עזרה במסך כחול.
A problem has been detected and Windows has been shut down to prevent damage
to your computer.
The problem seems to be caused by the following file: ntoskrnl.exe
IRQL_NOT_LESS_OR_EQUAL
If this is the first time you've seen this stop error screen,
restart your computer. If this screen appears again, follow
these steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer
for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware
or software. Disable BIOS memory options such as caching or shadowing.
If you need to use safe mode to remove or disable components, restart
your computer, press F8 to select Advanced Startup Options, and then
select Safe Mode.
Technical Information:
*** STOP: 0x0000000a (0xfffffa9801ece8cb, 0x0000000000000002, 0x0000000000000000,
0xfffff80002d2fdbf)
*** ntoskrnl.exe - Address 0xfffff80002c82f00 base at 0xfffff80002c11000 DateStamp
0x4a5bc600
זה קרה לי פעמיים, פעם אחת בזמן הרצת פריי95 ופעם אחת בזמן OCCT. יש מצב זה בגלל זה?
תודה!
עכשיו זה קרה בפעם השלישית, הבעיה שזה קורה בזמן שאני מריץ OCCT ופריים95. יכול להיות בגלל זה שהOC לא יציב?
עוד אחד:
to your computer.
The problem seems to be caused by the following file: hal.dll
SYSTEM_SERVICE_EXCEPTION
these steps:
select Safe Mode.
*** STOP: 0x0000003b (0x00000000c0000005, 0xfffff80002a8b1e6, 0xfffff88008a325b0,
0x0000000000000000)
*** hal.dll - Address 0xfffff80002ff4a56 base at 0xfffff80002ff0000 DateStamp
0x4a5bdf08
ועוד אחד קיבלתי היום:
to your computer.
The problem seems to be caused by the following file: dxgmms1.sys
SYSTEM_THREAD_EXCEPTION_NOT_HANDLED
these steps:
select Safe Mode.
*** STOP: 0x1000007e (0xffffffffc0000005, 0xfffff88003dac1d8, 0xfffff88004b91568,
0xfffff88004b90dc0)
*** dxgmms1.sys - Address 0xfffff88003dac1d8 base at 0xfffff88003d87000 DateStamp
0x4a5bc578
עוד אחד:
to your computer.
these steps:
select Safe Mode.
*** STOP: 0x0000003b (0x00000000c0000005, 0xfffff80002d94b9b, 0xfffff8800653dd10,
0x0000000000000000)
*** ntoskrnl.exe - Address 0xfffff80002acef00 base at 0xfffff80002a5d000 DateStamp
0x4a5bc600
מישהו יכול להסביר לי למה אני מקבל את המסכים כחולים האלה?
בגלל האוברקלוק !!!! :kopfpatsch:
תבטל ותראה מה קורה
ואולי תעשה אוברקלוק הגיוני יותר
