
[04/11/10,12:32:11] VS70pgui: [2] DepCheck indicates Microsoft SQL Server 2008 Express Service Pack 1 (x86) was not attempted to be installed.
[04/11/10,12:32:11] VS70pgui: [2] DepCheck indicates Data-tier Application Component Framework was not attempted to be installed.
[04/11/10,12:32:12] VS70pgui: [2] DepCheck indicates Data-tier Application Component Project System was not attempted to be installed.
[04/11/10,12:32:12] VS70pgui: [2] DepCheck indicates Transact-SQL Language Service was not attempted to be installed.
[04/11/10,12:32:12] VS70pgui: [2] DepCheck indicates Microsoft SharePoint Development Tools was not attempted to be installed.
[04/11/10,12:32:12] VS70pgui: [2] DepCheck indicates Microsoft Visual Studio 2010 ADO.NET Entity Framework Tools was not attempted to be installed.
[04/11/10,12:32:13] VS70pgui: [2] DepCheck indicates Microsoft Help 3.0 Beta 2 was not attempted to be installed.
למישהו.יש.מושג.למה.זה.לא.עובד?
מה קרה למקש הרווח שלך?
בכל מקרה, חיפוש זריז של הודעות השגיאה הראשונות מעלה את התוצאות הבאות:
http://blogs.msdn.com/amyd/archive/2010/02/10/silverlight-runtime-install-failure-in-vs2010-rc.aspx
http://social.msdn.microsoft.com/Forums/en/setupprerelease/thread/cce8986c-b0df-4712-96de-418017ab2a34
לפטופ.ישן.שירשתי,חצי.מקלדת.מתה.
מחכה.למשלוח.של.המקלדת.החדשה.
לגבי.שני.הלינקים:תודה.אבל.הראשון.לא.רלוונטי.לגבי,כי.אין.לי.אפשרות.להמשיך.
והשני.לא.מצי.פתרון.של.ממש..
תתחיל מכל ה dependency checks אחד אחד:
לדוגמא פה כתוב שלא מותקן לך silverlight.
חוץ מזה קוד 1603 בMSI אומר או שאין לך מספיק הרשאות או שההתקנה פגומה.
http://www.appdeploy.com/msierrors/detail.asp?id=11
הוא אומר שלא מותקן סילברלייט כי זה בדיוק מה שהוא לא מצליח להתקין...
