Battlefield Bad Company 2 - הדיון הראשי.
לאיזה קלאס/תפקיד אתם הכי מתחברים ? 783 הצבעות
  1. 1. לאיזה קלאס/תפקיד אתם הכי מתחברים ?
Changelog:
Server - Some potential sources for lag/rubberbanding have been eliminated
Server - The old reserved slots has been replaced by a kick-on-demand system like in BF2
Server - Log file for server admins: all remote admin interface commands/events are logged
Server - Log file for server admins: major server events + all chat messages are logged
Server - Idle kick is controllable
Server - Profanity filter can be disabled
Server - Teamkill-kick system is controllable
Server - Ticket counts and bleed rate are controllable per-level
Server - Infantry only mode available per-level
Server - Initial spawn delay and respawn delay are adjustable
Server - Server description can be up to 400 characters, and use "|" for line breaks
Server - Banlist can contain up to 10.000 entries
Server - reduced latency in packet handling
Admin Interface - fixed the player.onKill spam that occasionally happened
Admin Interface - ensured that player.onJoin events always report the player name
Admin Interface - events triggered when people spawn
Admin Interface - much more info on kills
Admin Interface - detailed stats are reported at end-of-round
Gameplay - Various minor level bugfixes
Gameplay - Helicopter handling has been tweaked
Gameplay - Weapon tweaks have been implemented based on PC public feedback
Gameplay - Tracer dart gun speed has been changed from 300 m/s to 200 m/s
Gameplay - Fixed technical hang when a crate was armed outside of the combat area
Gameplay - "Victory is near" message was shown for the wrong team on Valparaíso, this has been fixed
Gameplay - Countermeasures can be fired when driving a helicopter
Gameplay - The brightness of the pilot view in the Russian helicopter has been reduced
Gameplay - Advanced Spotting scope works better
Gameplay - Knifing people in the back works again (we backed out the change that we had done for Server R11)
Gameplay - Hit box for moving targets expands based on the speed of the targets movement
Gameplay - G36 now has crosshair when in Hardcore mode
Server Browser - Servers are sorted into 3 categories: Normal, Modified, Hardcore depending on their settings
Server Browser – Added support for retrieving update progress
Server Browser - Now refreshes information
Server Browser - Join queue system when attempting to join a full server
Server Browser - All settings are automatically saved between sessions
Server Browser - Pings are sent via an alternate mechanism, which should work for non-Administrator users as well
Client - Fixed DX9 issue, which likely caused graphics glitches and perhaps crashes
Client - Fixed some crashes
Client - Toggle/hold crouch is user controllable
Client - Toggle/hold zoom is user controllable
Client - Vsync bugfixed for DX10/DX11
Client - Rewritten how settings are written to disk; this should reduce/eliminate the spawn lag
Client - Fixed bug where a player could join a server before the stats has been downloaded causing faulty stats in "EOR- unlock progression"-screen
Client - New chat system allows chatting when dead (but not during end of round) and keeps a 100 lines log
Client - Improved Play Now functionality
Client - Removed K/D ratio and Skill Level filters in the leaderboards
Client - Any points you get while being dead will be added to your score
Client - Reduced negative mouse acceleration
Client - Increased health on the Cobra to match other vehicles
Client - More informative disconnection/kick reasons
Client - Support for Map Packs so PC gets future VIP maps at the same time as consoles
The Balance tweaks are as followed:
Slightly increased the damage of the UZI at long range.
The AKs74u now has more felt recoil when aiming.
The G3, VSS, and all SemiAutomatic rifles now settle slightly faster between shots when aiming.
The PKM, Type 88LMG, G3, An94, and 40mm shotgun have returned to their former glory.
Increased the damage of the MG3 to bring it in line with the rest of the LMGs.
Fixed a bug where the Saiga12 with slugs would do too much damage at long range.
Fixed a bug where the SVU would do too little damage at long range.
Fixed a bug where M95 rounds would not kill armored targets with headshots.
בעקרון אין משהו "חדש" זה יותר תיקונים לבאגים שנוצרו אחרי הפאטץ' האחרון ועוד כמה איזונים במשחק וכד'...
  • תגובות 7.8k
  • צפיות 733.4k
אין משהו חדש? רק אצלי אין אף שרת? גם אחרי חצי שעה של SEARCHING זה מראה 0 שרתים ואת כל השרתים בפייבוריסטס ובהיסטורי הוא מראה כלא פעילים...
DICE :facepalm:
מצאתי את הפתרון, לכבות ולהדליק את המשחק עשרים פעם.
איפה הX4 לM14????
לא יודע מה איתכם,
אבל אני מצליח להתחבר סוף סוף לשרת לבנתיים
DICE :facepalm:
מתי בדקת? EA וDICE אמרו שהשרתים ירדו עד סביבות השעה 10/11 לצורך העדכונים...
All game servers will need to be taken down for updates. The maintenance period starts on Wednesday Jun 30th at 07:00AM (GMT+2). Most of them should be back up by 11:00AM (GMT+2).
דברים חדשים?
יש דווקא את זה:
בדיוק באתי לשאול. אומנם אני מוריד את העדכון עכשיו. אבל השרתים יחזרו רק בסביבות 11?
משהו כזה...
אל תשכח שחוץ מהשרתים של EA/DICE , גם שרתי המשחק שלנו ירדו לצורך התקנת הגירסה החדשה R15.
יש בחתימה שלי את הבאנר של השרת שלנו , תוכל ללחוץ עליו ולראות מה הסטאטוס שלו ומתי הוא יחזור לפעילות.
מישהו יודע כמה זמן בערך לוקח לעדכן?
הא מצוין! תודה.
אני אניח שמתי שהוא יחזור שאר השרתים (רובם) יחזרו גם כן. D=
לך או לEA??
לך זה תלוי בחיבור שלך ובהנחה ששרת העדכון לא ייפול מעומס (דא....)
לEA והשרתים , כבר רשמתי קודם , תקרא אחורה קצת....
איפה הכוונת X4 לM4?
איפה הCOOP
איפה המפות החדשות?
מעולם לא אמרו שהONSLAUGHT יהיה לPC - אמרו שיחשבו על זה.
מפות חדשות? אהה.. כן ,זה נקרא BC2 VIETNAM... :lol:
אין מפות חדשות - יש שינוי מפות קיימות למצבי משחק אחרים ....
ולגבי הכוונת לM4 , זה גם משהו שלא עלה מכיוון של DICE , זה משהו שעלה מתוך קהילת השחקנים בפורום הרשמי של BC2.
אני לא בטוח שזה משהו שהיה אמור מלכתחילה להיכנס לפאטץ'...
או אז סתם ציפיתי לכלום
ד"א, ניראה לי מצאתי את הנשק הOP החדש- המיניגאן של האפאצ'י. הרגתי איתו 10 אנשים בלי שום בעייה כשפעם הייתי הורג בקושי אחד בשעה
הם רשמו שיהיה יותר קל להטיס את המסוק , ייתכן וזה קשור...
מיניגאן של האפאצ'י?? התכוונת אולי למיניגאן של הבלאקהוק לא?
אני לא יודע מה איתכם,אבל העדכון עשה רק טובות למשחק,אני ממש מרוצה.
אחרי שיצא לי לשחק בערך שעה וחצי בשרת ישראלי עכשיו,אין לי לאגים ולא נתקלתי בשום באג או הנתקויות מהשרת
המפות נטענות הרבה יותר מהר,ה SP מהיר,וזה אני או שה- FPS באמת עלה?משום מה המשחק זורם בהרבה יותר טוב.
האם אמרתי כבר שאני מרוצה?! ח"ח ל EA. :yelclap:
המפות נטענות יותר מהר, הסכין דוקרת, הקליעים פוגעים(לפחות רובם)
אני מרוצה.
